BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > Bluetooth Compatible Phones List
      05-04-2005, 08:56 PM   #23
CaptJack
Mach 1 in a BMW
CaptJack's Avatar
Drives: 2019 BMW X3 M40i
Cradles
Originally Posted by Ewrek
Does anyone know what Docking cradles are available here in the US??
If it's a Bluetooth phone you don't need a cradle. Just leave it in your pocket.
      05-04-2005, 09:20 PM   #24
robertb
Drives: 2012 335i
Yes, it is listed as a $130 accessory specifically for the e90 on the BMW NA site. The Motorola v710 is shown in the cradle, but I think any of the Bluetooth compatible phones that BMW's lists on the site can also be accomodated. The advantage of the cradle is the charging plus (and best of all) the phone will use the sharkfin antenna on the roof instead of the phone's built-in antenna for better reception and less microwave exposure for the driver.
      05-05-2005, 05:04 PM   #25
Jason
Administrator
Jason's Avatar
Drives: F80 M3
Picture of bluetooth docking cradle.
      05-09-2005, 09:39 PM   #26
CaptJack
Mach 1 in a BMW
CaptJack's Avatar
Exclamation Bluetooth Phones
Just a quick note: I just bought a Motorola Razr V3 and it is fully functional with my car. But, not until the latest software update was made by my dealer today. Apparently some cars are getting through without this update and you will NOT be able to pair your phone. So if you have such a problem don't just assume it's a phone problem, your car may not have the latest software updates. These are coming through apparently with some regularity.
Happy Bimmering!!
      05-10-2005, 12:03 PM   #27
RedStripe
RedStripe's Avatar
Drives: 2006 BMW 325i
2006 BMW 325i  [0.00]
Thanks for the update CaptJack. In an earlier post on a different thread, you had mentioned that the radio display (at least for non I-Drive cars) interacts with your bluetooth phone.
1) Once you pair your phone, can you scroll through your numbers using the radio display and buttons on your steering wheel?
2) When you get an incoming call, does the radio display show caller ID if available?
3) How else does the radio display interact with the phone? Thanks.
      05-10-2005, 07:41 PM   #28
Athos
Drives: 2006 330i 6-spd
Originally Posted by Tor330
Anyone know if the TREO 650 will work in the new E90 - I know it is not on the original list of officially compatible phones but I was wondering if it can still be "paired"
I can't believe they don't support the Treo 650 or the Blackberry. The ultimate yuppie car should support the ultimate yuppie phones. I would have gone for the bluetooth option but I'm not converting from my Blackberry. I probably spend 2 to 3 hours a day in a car but I spend even more time on my damn Blackberry. Any other Treo or Blackberry users out there baffled by this oversight on BMW's part?
      05-10-2005, 10:11 PM   #29
CaptJack
Mach 1 in a BMW
CaptJack's Avatar
Phone interface
Answer to #1 is I'm not sure, I haven't tried that. You would normally do that by turning the 2 knobs on the radio. The radio face takes on many different configurations depending on what you press. #2 is yes. You can also dial out by pressing the station buttons when the screen mimicks a key pad (horizontal). It will also list your missed calls and most other features offered on your phone. But, by far the best feature is "voice command". It works just like the 7 series. Simply press the voice command button on the steering wheel and tell Jeeves what you want to do. You can also control the volume of the incoming caller with your cell phone volume control as well as your radio volume control.
Check this out: This afternoon I was walking out of a store to my parked car. When I opened the door my phone automatically switched to the car stereo system without me doing or touching ANYTHING! My cell phone went silent and I was communicating through the cars system. All this with the car turned off and my key in my hand. The radio face lit up and all phone features were available. Pretty cool.
      05-10-2005, 11:43 PM   #30
RedStripe
RedStripe's Avatar
Yeah that's cool! Phat, super phat.
      05-11-2005, 03:44 PM   #31
jiggax23
9
Drives: e90
How do you pair the phone w/ the car w/ iDrive? I have a motorola v80 and cannot seem to get it to work. Any suggestions? CaptJack do you know, if any, the version number for ur software? Thanks!
