BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > AUSTRALIA > Dashcam Installation
GetBMWParts
      05-15-2017, 11:51 AM   #89
omorzo
Always on track!
omorzo's Avatar
Italy
Drives: 328i
Hello, i don't know if this is the right place for ask. I can use the 12v of the rain sensor for the dash cam?
      05-20-2017, 07:10 AM   #90
feng
feng's Avatar
Australia
128
Drives: 2014 F31 328i M-Sport AW
Do you mean tap off the same line? From memory, BMWs don't like that? Not 100% sure, but i do recall reading it. That being said, running to fuse box is essentially the same I guess?
Perhaps ask in the modifications forum section?
      05-27-2017, 11:17 PM   #91
jkwhar
Drives: F30 328i Xdrive | F15 x35i
I tapped off the compass on the mirror for my radar but for the dashcam, tapped the ACC+ at the mirror/compass and Batt+ at the fusebox.
http://f30.bimmerpost.com/forums/sho...d.php?t=780561
Did my post help? Click "Appreciate!"
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD)
      09-25-2017, 04:55 AM   #92
jyc093
27
Drives: 2016 430i
Originally Posted by feng View Post
i'm in a meeting now, but I have since removed my PMP and gone with a Cellink Battery B.
I'll write up a quick review on that when I get a chance.
I must say, it is very worth the money.
Hey Feng, could you provide us with a review of Cellink Battery B? I'm considering the battery pack over PMP since i don't want to put too much stress on the car battery. Cheers!
      10-13-2017, 01:18 PM   #93
hmmwvj
Drives: F30N 320i
Originally Posted by SteveAus View Post
I've attached a PDF file that can walk you through the wiring. I'm assuming the F30 Wagon is similar to the F30 Sedan.
Attachment: http://f30.bimmerpost.com/forums/att...6&d=1430952700
This is a silly question but do I have to disconnect the negative battery terminal before connecting the PMP to the positive battery terminal connection as described? Just making sure.
What effect does disconnecting the battery terminals have on the car?
      10-15-2017, 09:26 AM   #94
feng
feng's Avatar
Australia
128
it's not necessary to connect to battery anymore. I find that the PMP is not that good either (if you read through the whole thread). I am yet to have time to take off my trims etc to take pictures of how my Cellink is wired up but i will soon.
      02-13-2018, 02:31 AM   #95
jyc093
27
Drives: 2016 430i
For those who are interested in the cellink, it works best if you drive 45 minutes+ a day. For me who drives 10 minutes (one way) to work, its hard to get the full 15+ hours of recording.
Tux22.50
      03-26-2018, 01:15 AM   #96
jyc093
27
Drives: 2016 430i
Finally, after months of procrastination, I finished hardwiring my dashcam/cellink B to the fuse box.
      04-08-2018, 06:07 AM   #97
ECHAN852
Drives: BMW F30 320i
That box on the left of the fuse box... it's held down with a metal bracket. I bent the grounding wire a little and screwed it under that.
Can take a pic if you don't figure it out.
Dear feng,
I am looking for grounding point in the trunk, could you share with me a picture how u did it? Many thanks.
      04-09-2018, 08:38 AM   #98
feng
feng's Avatar
Australia
128
Originally Posted by ECHAN852 View Post
Dear feng,
Just using the picture above, I used the point in the pic below.
      04-09-2018, 03:57 PM   #99
too hot
too hot's Avatar
Scotland
113
Drives: None
Excellent write up and troubleshooting.
I`m going to fit my Blackvue tomorrow.Had it a year and its sat in the box unused !!
Fingers crossed its still works !!
RS4
      04-15-2018, 06:21 AM   #100
ECHAN852
Many thanks, I used the same point that is a bolt facing upward , I added a 5mm nut to fix the grounding cable.
      04-16-2018, 12:45 AM   #101
feng
feng's Avatar
Australia
128
Many thanks, I used the same point that is a bolt facing upward , I added a nut to fix the grounding cable.
I think so. I cut the grounding clip and wedged it against the body of the car (from memory).
      06-05-2019, 02:47 PM   #102
allotherareused
13
Drives: 320d, f30
consider home link
I've just found this post because I was looking for BAT fuse (old dash cam has battery, new one need constant power in order to keep settings and to save last file). Anyway, mi comment is about homelink fuse (if I remember this is 146). Consider using it instead of 143, this power very similar and works just as I like it, power on when you power engine and power off with small delay.
      11-07-2023, 03:24 AM   #103
arsenal6
Drives: bmw 428xi
2015 bmw 428xi  [0.00]
Here are a couple of iPhone-tastic pics.
First one shows the positioning under the connected drive unit centering the lens.
Second one shows the back camera with the split tailgate window open.
Third one shows how the cable slack is managed so the main tailgate can open.
Fourth one shows the issue i have with the B pillar.
I'll post my fusebox when I get home, and maybe do a proper run through on it like Steve did earlier in the thread.
I also tested the PowerMagic Pro with ASS and it does not reboot my camera as others around the world have reported. Not sure why that would actually happen though as the power is still on. It's like saying the lights would turn off when ASS kicks in?!
When I tried pushing the cable into the b-pillar cover; rather than have it exposed, my car started to beep, 3 times (vehicle was off (f32)) anyone else experience this?
