TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X6 Forums > X6 Engine / Exhaust / Drivetrain Modification
      01-21-2023, 03:57 AM   #111
x800pro6
ZEE DEE
Australia
15
Drives: 335i
Does anyone recommend when installing manifold to remove alternator to remove heat shielding? Or just bend the heat shielding up? Thank you
      01-21-2023, 05:42 PM   #112
x800pro6
ZEE DEE
Australia
15
Drives: 335i
Tips and tricks for anyone else pursuing the same project.
1. Intercoolers (charge air coolers) must be removed to remove alternator so that heat shielding can be removed however you can do it without draining the water.
2. You can reuse manifold exhaust header gaskets and turbo train gasket however you must spray them with copper spray first to refurbish them. Works like a dream.
      01-24-2023, 03:45 AM   #113
x800pro6
ZEE DEE
Australia
15
Drives: 335i
Originally Posted by RichardH View Post
So turbos and manifolds are in.
Mostly direct fit
Oil feeds perfect fit
Oil return perfect fit
Coolant feed abit of modifications
Also turbo intake fits but the mounting blt needs to modified.
Spool up is incredible!!
Dump valve needs to dump into the atmosphere M5 turbos dont have opening for them
JB4 not working correctly
Now to custom tune
Throttle feels alot lighter
Exhaust note alot deeper
Do you have any pictures of how you modified the m5 inlets ? As they interfere with the oil line . Regards
      01-25-2023, 05:59 AM   #114
x800pro6
ZEE DEE
Australia
15
Drives: 335i
Just heads up. You are also going to have to swap the oil filler neck as almost impossible to fit air intake on M5 inlets. Interference with the huge long filler neck of x6M
      01-26-2023, 05:26 AM   #115
x800pro6
ZEE DEE
Australia
15
Drives: 335i
Installed oil filler neck from an n63 or m5. Now intakes fit proper..here is also some pics of my crankcase evac pump. That plums into my exhaust venturi the smog pump I have converted with a brushless motor with speed control. The exhaust venturi also helps create some vacuum. I chose a vortex style impeller for evac pump. When taking apart the manifold and turbos was amazing how free of oil coak my exhaust valves and intakes were. Even the inside on my downpipes were clean inside. No soot or anything. No oil in intercoolers either. Also because of the smog pump injecting some fresh air into exhaust after the downpipes. I literally have zero bad smells despite me having no catts. As the oxygen oxidises some of the unburnt fuel.
      03-28-2023, 07:31 AM   #116
GIRO
Drives: BMW 3
2. You can reuse manifold exhaust header gaskets if they are still okay https://epicvin.com/license-plate-lookup/texas and turbo train gasket however you must spray them with copper spray first to refurbish them. Works like a dream.
The first one was useful, thanks!
      07-17-2023, 06:45 PM   #117
jdrex
Drives: 2011 BMW X6
Any part numbers on those custom intakes?
where can I find those parts?
      08-06-2023, 01:26 PM   #118
TTV8M
TTV8M's Avatar
124
Drives: '23 AMG GLE53, '10 X6M
2023 AMG GLE53  [0.00]
2010 BMW X6M  [0.00]
2008 Mini Cooper S  [0.00]
love it.
Originally Posted by greddy91 View Post
Insert dick comment about using search, but really I'm just too lazy to also do that and link you.
'10 X6M
'08 Cooper S
      08-08-2023, 03:31 AM   #119
SveinnH
Luxembourg
Drives: E70 X5M
M5 Headers modification (not swap)
Hi guys,
One of the things that bother me the most about the S63 motor is the 2x4cyl soundtrack. I aim to change this as an experiment.
People have thrown the earth and the moon money wise towards these things and in my personal opinion the sound only gets louder, and playing a bad song at volume 11 doesn't really make it any better.
The real reason why we don't get the V8 rumble like the N63 has (and any other hot-V out there) is that some genius at BMW-M decided to extract the very last milliseconds of spool from the motor by crossflowing the exhaust banks.
Cyl 1 & 4 cross over to 6 & 7 and 5-8 cross over to 2-3. This is the same for all S63s, TU and non TU, X5/6, M5/6/8/XM
What I want to do is to separate the two exhaust banks. I bought a second hand X5/6M manifold but cutting that one up is a PITA because of all the heat shielding.
I have acquired a set of M5 manifolds now and will be building a jig and then cutting stuff up. I will post the results later.
Regarding the Turbos I have two options, get a set of M5 turbos and do that mod, or run the X5 turbos I have now, the motor only has 40k miles on it so I don't see the need to change.
However this means the flanges on the M5 manifolds need to be shimmed down.
SO MY QUESTION: Does anyone have detailed info on how much the M5 manifolds need to be turned down on the lathe to make the X5/6 turbos fit the flange.
Remember I am not after more power, just a nicer sound.
      11-22-2023, 03:06 AM   #120
jonhall_128
Drives: BMW X5M E70
Bmw x5m e70 f10 turbo and manifold swap
I have been reading the forums for about 2 years to try and improve the performance at a reasonable cost for my X5M E70. Mods to start, Sprint booster, Catless downpipes, XHP gear box tune and ESS stage 2 Tune.
Finally I decided to push the button on F10 downpipes and turbos. Following the guidelines on this thread.
For everyone's information. The F10 turbos do not fit into the engine compartment and they do require extensive skill to make them fit. The coolant lines, The air intakes etc do not line up. It is not plug and play.
Good news however is there is a workaround to make them plug and play. Simply use the inlet housing on the original turbos and have them precision machined to fit the inlet turbine.
Then they are plug and play. My car looks completely stock no engine bay change. Same inlets same coolant lines and now it has the F10 turbos and manifolds. Sadly ESS do not respond to any emails about this so I have gone with a local tuner who has given me a healthy bump up to 800 engine BHP. I can post pictures and will post actual sound and performance videos at a later stage. All in I am about USD 4,000 with all hardware and tuning.
Also on another note so much has been said about the difference between the turbos. Simply the F10 turbos are bigger. See picture the original housing on the F10 turbo which has been machined to fit. This is the real reason they are better! Name:  IMG-20231121-WA0009.jpg
      03-16-2024, 10:30 PM   #121
TTV8M
TTV8M's Avatar
124
2010 BMW X6M  [0.00]
Thanks for the info and pics
'10 X6M
'08 Cooper S
xbimmers
