Dyno runs.. what gear on a 6MT?
09-09-2009, 08:58 AM | #1 |
BlackBerry King
41
Rep 184
Drives: 2009 BMW 335i
I have done a couple of pulls in 4th gear on the dyno, and I am wondering as I just read a couple of threads with people mentioning doing 3rd gear runs. What gear are you guys using for your dyno pulls?
Thanks!
2009 BMW 335i /6 SPD Fully Loaded Saphire Black on Black Dakota Leather |
09-09-2009, 09:00 AM | #2 |
Rep 7,377
always 4th
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
09-09-2009, 09:06 AM | #3 |
ASR Turbos+LSD+Meth= :D
73
Rep 1,517
Drives: E92 335i
our fourth gear usually yield higher numbers. not sure of the technical reason of load or something, but from a laymens standpoint, you have more time in the dyno run to see peaks and valleys of the run in a higher gear.
2007 335i Coupe Mods: Check the Garage |
09-09-2009, 09:09 AM | #5 |
BlackBerry King
41
Rep 184
This is exactly why. Its all about a 1:1 ratio. I remember my 325i I actually did the research and it was truly 4th, I am just trying to verify that it is indeed the same on the 335i's
09-09-2009, 09:14 AM | #6 |
Team Zissou
3084
Rep 10,198
We did a test at a dyno day: back-to-back 3rd and then 4th gear pulls on the same car. The power output was exactly the same.
I always have to use 3rd on my car because the AWD goes bonkers when trying 4th gear. |
09-09-2009, 10:05 AM | #7 |
54
Rep 886
The most accurate numbers are when using 5th gear (1:1 gear ratio).
Mods: RB turbos, JB4, BMS DCI, Scoops, Forge DVs, ar design catless DPs, Milltek exhaust system, Helix FMIC, Quaife LSD, VK MotorWerks OC Kit, Bilstein B16 PSS10
09-09-2009, 10:13 AM | #8 |
Rep 1,410
4th takes a LONG time to dyno going from 2k to 7k lol... the dyno guy was like "that is a tall gear" and I told him that he just went about 142 mph and starting all the way down around 2k rpm's takes a while. It is, apparently, the 1:1 gear though so that is what I use. I would almost rather use 3rd since it would decrease my stock FMIC heat-soak
09-09-2009, 10:26 AM | #9 | ||
Rep 318
Drives: 08 E92 335xi
