BMW M3 Forum (E90 E92)
BPM
      10-09-2016, 10:17 PM   #1
ThatWhiteM3
33
Drives: 2008 BMW M3 E92
Oil filter housing removal DIY?
Hello everyone. Finally took sometime to try to find the engine leak. From using fiber optic camera and some observation seems like the oil filter housing has a leak from underneath. Most likely its a gasket.
Is there any DIY on how to remove it and replace an oil filter housing gasket?
Please help
      10-27-2016, 09:52 PM   #2
cmtemauricio
cmtemauricio's Avatar
Drives: 2014 F13 M6 COMP PACK DCT
Please help
I had the same problem about a year ago and finally got it done. I took some pictures so let me see if I can find it and I'll post them here.
I remember having to remove a lot of things out of the way to get to it.
Remove fan, intake box, coolant hoses, reservoir, water pump, all belts, power steering pump (just the main bracket then move to the Side).
On the housing itself, one of the bolts is in a very tight space between the block and the crankshaft balancing rubber disk.
It's a $10 gasket but a ton of work to get to it so you might as well replace all belts, water pump gasket, thermostat. Or at least inspect the water pump since it will be out.
Mauricio Cardoso
ha998193.50
      10-27-2016, 09:57 PM   #3
cmtemauricio
Found the pictures, one of them you can see the gasket stuck to the block after I removed the oil filter housing.[IMG][/IMG]
Mauricio Cardoso
Chigurh30.50
      10-30-2016, 03:24 AM   #4
ThatWhiteM3
33
Thank you so much. I heard by manual u have to remove harmonic balancer damper but seems like you didnt do it so u just saved me lots of time. I will go ahead and start on it Friday! Thank you again!!!!
      03-18-2017, 10:40 AM   #5
bond_007
Drives: 2008 E90 M3
cmtemauricio seems to have had less trouble getting it done than ThatWhiteM3:
http://www.m3post.com/forums/showthr...7#post21428167
The above pictures and the recipe on TIS/AllData look really straightforward to me (aside from having to remove the harmonic balancer).
I asked some of the local shops what they would charge to do the job so that I don't have to deal with it (I can see the oil seeping from the metal-metal joint).
I was told about 3 hours by one independent shop (says that this is a rare failure item that they have not seen on this engine and didn't have a book time for it).
The other independent shop says it is a pain in the tail and needs 8 hours to do the job.
I guess I need to call one ore two more to get a consensus. It's not worth doing it myself if it is more like 8 hours but I could probably handle 3 hours.
2008 E90 M3 Jerez Black
2007 Mini Cooper S (The Radio-Active Concert Hall)
1993 RX-7 (self fabricated parts/far from stock)
1990 MX-5 turbo (self fabricated parts/far from stock)
      01-19-2020, 10:47 AM   #6
aakrusen
To Punish and Enslave
aakrusen's Avatar
33
Drives: with both hands on the wheel
2008 M3 E92  [9.00]
Did you use a custom T30 Torx bit or tool to get that one bolt out that is behind the crank shaft balancer? Or atleast, how did you get that one bolt out?
SAMM3Y3085.00
      01-19-2020, 10:55 AM   #7
pbonsalb
Drives: 18 F90 M5, 99 E36 M3 Turbo
I have not done the job yet. Would something like this work?
https://www.homedepot.com/p/GearWren...E&gclsrc=aw.ds
      01-19-2020, 11:09 AM   #8
aakrusen
aakrusen's Avatar
33
2008 M3 E92  [9.00]
There's about 13/16" between the head of that bolt and the balancer. Most of those torx bits are about 1" long. I could cut one down, but using that tool kit means that special wrench has to fit, and there's no specs on the dimensions sizes.
      01-19-2020, 01:55 PM   #9
aakrusen
aakrusen's Avatar
33
2008 M3 E92  [9.00]
Figured it out. Took the T30 torch bit, cut down to about 1/2” long, then taped it in the end of a 1/4” wrench. Broke the bolt loose and everyone is happy!!
      01-19-2020, 05:43 PM   #10
Johal E32
Drives: 91 M5, 98 M3, 08 M3
1991 BMW M5  [0.00]
1998 BMW M3  [0.00]
2008 BMW M3  [0.00]
Smart!
I ended up removing the harmonic balancer and replacing all of the bolts as I could not get my T30 to fit.
SalimM327.00
      01-20-2020, 01:54 PM   #11
SonnyJack
Drives: '09 E92 M3/'18 F83 M4
Sorry I'm just now seeing this. That's exactly what I had to do almost exactly a year ago. Grind that sucker down and then used a vise grip to hold it in place and it came out. For some reason putting it back in proved more difficult.
Great job!
