01-01-2024, 05:11 PM | #111 |
Rep 1,591
I am referring to the CANBUS message identification process. I am not familiar with the BMW security software protocols, just that it seems to be all internal to the FEM as there are no CANBUS links going to the locks, only direct wiring.
As far as the software/hardware he uses: he taps into the actual CANBUS wires of the bus components he wants to map out, and with his python program visual-interface one can eliminate most non-applicable bus messages. I am not planning to build a remote starter, but I am following this thread to learn about the CANBUS messages that I could use with an MMI. More CANBUS ID info: https://docs.google.com/spreadsheets...gid=2000294247 https://www.loopybunny.co.uk/CarPC/k_can.html https://www.reddit.com/r/CarHacking/ https://www.m5board.com/threads/any-....214354/page-2
Help each other: if you manage to fix your issue (especially with help from this forum), don't be a d*ck and disappear. Follow-up by posting the solution so you can help others.
01-03-2024, 01:57 AM | #112 | |
Rep 1
Easy part regarding the can us CMD is the basic functionality like send command to lock/unlock doors and trunk, including roll up down windows and other various stuff like horn, lighting (such as hazard headlight taillights, gauge cluster rpm and various lights within the cluster that you can enable at will...all via canbus. Hard part is finding the right command for ACC/IGN trigger and also the firing command to trigger the starter. I was able to finally got all those using techstream/Subaru ssm4 software by intercepting the messages that's being sent by the software. And I was able to have access to all those and more. I can't now start the engine and shut off and even full control of HVAC and more .. all via the canbus connected to just the high and low. Two wires . Just two simple wires. 😂 In comparison to what you have here it feels like technology from 20 years down the road. Unfortunately I don't know what kind of software bimmer uses that's equivalent to Toyota/Subaru diagnostic software but if you can get your hand on it, then I believe you could definitely start something with it. I'm almost done with my project..currently using Arduino mkr 1500 LTE with mkr can shield connected to my Mqtt server. Even though this is a bummer forum, I'll try to post update and hopefully it may help out in moving to just canbus control which makes things a lot more super portable and less power consumption with no relays or barely any wires used Good luck. Sorry for any typo..typing from phone 😔 |
fe7565552.50 |
01-03-2024, 05:24 PM | #113 | |
Rep 1,591
I am interested, if you post later on your progress. It's a great challenge and at times comes with setbacks...but fun. Hope to learn from you...and do not hesitate posting any questions...someone here may be able to give you tips.
01-05-2024, 03:33 PM | #114 |
97
Rep 130
Video:
https://www.youtube.com/watch?v=qO5-HMEZOW4 If you unlock before 3x lock, it won't trigger alarm and the car will remain locked - so it's quite usable atm. I am quite certain that you don't need CAN and that it is a timing issue for disarming alarm trough A173*2B pin 30, previous BMWs use double pulse for unlocking, but how long the interval between pulses with or without central unlocking etc is uncertain. Just have a regular multimeter, but can see that pin 30 has a voltage reading 3.85v when idle, 3.73v when locking and 3.81v when unlocking. Can't see if there are any double pulses with my equipment. Eventually something will pan out |
fe7565552.50 |
01-05-2024, 03:44 PM | #115 | |
Rep 1,591
Maybe you can connect the voltage reading to an Arduino port and run a program that uses the PULSE-IN https://www.arduino.cc/reference/en/...ed-io/pulsein/ or Analog-in pin. Or use an oscilloscope. The Pico 2204A has a decent price and features for automotive as well. This guy has a lot of good videos with the Pico: https://www.youtube.com/@MechanicMindset Or an Arduino oscope: https://www.instructables.com/Oscill...no-Processing/ Don't expect nanoseconds resolution, but should be good for milliseconds and probably microseconds.
01-05-2024, 04:16 PM | #116 | |
97
Rep 130
I'll look into PULSE-IN, thanks for the suggestion |
f30, remote, remote start |
