inpa/ncs expert not working
12-21-2019, 01:02 PM | #1 |
Rep 9
i just had them working got my zb number from inpa now if i try to get the user info i get nothing.
now when i open inpa i have 2 balck dots but othing else is working anymore ncsexpert is giving me a vin faulty error too ncs expert vin is faulty coapi-2000 i got my zb number dismorning from my old ekp module took a screenshot put the new ekp module in an i couldnt get any info from the car but got 2 black dots any help would be appreciated thank you error log [14:13:18.945] [2019-12-21] [SERIE] 2000 Error LFCDHDIA.CPP (A_PL2FRX.IPS/IPO) CDHapiResultText 1 [14:13:18.945] [2019-12-21] [SERIE] Fehler in EDIABAS oder in SG-Beschreibungsdatei IFH-0018: Initialisierungsfehler des Interface-Handlers FRM_87 [14:13:18.947] [2019-12-21] [SERIE] 2000 Error COAPI2.CPP coapiRunCabd 6 [14:13:18.947] [2019-12-21] [SERIE] Fehler in EDIABAS oder in SG-Beschreibungsdatei FA_READ [14:13:18.949] [2019-12-21] [SERIE] 2000 Error COAPI4.CPP coapiReadAuftrag 4 [14:13:18.949] [2019-12-21] [SERIE] Fehler in EDIABAS oder in SG-Beschreibungsdatei FA_READ: A_PL2FRX [14:13:18.955] [2019-12-21] [SERIE] 2000 Error LFCDHDIA.CPP (A_PL2FRX.IPS/IPO) CDHapiResultText 1 [14:13:18.955] [2019-12-21] [SERIE] Fehler in EDIABAS oder in SG-Beschreibungsdatei IFH-0018: Initialisierungsfehler des Interface-Handlers FRM_87 [14:13:18.958] [2019-12-21] [SERIE] 2000 Error COAPI2.CPP coapiRunCabd 6 [14:13:18.958] [2019-12-21] [SERIE] Fehler in EDIABAS oder in SG-Beschreibungsdatei FA_READ [14:13:18.959] [2019-12-21] [SERIE] 2000 Error COAPI4.CPP coapiReadAuftrag 4 [14:13:18.959] [2019-12-21] [SERIE] Fehler in EDIABAS oder in SG-Beschreibungsdatei FA_READ: A_PL2FRX [14:13:18.997] [2019-12-21] [SERIE] 2000 Error LFCDHDIA.CPP (A_E65CAS.IPS/IPO) CDHapiResultText 1 [14:13:18.997] [2019-12-21] [SERIE] Fehler in EDIABAS oder in SG-Beschreibungsdatei IFH-0018: Initialisierungsfehler des Interface-Handlers CAS [14:13:18.999] [2019-12-21] [SERIE] 2000 Error COAPI2.CPP coapiRunCabd 6 [14:13:18.999] [2019-12-21] [SERIE] Fehler in EDIABAS oder in SG-Beschreibungsdatei FA_READ [14:13:19.001] [2019-12-21] [SERIE] 2000 Error COAPI4.CPP coapiReadAuftrag 4 [14:13:19.001] [2019-12-21] [SERIE] Fehler in EDIABAS oder in SG-Beschreibungsdatei FA_READ: A_E65CAS [14:13:19.003] [2019-12-21] [SERIE] 1000 Warning COAPI.CPP coapiReadFgNr 9 [14:13:19.003] [2019-12-21] [SERIE] Fehler CAS ================================================== ==============================(2) [14:13:19.011] [2019-12-21] [SERIE] 2000 Error LFCDHDIA.CPP (A_E65CAS.IPS/IPO) CDHapiResultText 1 [14:13:19.011] [2019-12-21] [SERIE] Fehler in EDIABAS oder in SG-Beschreibungsdatei IFH-0018: Initialisierungsfehler des Interface-Handlers CAS [14:13:19.013] [2019-12-21] [SERIE] 2000 Error COAPI2.CPP coapiRunCabd 6 [14:13:19.013] [2019-12-21] [SERIE] Fehler in EDIABAS oder in SG-Beschreibungsdatei FGNR_LESEN [14:13:19.015] [2019-12-21] [SERIE] 2000 Error COAPI.CPP coapiReadFgNr 12 [14:13:19.015] [2019-12-21] [SERIE] Fehler in EDIABAS oder in SG-Beschreibungsdatei FGNR_LESEN: A_E65CAS https://prnt.sc/qe3afs Last edited by jwm614; 12-23-2019 at 09:09 AM.. |
12-21-2019, 01:37 PM | #2 |
Rep 13,122
whose download did you use.
It's recommended you use the Bimmergeeks.net download since we know it works and the steps it takes to get it up and going. |
12-21-2019, 02:44 PM | #4 | |
Rep 9
it was working fine dismorning but now it dosent |
12-21-2019, 02:45 PM | #5 |
Rep 9
12-21-2019, 03:00 PM | #6 |
Rep 780
Can you do anything in inpa? When you see vin is faulty error it's a communication problem not a software problem. If you have a switch on the cable make sure it's pinned correctly. Could be faulty cable now. Go into ediabas.ini and make sure it says com port 1
12-21-2019, 04:25 PM | #7 | |
Rep 9
cant do anything in inpa but see too black dots its not my cable it works on my other laptop but the screen is broke so its a pain |
12-21-2019, 04:32 PM | #8 | ||
Rep 780
12-21-2019, 04:40 PM | #9 | |
Rep 9
yea cable is 100% working i dont have standard tools in my programs i have bmw coding database version 1.3.4 ediabas 7.3.0 mike's easy bmw tools i have to wait 4 hours to download it an ill try standard tools |
12-21-2019, 06:45 PM | #10 | ||
Rep 780
12-21-2019, 07:10 PM | #11 | |
Rep 4,082
1) What happens when you open INPA with NO cable connected to USB port? 2) If you get "BMW INPA" screen (as you should) press Function Key for E90 (F6 in Mike's?) key varies depending upon source of your program; 3) Do you now get Script Selection Box, and can you navigate Functional Jobs, and ALL Modules? Open NCS Dummy, and see if you can see Options for a specific module such as CAS. If it was properly setup, you should see "Chassis: E89..." Same idea -- you should have some functionality even NOT connected to Cable or OBD II Socket. If NEITHER is now working, but BOTH did before today, make sure you simply try re-booting/ Restarting your computer. Think about anything that was added or deleted on the C Drive since it last worked. If it does NOT work as described above, then likely your installation has become corrupted in some fashion. Check to see that you have "EC-APPS" folder in your Root/C: Drive and that it contains "INPA" and "NCS" folders. Check/report SIZE of each of those two folders. George |
12-22-2019, 02:47 AM | #12 | |
Rep 9
12-23-2019, 09:09 AM | #13 |
Rep 9
