TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X6 Forums > X6 Engine / Exhaust / Drivetrain Modification
      10-26-2023, 08:02 PM   #45
x800pro6
ZEE DEE
Australia
15
Drives: 335i
Originally Posted by TTV8M View Post
Got some more of the engine assembled. Worked on the heat shielding as previously mentioned from Sophisticated Redneck
Dont mind our messy wrap, first time heat wrapping a spider looking exhaust manifold.
Attachment 3299757
Attachment 3299758
Attachment 3299759
Attachment 3299760
Attachment 3299761
Just be careful oil doesn't get soaked on the wrap. Better to upgrade to m5 manifold and m5 turbos as those manifolds have less heat soak. They are not double walled and have better flow. Just swap 02 sensors. I wrapped my downpipes only.but wrapped in aluminum foil tape also. The glue will burn off when you first start up for a bit. Makes it a bit safer if you accidentally get some oil on the wrap.
TTV8M123.50
      10-26-2023, 08:04 PM   #46
x800pro6
ZEE DEE
Australia
15
Drives: 335i
gonna need some ideas on blocking the intake manifold ports that were for the PCV/EGR. dont want any of that garbage getting fed back in.
I built a brushless vacuum pump that gets plummed into exhaust evac Venturi. I blocked off my intake manifold.
TTV8M123.50
      11-06-2023, 09:58 AM   #47
TTV8M
TTV8M's Avatar
124
Drives: '23 AMG GLE53, '10 X6M
2023 AMG GLE53  [0.00]
2010 BMW X6M  [0.00]
2008 Mini Cooper S  [0.00]
That sounds good. I'll look into it. Thanks
I think I will also consider using the intake port which would normally be for the PCV and try to get a WMI injection in there. But I am reading that it's best to have the WMI injection higher up.....closest to the turbo..... So that the water part of the water meth mixture (50/50) actually gets vaporized.... since we don't want water making it into the engine.
But not too close, since the meth is flammable..... Idk. Tricky things to consider
'10 X6M
'08 Cooper S
      11-06-2023, 10:03 AM   #48
TTV8M
TTV8M's Avatar
124
2010 BMW X6M  [0.00]
Got a few things done the weekend ... Turbos mounted and started the install. Cleaning up those banjo metal lines in the mineral spirits wash. Do these leak? They looked like they had stains on them (not pictured) but probably from the original copper washers going bad. I didn't wanna replace them since the dealer wanted like $100 for each.
I have to find the right size t fittings for the coolant hoses that T off to the turbos. I replaced these $100 hose assemblies but not liking the plastic T fittings. It looks like it's 11mm ID. Brass or stainless?
Gotta love the little Pure logo on the turbo blades.
'10 X6M
'08 Cooper S
      11-18-2023, 10:20 PM   #49
TTV8M
TTV8M's Avatar
124
2010 BMW X6M  [0.00]
Got a bunch more stuff assembled today.... Ran some nice blue silicone vacuum lines.....
I see bmwfans.info was down today, lucky for me I remembered the realoem.com page.
Was working on renewing the air duct manifold which connects from the turbos to the intercoolers, and it seems the rubber hose/boots are not sold separately; even tho there are BMW parts numbers on them. It seems they had a hidden prefix to the part numbers , but I didn't find them after a few minutes of searching. Oh well. Will buy some dooded up stuff from Amazon and see how it works (pop! Is gonna be from the pressure i imagine)
And after cleaning up both intercoolers, one has a hole/ puncture. Prob from either disassembly or was dropped. I'll have to scavenge the one on the dead motor.
And those dam MAP sensor connectors. Such brittle plastic. Broke the driver's side intake manifold and intercooler plastics. Smh. Scavenge those too from the dead motor. More parts on order. Until next week or two. Slow process.......
'10 X6M
'08 Cooper S
      11-20-2023, 02:50 PM   #50
TTV8M
TTV8M's Avatar
124
2010 BMW X6M  [0.00]
The T connectors for the coolant feeds on the turbo i went with was from McMasterCarr:
https://www.mcmaster.com/catalog/129/200/5670K68
1/2"
stainless steel
barbed
temperature rated up to 750F
Cant trust the stock plastic junk. the last ones were all shattered and fell apart on removal.
