BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Odd occurrence. All settings lost. Ideas why?
      03-04-2012, 08:18 PM   #1
jklamerus328xi
jklamerus328xi's Avatar
Drives: 2008 328xi
2008 BMW 328xi  [0.00]
Question Odd occurrence. All settings lost. Ideas why?
When I went out to my car this morning I quickly noticed all radio presets were lost and upon further investigation I noticed every setting in the whole car was reset. I went through my iDrive screen by screen and had to reset everything to my liking. Literally every setting was restored to factory settings. Ever have this happen? Something to worry about?
      03-04-2012, 08:32 PM   #2
AddictedToBavarian
My other ride is a Bianchi Infinito
AddictedToBavarian's Avatar
Portugal
96
Drives: Miss my E92 but love my E46 M3
Did you have a long crank? Happened to me when I had a "increased battery discharge" issue.
      03-04-2012, 09:24 PM   #3
Tom K.
Tom K.'s Avatar
Drives: '07 328iT, '13 Boxster
Did you inadvertantly use the other key fob?
But if your trip odometer was also reset, this most likely indicates a low battery charge.
Tom
      03-04-2012, 10:33 PM   #4
jklamerus328xi
Drives: 2008 328xi
No it started just fine. I put it in the garage last night and this morning the issue. It is going in for service Tuesday. I'll add this to the list of things for them to check out. Thanks for the reply.
      03-04-2012, 10:34 PM   #5
jklamerus328xi
Drives: 2008 328xi
Tom
I didn't use the other key fob. I have it scheduled for service on Tuesday so I'll just run this by the tech's then. Thanks for replying.
      03-05-2012, 09:20 AM   #6
Professor///M
Professor///M's Avatar
819
Drives: 2022 M3, 2022 X5 40i;
I have had this happen once or twice. What happened is it probably didn't register your settings.
If you shut your car off and put your key back in, chances are on startup settings are just fine.
If it happens multiple times, chances are the battery in your FOB is dead. Your car charges it every time you put the key in, and if the battery dies you could lose the settings since it would take a long time to recharge and read them.
      03-05-2012, 03:12 PM   #7
jklamerus328xi
Drives: 2008 328xi
Thanks for the thought. You're probably right about this.
      03-05-2012, 03:15 PM   #8
jphughan
jphughan's Avatar
Drives: '16 Cayman GT4
Just as a reminder to avoid this turning into yet another thread where this issue is confused, only NON-Comfort Access fobs are charged in the slot. If you have Comfort Access, buy a CR2032 battery anywhere for $2-3 and see if that helps.
'16 Cayman GT4 (delivery pics, comparison to E92 M3 write-up)
Gone but not forgotten:
'11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015)
idrive, issue, lighting, radio, settings