AA Gen 2 Lvl 2 w/Meth; MagnaFlow catless x-pipe; Dinan Underdrive Pulley; VAC Coated Bearings; ARP Rod Bolts; Oil Diverter Valve; Dinan Strut Braces; Dinan Rear Toe Links; ECS Rear Trailing Arms; MCS 2-Way NR w/700F-1000R; GC Camber Plates; AKG 75D MM & 95A TM; CAE Shifter; Titan T-S5; StopTech ST60 380mm/ST40 355mm; MFactory DS; Zebulon Splitter; Zebulon 330 Rear Wing; Gutted w/Piper Motorsports Custom Cage; OMP WRC-R Seats
      01-20-2020, 02:08 PM   #12
aakrusen
aakrusen's Avatar
33
2008 M3 E92  [9.00]
Put it back together this morning. Used that same box-end wrench with the cut down torx bit taped in the end, took my time and she's tight!
      01-29-2020, 09:14 AM   #13
cmtemauricio
Sorry guys I haven't been keeping up with the forum as I moved on to an F13 M6.
Now I remember inserting a short bit and then clamping down on it with pressure pliers to turn that bolt. That's all I had at that time that would fit in that space. As soon as you break it loose then you can take it out by hand.
Hope this helps
Mauricio Cardoso
      01-29-2020, 07:49 PM   #14
bmwpower603
Drives: E36 m3 coupe 08 e90 M3
I am about to do this job.
I cut a torx 30 bit in half. And will use the 1/4 to break it loose.
My question is. Are all the bolts torx 30? Some seem bigger from the bmw instructions that I read.
      01-29-2020, 08:52 PM   #15
aakrusen
aakrusen's Avatar
33
2008 M3 E92  [9.00]
I don’t recall the sizes, but there were two different Torx bits I used. Also, you only have to use that cut but on one bolt, the rest you will be able to get to.
I traced the gasket onto a piece of cardboard so I could put each fastener in the relative location from where I removed it. This is because of the two different torx head bolts and different lengths of bolts. I believe there were nine total bolts.
      01-30-2020, 12:55 AM   #16
msan
Drives: 2011 E90 M3 / 2012 X5 35i M Sp
Can you post a pic of the tire bit and wrench set up?
      01-30-2020, 08:00 AM   #17
aakrusen
aakrusen's Avatar
33
2008 M3 E92  [9.00]
You can see that the overall length is about 5/8", and there's only about 3/4" space between the head of the bolt and the back of the crank shaft balancer. Once you break it loose, you can unthread it with you fingers. The bolt won't come all the way out of the hole in the oil cooler housing, but it will be completely unthreaded from the block. When putting the oil cooler housing back in, make sure you do this bolt first.
edit: fixed the pic links.
msan402.50
Chigurh30.50
      01-30-2020, 11:22 AM   #18
bmwpower603
Thanks for the pics.
Did you suck any oil out of the housing? Or drain oil before doing this?
How big was the mess? Can I avoid it by putting a big towel under it?
      01-30-2020, 12:21 PM   #19
aakrusen
aakrusen's Avatar
33
2008 M3 E92  [9.00]
I did not drain the oil as all the oil you would drain from the motor is already sitting in the pan. There is a little oil in the housing and some in the oil cooler lines. I put an oil drain basin under the motor below the this part of the block when I removed the cooler, but it wasn’t much. When it was all done, the ECU didn’t even show a drop in oil level, that’s how little you will lose.
Be mindful of the oil in the cooler lines, just keep them up in the air after removal from the housing.
When pulling the housing, the gasket may stick to the block, this is fine, just peel it off and thoroughly clean the surface. The new gasket will fit in the grooves of the housing, no need for RTV, it will stay in place.
msan402.50
      01-30-2020, 03:28 PM   #20
msan
Here's a pic from TIS. Shows there are different sized Torx screws
      01-30-2020, 03:59 PM   #21
bmwpower603
What this also shows is that the WP doesn’t need to be removed. Just the WP pulley needs to be removed. (Less mess)
      06-14-2020, 11:51 PM   #22
aerospacey
aerospacey's Avatar
Drives: 2008 BMW E90 M3
Hey guys,, thanks for the pics and high level. This job wasn't too bad, but I accidentally broke a few minor thing.
However, when I was trying to clean all of the oil and grime out from the engine bay I accidentally sprayed some non-chlorinated brake cleaner around the the engine block's interface with the oil filter housing. I was in a rush and only plugged the center hole in the pic below and completely forgot to plug the other two holes or ports (one left and one right) as seen in the linked image. Does anyone know if it is a big deal having a little bit of non-chlorinated brake parts cleaner in the oil ports? Will damage the engine? I'm assuming no big deal, but just was wondering!
https://www.dropbox.com/s/n9qzxrpo9x...10744.jpg?dl=0
m3post