'10 X6M
'08 Cooper S
      11-21-2023, 07:29 AM   #51
TTV8M
TTV8M's Avatar
124
2010 BMW X6M  [0.00]
I really wish the f10 m5 intercoolers could be swapped in here. Move everything around , cut this and that. I'd have to find some in a junkyard to test fitmet. But doubtful I'd find anything
Edit: I did see a bunch for sale on eBay for around $130. Maybe I'll buy one for experimentation
I'll have to spend more time searching on the forums to see how far others have gotten attempting this
Sounds more of a headache, since they would just look good and who knows what cutting and nonsense would have to get done. I'll still look into it tho. lol. Remove passenger headlight permanently.
'10 X6M
'08 Cooper S
      11-21-2023, 10:33 PM   #52
x800pro6
ZEE DEE
Australia
15
Drives: 335i
Your turbos look really good !!
I managed to find an n63 entire engine (with update block) (bent rods due to hydro lock)
Comes with
8x Injectors index 12.
1x bran new alternator
Set of bran new forged I beam kingteck rods
Set of bran new arp rod bolts.
Wiring harness
Hpfp.
Vannos solanoids
Fuel rails
N63 turbos.
N63 catalytic converters
Entire engine ( with bent rods)
If the block is usable I will sleave it. If not. Well I still got 8x index 12 injectors.
Paid 2400 AUD for the lot.
Found from a guy who didn't complete his project. And sold me the lot.
N63 block is same as s63
TTV8M123.50
      11-21-2023, 10:34 PM   #53
x800pro6
ZEE DEE
Australia
15
Drives: 335i
this engine that I purchased hydrolocked due to leak in air to water intercoolers
TTV8M123.50
      11-21-2023, 10:38 PM   #54
TTV8M
TTV8M's Avatar
124
2010 BMW X6M  [0.00]
Thanks
Wow that's a good deal, all those parts
Let me me know if you have questions
I'll also have some parts for sale, that were off the working donor motor
Like factory pistons, wrist pins, curved rods, etc. Ill probably just list them on eBay and post the links. Seems a bit more reputable than just forum selling posts
'10 X6M
'08 Cooper S
      11-21-2023, 10:44 PM   #55
TTV8M
TTV8M's Avatar
124
2010 BMW X6M  [0.00]
I bet that's what happened to mine. I won't know til probably next year, as I just assumed it was dead and bought a replacement motor. I do recall, checking the intercooler reservoir, that it was empty
'10 X6M
'08 Cooper S
      11-22-2023, 11:44 AM   #56
TTV8M
TTV8M's Avatar
124
2010 BMW X6M  [0.00]
I'm a bit slow on the uptake and searching, but I see the F90 M5 intercoolers / charge air coolers are smaller than the F10 M5 intercoolers. Possibility of working? Theyre so much more expensive on eBay (obv cause newer and less wrecked ones around).
reason for all this? My stock intercooler on the drivers side has a hole in it and I don't wanna ghetto alumalloy it as I don't know if the fins inside are also damaged. So need a replacement. Ill probably just use the one on the motor that's toast.
Did anyone size it up or was it totally not worth it besides the aesthetics looking good/different and then negatives of the unknowns and custom hoses/routing?
'10 X6M
'08 Cooper S
      01-22-2024, 10:08 PM   #57
TTV8M
TTV8M's Avatar
124
2010 BMW X6M  [0.00]
Motor is fully assembled, just havent had time to get the x6m on the lift to start the teardown. Hopefully in the next few months
'10 X6M
'08 Cooper S
      03-16-2024, 10:28 PM   #58
TTV8M
TTV8M's Avatar
124
2010 BMW X6M  [0.00]
Finally had some time to work on the x6m tonight, I had replaced the rear trunk shocks a while ago but never ran the new wires. Wow what a PITA that was. So many body panels had to come out and luckily I already had the truck gutted from the mice problem I had.
Don't ever break your trunk shocks or force the truck open/close, it's a real nightmare
Now I have to deal with all the mice pee and droppings in the headliner. They had a 3 bedroom penthouse up there.
And that headliner replacement is a small fortune, something like $1300?
Smh
'10 X6M
'08 Cooper S
xbimmers
