TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X6 Forums > X6 Engine / Exhaust / Drivetrain Modification
      11-09-2020, 03:31 PM   #1
TTV8M
TTV8M's Avatar
124
Drives: '23 AMG GLE53, '10 X6M
2023 AMG GLE53  [0.00]
2010 BMW X6M  [0.00]
2008 Mini Cooper S  [0.00]
2011 s63 oil pump chain excessive play
So in the process of tearing down this 2011 s63 motor, dropped the oil pan and it feels like too much play on the oil pump chain.
is there a tensioner for this, or could this chain have also stretched?
i hear others mentioning the timing chain likes to stretch on the N63/S63s
'10 X6M
'08 Cooper S
      11-10-2020, 11:11 PM   #2
BigHunk
///M
BigHunk's Avatar
270
Drives: X5M , iX , S1000XR
There is revised-updated oil pump for S63.
Mine was updated couple years ago under warranty.
https://www.xbimmers.com/forums/show...php?p=26524850
not rich enough to buy cheap
TTV8M123.50
      11-11-2020, 11:21 AM   #3
TTV8M
TTV8M's Avatar
124
2010 BMW X6M  [0.00]
Thanks, I will have to order a replacement.
Also, I found the tensioner for the oil chain.
Attachment 2458390
'10 X6M
'08 Cooper S
      11-26-2020, 08:24 AM   #4
Dawgz
2022 M4 Comp Xdrive
1016
Drives: 2022 M4 Comp Xdrive
How many miles is yours?
      12-06-2020, 02:28 PM   #5
TwinSnailz
TwinSnailz's Avatar
75
Drives: 2011 X5//M
Before its too late, your s63 is NOT a tu. It does not have a physical tensioner. It uses bolt/spacer to extend the pump and chain. 10mm chain slack from side to side.
Appreciate 3
      12-16-2020, 08:21 PM   #6
m5james
m5james's Avatar
Drives: '10 X5M Alpine White on Sakhir
How did you get this done under a warranty? I've got 140k on mine currently and BMW's website doesn't show any open recalls and we got screwed out of the N63 Customer Care Package even though we share the same chain setup.
'10 BMW X5///M - Alpine White on Sakhir Orange - JB4 w/ HCP Stage 2 BEF, NGK 97506 @ .20, SS tubing & BMC filters, gutted cats, AC Forged 312 22's, H&R 2"
'98 BMW 740iL - ///E39 M5 6spd swap, fully built engine (sleeved, P&P, cams), 3.46 LSD, H&R Stage 2/Bilstein HD, Magnaflow 14816's
'97 BMW 328ci - ///E36 M3 clutch & L/W flywheel, Z4///M 18's
      12-18-2020, 12:14 AM   #7
BigHunk
///M
BigHunk's Avatar
270
It's not a recall, had an extended warranty. It was suggestion from shop foreman, they were dropping pan because of sweaty pan gasket, covered by Bmw Canada.
I would guess they are aware of oil pump problem on numerous engines.
Btw that was 2 years ago.
      03-29-2021, 11:48 PM   #8
TTV8M
TTV8M's Avatar
124
2010 BMW X6M  [0.00]
100,000 miles
      03-29-2021, 11:49 PM   #9
TTV8M
TTV8M's Avatar
124
2010 BMW X6M  [0.00]
Nice catch on the TU. Thanks. Still inspecting everything on the tear down. I have some scratches on the cylinder walls. Considering sleeving the block
      04-07-2021, 04:38 PM   #10
iansanderson
Drives: 2013 X5M
Came here to say thank you for the info. Just bought a ‘13 X5M with 90K mi. Upper pan was leaking so I decided to get it out of the way, but kept going back and forth on replacing the oil pump with the updated unit. I’m glad I did. The engine had some noise at idle and now that the new pump is in and chain properly tensioned, the noise is completely gone. I’m just left with the sweet sound of high pressure injectors ticking away. I borrowed the special tools from a friend and measured the chain installed. It was a tad loose but nothing major. The old pump was mounted tight to the engine thankfully. Now that the idle is quiet, i’m fairly certain the oil pump was failing which may explain the catastrophic failures and updated part from BMW. I would definitely consider the oil pump normal maintenance on the S63 after replacing it.
Pics of the revised oil pump below:
TTV8M123.50
      07-07-2021, 06:21 PM   #11
Gocar
Drives: BMW E92 328i LCI
I have the same issue with my 2013 750li alpina b7l. The oil pump chain is loose and just 3 bolt can hold the chain sprocket. There is no chance to tighten it. I will close the lower pan if I have an issue, I may need to upgrade it. If there is an upgrade I can do it soon as well.
      08-03-2021, 10:13 PM   #12
Sophisticated Redneck
Drives: 2012 BMW X5 50i
Just posted this thread on how to tighten:
https://f15.bimmerpost.com/forums/sh....php?t=1847303
m5james431.00
TTV8M123.50
      08-03-2021, 10:28 PM   #13
m5james
m5james's Avatar
Safe to assume that writeup and video isn't N63 specific? I feel like I'm on eggshells driving my '10 X5M with 144k...a hard driven 144k at that.
TTV8M123.50
      08-04-2021, 08:03 AM   #14
Dawgz
2022 M4 Comp Xdrive
1016
Should be all the same at that area.
      08-04-2021, 06:06 PM   #15
Like Dawgz mentioned, they are all identical. I verified by looking up all the different platforms and engines in ISTA, instructions all identical until you get to the F10 M5, completely different pump and oil pan used there.
If your at 144K and drive it hard, I would not wait and order up all the parts and do it ASAP. Please report back when you do and let us know what you found.
TTV8M123.50
xbimmers
