BMW M3 Forum (E90 E92)
Mporium BMW
      09-13-2018, 11:08 AM   #67
drrust
drrust's Avatar
336
Drives: E90 M3 DCT Sedan
Originally Posted by RC Post View Post
I've been having this bouncing idle and stalls out only on morning cold starts and no other time thru out the day.. No codes.
Should I give this a go?
The part isn't that expensive, it's a matter of if intermittent stalling bothers you enough to try and replace this part.
      10-04-2018, 01:57 PM   #68
RC Post
68
Drives: E90 M3 6MT
Just replaced breather valve. All information needed is in this thread. Everything went well only part that took the longest was removing the hose off the valve itself which took some effort to pull off but eventually came off.
BUT morning cold start rough idle/bog/stall still persist . AGAIN I'm only experiencing it only in the morning. What else to look for?
      10-04-2018, 02:14 PM   #69
MPower7
MPower7's Avatar
90
Drives: 11' e92 M3
Idle control device?
      11-08-2018, 11:15 AM   #70
mtx450
mtx450's Avatar
Drives: 2011 E90 M3 ZCP
2011 BMW M3  [0.00]
Originally Posted by derekc5475 View Post
Does anyone know if there are any negative side effects to the car if you have this problem and don't replace the valve? As far as I know, it's only the bouncing RPMs for a minute or so after you fill up gas. Can it do some potential damage?
From what I gather, the valve gets stuck open which is what causes all of these issues. I don't think you'd have any issues with flooding the charcoal canister.
      03-28-2019, 08:43 AM   #71
alefcole
26
Drives: 2011 ZCP 6MT Jet black E92
Ty
      05-31-2019, 08:01 PM   #72
JDAURIA
JDAURIA's Avatar
725
Drives: F31 MSport
2005 BMW  [0.00]
2016 BMW  [0.00]
In the process of doing this, I broke the nipple off the old fuel tank breather unit...Thought I could get the piece out with pliers but to no avail. Have to order an entire new pipe.
2016 F31 328iX | Alpine White | Black | ///MSport | iND | Eventuri | AC Schnitzer | MPerformance | 513M | Michelin PS4 |
2005 | 330CiC | Sparkling Graphite | Black | 6MT | ZHP
Purchase your W///AGON Stickers Here: https://f30.bimmerpost.com/forums/sh....php?t=1930190
wfdeacon881105.00
DrFerry6728.50
      06-01-2019, 08:03 AM   #73
EJT86
EJT86's Avatar
Drives: 2018 M2
  [0.00]
2018 BMW M2  [0.00]
You could try an easy out
      06-01-2019, 08:21 AM   #74
JDAURIA
JDAURIA's Avatar
725
Drives: F31 MSport
2005 BMW  [0.00]
2016 BMW  [0.00]
Not sure how, I tried using needlenose pliers to get it out. It's really in there. 100k mile and never been replaced
DrFerry6728.50
      06-01-2019, 09:05 AM   #75
EJT86
EJT86's Avatar
Drives: 2018 M2
  [0.00]
2018 BMW M2  [0.00]
An “easy out” is a reverse threaded bit used for when a screw is stripped. Screw the easy out into the broken plastic and twist it free and pull it out little by little
      06-01-2019, 12:05 PM   #76
drrust
drrust's Avatar
336
DIY: Replace Fuel Tank Breather Valve (Fix for bouncing idle at fuel station)
A couple suggestions on how to get the nipple out. I suspect that if you look up how much the pipe costs you will put significant effort into getting the old one out.
First hopefully the pipe is fully disconnected/ out of the car. If not follow it to the connection on the shock tower. Once out, it will be much easier to work on.
The locking mechanism can be seen. You maybe able to pick them loose as shown here:
At about 9:50 he (not me) pulls out the hose and disconnects the valve. In your case you may want to try and screw a wood screw into the broken plastic to have something to hold/pull on. Also you may have a better view of the the teeth holding the piece in.
If that doesn't work I would try to cut the inside of the tube and try breaking it out with your needle nose pliers. You may need some specialized xacto blades or a very narrow saw blade (scroll or coping saw).
Good Luck!
DrFerry6728.50
      06-01-2019, 12:15 PM   #77
EJT86
EJT86's Avatar
Drives: 2018 M2
  [0.00]
2018 BMW M2  [0.00]
Good Luck!
I believe he is talking about the small hose in the front that’s hose clamped onto the breather. The nipple of the breather broke off inside the little hose
      06-01-2019, 12:40 PM   #78
drrust
drrust's Avatar
336
My experience was the back connection was the difficult one. Need OP's response.
