08-13-2011, 06:48 AM | #1 |
Rep 3,435
Car squeaks/squeals when in reverse
Kinda hard to explain the noise, its kinda like a low tone squeal. Happens when I drive slowly in reverse, like when backing out of a parking spot or driveway. It doesnt happen all the time. My dad heard it one time while I was home visiting, he said its caused by the rainy weather, but I've heard it when it was nice and sunny out.
Its very loud and noticeable, definitely a sound you shouldnt be hearing from a car thats only a year old. |
08-13-2011, 08:03 AM | #2 |
44
Rep 238
My car does this as well. I think it is caused by the e-brake sticking a little, but because I have MT I always use e-brake so I have never tried without. I mentioned it to the dealer when I brought it in for service and their response was vague and unhelpful. Mostly just told me to live with it.
My brakes were squeaking as well due to an improperly installed sensor that was prematurely rubbing. Now that I think about it, since they replaced my pads/sensors for my brake squealing issue, I have not noticed the reverse squealing issue either. Perhaps that is the cause? |
08-13-2011, 08:04 AM | #3 |
Rep 7,341
Mine has also done this since day one. Dealer was able to replicate and sent the symptoms to BMW. They replied that there is no fix and to send me on my way. It's pretty embarrassing.
The views and opinions expressed in this post are those of the author and do not necessarily reflect the official policy or position of Bimmerpost.
2018 Jeep Grand Cherokee High Altitude Hemi | 2010 S4 Sold | 2010 BMW 135i Retired | 2006 Lotus Exige Sold |
08-13-2011, 08:17 AM | #4 |
Rep 3,435
I wonder if the hill assist is causing it somehow. Like its not fully disengaging.
08-13-2011, 08:39 AM | #5 |
Rep 1,362
It's the E brake sticking, mine does this also if I fully engage the E brake to park. I hate it also so now when I park in public I'll leave the car in 1st and only pull the E brake if I'm on an incline and even then only 2-3 clicks. This works for me.
08-13-2011, 10:15 AM | #6 |
Vrooom :)
315
Rep 2,602
the exact same thing happens to me. it has almost always been there.
2014 C7 Corvette Stringray - Laguna Blue - NPP Exhaust - Competition Seats
08-13-2011, 07:06 PM | #7 |
High School Dropout
13
Rep 323
It's been a pretty well documented issue. It's generally not caused by your e-brake, but rather the front pads from when you last applied them when you parked.
See: http://www.1addicts.com/forums/showthread.php?t=405655
08-17-2011, 08:24 PM | #8 |
yield to pedestrians
Rep 57
I notice something similar to this with my car--I would almost call it a groaning sound. The acoustics of parking decks made it most noticeable. The dealer said it was a wear sensor, replaced the rear pads and the noise went away.
08-18-2011, 05:12 AM | #10 |
Rep 1,922
Drives: 2021 G80 M3
I have that on my E90 on top of the squeaky brakes when you start moving and then stops after passing 20mph.
'21 G80 M3
'11 E82 135i DCT (Gone but not forgotten) '08 E90 335i (Gone but not forgotten) |
08-18-2011, 06:18 AM | #11 |
Rep 1,362
08-18-2011, 06:57 AM | #12 |
Rep 38
Same thing happens to me, and I only have like 1000kms on it. I was thinking about going back to the dealer but I see this is a common thing now...these forums rock
08-18-2011, 05:53 PM | #13 |
Rep 134
08-18-2011, 07:00 PM | #14 |
Rep 941
when going in reverse apply a bit of ebrake.. see what happens to the noise...
JB4, DCI, Digi boost, CSL eyelids, 5% tint, KW v2's. Bastuck 85mm quad w/ berk resonated mids, LED int ltg, Perf SSK, CF int trim, 19" SF-71 rims, CDV mod, BMS OCC, ER+tial charge pipe. AR DP's, Helix IC,meth, drilled slotted rotors
08-19-2011, 06:30 PM | #15 |
Rep 462
I've been getting this squealing noise too in recent months, when backing out of my driveway. It only happens after the e-brake has been used. Earlier in the summer I heard it every morning, but now just once in a while.
I'll mention it to the dealer again on my next scheduled visit, but all in all, considering the more serious problems I've been able to avoid thus far, I'm 99% satisfied with how reliable this car has been, and this is not something I'd lose sleep over... |
08-19-2011, 10:11 PM | #16 |
Rep 134
So I didn't engage the e-brake last night and this morning I had zero squeal.
Pretty silly that I can't use my e-brake in order to avoid my car sounding like a hoop-die, but it's worth it. |
08-19-2011, 10:37 PM | #17 |
467
Rep 4,592
09-02-2011, 02:10 AM | #18 |
Rep 627
Drives: '09 E88 135i M-Sport/6MT/SGM
I brought my 135 cab in yesterday. Had them adjusted the e-brake and will update if the noise returns. Interesting thing is adjustments aren't covered under warranty, but now that I paid once it has it's own warranty.
| Dinan S2=>MHD | e46 M3 trans mounts | Dinan CF CAI | ER CP | HKS SSQV4 BOV | RB PCV Valve | VRSF DP | N55 MP | BMW PE | OC | VRSF 7" FMIC | UUC Evo3 SSK | EBC GD Sport Rotors | EBC Redstuff | TRW F+R | | Whiteline KDT918 | H&R Front Sway | BMWP 313 | MPSS 225/255 | Scopione CF Rear Diffuser | iCarbon CF Rear Spoiler | P3 v2.1 Gauge | Interior LED Retrofit |
09-02-2011, 01:56 PM | #19 |
Rep 145
Its the ebrake, and it happens on reversed, changing pads does not help, i just had my pads replaced about 30 days ago.
the fix for me is to disengage the ebrake, engage and disengage again... works every time. |
09-02-2011, 03:10 PM | #20 |
Rep 1,101
I was told to rinse the brakes when I wash the car. I put the hose right up to the brake calipers/pads and rinse it for several seconds. I was suprised to find that this works. I had the squeal in reverse but rinsing the brakes will stop the squeal for a week or so. It is not a permanent fix but it does stop it for a bit...usually till the next wash. The more water pressure the better!
The BMW dealer recommended giving my brakes some repeated hard use to stop the squeal. I have had mixed results with this. I tried it a few times with no luck. After some serious braking one evening I stopped the squeal for a while. However, we are talking some repeated serious threshold heavy braking (and some serious brake dust build up!). I would say this is not a good route to try. |
09-02-2011, 05:29 PM | #21 |
Rep 3,435
Twice in the last 2 days I've heard my main brakes (Brembos up front) faintly squeak during normal driving. Its rarely and not all the time. Its probably nothing, but its definitely coming from my car.
09-02-2011, 06:06 PM | #22 | |
376
Rep 2,388
Drives: M2 Competition
Sounds like a brake issue to me... I have heard and seen it diagnosed three times properly and several times with solutions that didn't solve the noise issue. I am not sure about BMWs but all past experience tells me that it is a brake issue...
Best of luck, -NurEinser Quote:
