Coding performance brakes
03-17-2021, 07:54 PM | #89 |
Rep 420
This evening i have coded my e92 335i with +spbr.
Add vo and coding CAS, FRM & DSC with ncs expert I will told you my sensation... I told you for remember my setup brake. Rbf600 All Aviation bfgoodridge Front M4 caliper brembo 4 pistons disk brembo 370mm and ferodo ds2500 Rear stock caliper disk brembo and ferodo ds2500 |
03-18-2021, 04:20 AM | #90 |
Rep 420
Soit $102A freinage renforcé
Soit $ZP1A Système de freinage BMW Performance Après une réflexion plus approfondie, les ref du DSC 135i et 335i sont les mêmes, ce qui signifie que, si le freinage performance était disponible en accessoire sur 135i il est "codable" sur 335i, mais, ne faudrait-il pas plutôt ajouter $ZP1A ?
335i Pack M Stage 2 BR Performance 403,5 hp 582n.m/Bilstein B14 pss/R&B PVC2 valve/K&N air filter/Spearco FMIC/pre cata empty/EBC Redstuff,aviation hose, BMW Performance exhaust, Charge pipe Evolution Racewerks, Forge DVs
03-20-2021, 07:38 AM | #91 |
24
Rep 144
Hello,
I am currently installing Brembo GT6 calipers on the front and GT4 calipers on the rear of my 335i. Using original discs. I haven't installed yet but is coding required? I will most likely install M3 master cylinder to match larger pistons. |
03-20-2021, 11:29 AM | #92 |
Rep 1,815
There is no coding for the 335i
2009 118i Monaco Blue "Maximillion"
2009 335i Saphire Black M Sport "Leopold" Cobb stage 2 aggressive tune, Mishimoto FMIC, Cobb charge pipe, Cobb catted down pipes, Forge diverter valves, BMS inlets and DCI, Cyba scoops and M Individual Audio retrofit and M3 gauge cluster retrofit. 2011 328i Titan Silver M Sport "Franzel" <--Wife's car |
03-21-2021, 01:25 PM | #95 |
Rep 1,815
Just normal bleeding. I have only done pressure bleeding.
06-27-2021, 03:10 AM | #96 | |
Rep 15
You only have to replace the master cylinder when you install M3 brakes, as the have bigger piston surface |
06-27-2021, 09:38 AM | #97 | ||
Rep 1,486
06-27-2021, 02:57 PM | #98 |
Rep 4,202
Drives: '11 335is | '16 Macan Turbo
I did F30 rears and swapped M3 mc, no coding.
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete |
06-27-2021, 03:21 PM | #99 | ||
Sua Sponte
1299
Rep 2,850
Drives: 2013 LMB 335is
What I do know, as someone that did this retrofit to my E92 335is four or five years ago, adding the E92 M3 MC does make a difference.
335is/DCT-M3 GTS software-M3 drivetrain-M3 GWS-KOMBI-DSC-SZL/MHD/BQ Tuning IG@ClustersandCoding
06-27-2021, 04:46 PM | #100 |
Rep 1,486
06-27-2021, 04:48 PM | #101 | |||
Rep 1,486
06-28-2021, 08:18 AM | #102 |
Sua Sponte
1299
Rep 2,850
09-17-2021, 07:49 AM | #104 |
Rep 15
02-21-2024, 03:44 AM | #106 |
Rep 14
Guys, sorry for bringing this topic back to top.
I am planning to do the 335i brakes swap on my 330i. The only thing is that I really want to code it. My car is EU spec May 2005 - is there possibility there will be no Performance Brakes option in my unit? What option is it? S102A (S100A) because I can not find Performance brake option in here https://www.e90post.com/forums/showthread.php?t=717103 Thanks Last edited by Michal; 02-21-2024 at 09:48 AM.. |