      06-01-2019, 02:14 PM   #79
EJT86
EJT86's Avatar
Drives: 2018 M2
  [0.00]
2018 BMW M2  [0.00]
Mine too, it was late and dark so I just broke it, but when he said “broke the nipple off...” it sounded like he meant the front since I wouldn’t consider the back a “nipple”
      06-01-2019, 06:09 PM   #80
JDAURIA
JDAURIA's Avatar
725
Drives: F31 MSport
2005 BMW  [0.00]
2016 BMW  [0.00]
back connection, nipple broke and is stuck inside the hose. I already bought a new hose.
DrFerry6728.50
      08-10-2019, 02:57 PM   #81
MyUnicorn
62
Drives: 2011 E90 M3 SSII
This diy was awesome. Thank you. I found that using a 6 mm socket on an extension was much easier than using a screwdriver to tighten the clamps for the plenum. Getting the valve off was a pain in the ass.
2011 E90 Silverstone II / Fox Red/Black ZCP Manufacture Date 10/28/2011
      09-11-2019, 08:59 AM   #82
roninCoder
Drives: '89 BMW 325is '11 BMW M3
FWIW, I struggled with removing the hose from valve. I finally solved the problem by using a angled pick tool, inserting it into the end of the hose then working it around the nipple to loosen the hose.
DrFerry6728.50
      09-11-2019, 03:42 PM   #83
CHE///MIST3
CHE///MIST3's Avatar
Drives: E92 M3 6MT Space/Black
2009 BMW M3  [0.00]
2007 BMW 328i  [0.00]
Lol, every single connector, hose/tube, on this car needs to be taken apart..... and put back together so that when it's time to perform a DIY it takes half the time.
Seriously the MOST sore finger tips in the world the morning after working in the engine bay from a newly acquired BMW.
GM
      05-02-2020, 11:36 AM   #84
ThatM3guy
Drives: 2011 M3
just tackled this job this weekend with the help of this DIY and it was great. thanks for the detailed contribution.
that rear clip that everyone is talking about.... i took the front tube off, then i removed the actual valve from it's mount, and i was able to rotate it to get a better grip of the clip. Then, PUSH IN towards the valve, and press the clip, and mine came right off. I did this repair along with Throttle actuators. Getting the plenum to sit in the back was difficult. I asked a Indy shop friend who recommended wiping some silicon lubricant on the surface, and that helped.
Thanks for the great write up!
DrFerry6728.50
      05-03-2020, 03:17 AM   #85
Route 16
I got lei'd
Route 16's Avatar
Philippines
844
Drives: '10 E90 M3
silicon lubricant...ky jelly?
      08-23-2020, 02:30 PM   #86
PACarGuy
PACarGuy's Avatar
Drives: 2012 E92 M3 DCT ZCP
Followed the DIY guide today to do this replacement, but should have read further down in the comments on removing the rear hose from the valve, because my hose collar cracked and the old valve nipple broke off inside the hose as I was trying to remove it. I managed to remove the broken nipple by prying apart the connector and using some needlenose, and can reinstall the hose on the new valve, but the pinch collar no longer clamps the same way. The hose is reasonably snug and doesn't fall off per se, but I can pull it off the valve with a good tug. Should I just go ahead and replace the fuel breather hose, or will it be OK? I can't really see a scenario where it just slides off, but is there high pressure on it?
2012 E92 M3 | ZCP | DCT | Space Grey Metallic | Black Novillo | BE/ARP | MPE V2 | AA green filter |BMW CF Rear Spoiler, RW Carbon Diffuser, CF Front Splitters | DTEC 160W Angel Eyes
DrFerry6728.50
      08-23-2020, 07:52 PM   #87
EJT86
EJT86's Avatar
Drives: 2018 M2
  [0.00]
2018 BMW M2  [0.00]
Use zip ties to hold it in place then decide if you want to spend the cash on another hose. Same thing happened to me and I used two spare hose clamps because it was cold and dark when I had finished. I planned on buying a new hose but I got lazy
PACarGuy683.50
DrFerry6728.50
      08-23-2020, 07:57 PM   #88
PACarGuy
PACarGuy's Avatar
Doh! I was trying to think of a way to secure it but no idea why a zip tie didn't come to mind lol.
I'll call around tomorrow morning to see how quickly I can get a replacement hose and if I can't get one quickly I'll try the zip tie...or hose clamp.
Thanks!
m3post