      05-11-2005, 04:36 PM   #32
Nathan
Nathan's Avatar
Drives: 2010 X5 3.0
I had a similar issue trying to get my Jabra Bluetooth headset to pair with my AudioVox SMT5600 SmartPhone. I found out on my phone that there is a special menu i have to access to get the phone to initiate the pairing with a BT device. You will need to find that menu on your phone, but its probably in your user's manual.
Once you initiate the BT search and connect, it will find the BMW speakerphone device. This is normally turned off on all phones by default (searching for new devices, that is).
      05-11-2005, 07:08 PM   #33
jiggax23
9
Drives: e90
is there any way to make the car search for my phone? i have had no luck making the phone find the car. *shrugs*
      05-11-2005, 07:20 PM   #34
Nathan
Nathan's Avatar
Drives: 2010 X5 3.0
I'm pretty sure you have to initate from your phone. try this for your v80:
go to menu, settings, connection, bluetooth, headsfree, look for device
When prompt, enter password: 0000
Follow instruction.
See these i googled:
http://www.mobiledia.com/forum/topic19723.html
http://www.mobiledia.com/forum/topic21470.html
      05-11-2005, 10:30 PM   #35
CaptJack
Mach 1 in a BMW
CaptJack's Avatar
Pairing
I'm not sure, I don't have I-Drive on my car. I do know you need to put both the phone and the car in "search" mode. But first, if you're having trouble with pairing I'd call your dealer and check on the software update. Mine should have been updated in Spartanburg but wasn't.
      05-12-2005, 02:59 AM   #36
jiggax23
9
Drives: e90
Hmm.. interesting.. Anyone with or without iDrive know how to put the car in search mode? I tried with a motorola razr and still couldnt get it to connect?
      05-14-2005, 11:53 AM   #37
Jason
Administrator
Jason's Avatar
Drives: F80 M3
from ObD at bfest
Bluetooth rules!
      05-14-2005, 12:12 PM   #38
RedStripe
RedStripe's Avatar
Thanks Jwocky, I've been wanting a picture like that for awhile now!
      05-14-2005, 02:12 PM   #39
Athos
This kind of picture is definitely useful.
Does anyone know if BMW can add other bluetooth phones later? In otherwords, say I purchased the bluetooth option now, is it possible that at some later date that this system would be compatible with additional phones (my phone is ablackberry and it isn't currently supported). Would this involve a sw update?
      05-14-2005, 02:54 PM   #40
Armen52
Armen52's Avatar
34
Drives: 2006 330i
2006 330i  [0.00]
I guess it depends on the reason that its not supported now. The way phones are supported or not is not individually but if they support what's called a Bluetooth "profile".
There are a couple of Bluetooth profiles that can be used with handsfree sets and cars, one more capable than the other. Their exact names I'm not sure of right this second so I won't say what I think they are anyway.
So let's say new phones come out in the future with proper support for these profiles, then they SHOULD work in the BMW. If there is a bug in the implementation of either the car or the phone you have and that's why its not supported now; AND the company responsible decides to fix it, then its feasible your phone could work in the future as well.
That said, I still don't know the reason why the Treos and Blackberries aren't supported right now. I think that's really ironic because the people with those phones are the ones MOST likely to be talking most, especially on the go. Oh well.
      05-14-2005, 05:03 PM   #41
jiggax23
9
Drives: e90
anyone w/ navigation have their bluetooth hooked up? mines still wont work???
      05-16-2005, 01:37 PM   #42
jiggax23
9
Drives: e90
nope, not standard in neither... its an option alone, and its standard w/ the premium package option
      05-16-2005, 01:39 PM   #43
Amil
Drives: e90 3.0i
my s700i works fine ...but i wish there was a CRadel
      05-18-2005, 12:47 AM   #44
Ewrek
Ewrek's Avatar
58
Drives: 2006 330i
From my understanding, you get a base plate that costs $130. From there you have to get the snap-in adapter for the specific phone you have ranging from $100-$145. This system allows you to charge your phone while utilizing the e90s dorsal fin to get better reception. Currently, these are the available snap-in adapters for BMW (don't know if they will carry over to the e90):
-Motorolla V710
-Nokia 6310, 6310i
-Siemens S55
-Sony Ericsson T39
-Sony Ericsson T68i
-Sony Ericsson T610, T616, T630, T637
-Motorola V505, V551, V525, V600, V620, V635
