02-22-2022, 01:44 PM | #1 |
157
Rep 466
horizonmotorsport.com | ARM Motorsports S55 Silicone Charge Pipes
HIGHLIGHTS
•Insulates Charge Air From Engine Heat • 5-Layer Steel Reinforced Silicone Piping • Built for High-Boost Applications • Precision CNC Machined Turbo Connections https://horizonmotorsport.com/collec...f83-m4-f87-m2c PROFILE The ARM S55 Silicone Charge Pipes allow you to maximize power on your S55 powered BMW by replacing the OEM charge pipes which are known for cracking. Silicone charge pipes benefit the S55 engine over their aluminum counterparts by providing an extra layer of insulation. Aluminum charge pipes conduct heat very easily between the engine bay and the charge air going from the S55's turbos to the intercooler, while silicone charge pipes provide a significant improvement in insulation between these two areas. |
