New 2009 2010 BMW Z4 - ZPOST
      09-08-2019, 11:10 AM   #23
BuddhaPilot
Swollen Member
BuddhaPilot's Avatar
Drives: 2009 BSM Z4 3.0
Time for new tires just before I put our Z4 up for sale. I'm definitely going with a non-RFT and will most likely buy the PS4. Has anyone tried the PS3+ high performance all-season? They're about $60 per tire cheaper and since I'm more worried about wet weather performance over all out grip, I think they may be a better choice. Feedback?
Finally delivered!!...2012 135i/AW over Coral Red/MSport/Nav/HK/Toasty Seats/6MT
      09-18-2019, 11:08 AM   #24
BuddhaPilot
Swollen Member
Ride report since no one seemed to have given these a try...
Our Z4 is a 2009 3.0, non-sport package, square setup 225/45-17. Car had Michelin RFTs when we bought it and just replaced with non RFT PS3 Ultra High Performance All Season. I've put about 200 miles on them with about 75% being highway. Noise level is a little better with a significant improvement in ride quality. Drove it through some of the worst streets in downtown Charleston the other day and not feeling and hearing a crash out of the tires when hitting some of the potholes and broken areas of the pavement was a very welcome change. Turn in response actually seems to be better despite the softer sidewall. The tire has a beefier and more aggressive look on the wheel even though it's the same size as the previous tire. Waiting to see how they do in the pouring rain and I'm sure I'll have the chance soon since it's monsoon season here. At $140 each, so far I think they were a great choice.
      10-19-2019, 08:09 AM   #25
scootr
scootr's Avatar
Drives: E89 Z4 3.0 6MT
Stock size Michelin Pilot 4s with 17X8 PLATINUM REVELATION GUNMETAL wheels from tire rack. Including new TPS sensors mounted and balanced to your door. Just slapped them on and go.
The non RF tires improve the comfort and handling.
18mm and 12mm spacers coming to complete.
      10-24-2019, 08:30 PM   #26
Eracer76
Eracer76's Avatar
Drives: 2009 E89 Z4 35i
TSW 19x8 et35 with 10mm spacers up front, and 19x9.5 et35 in rear with no spacers. Bridgestone Potenza RE11 tires 235/35/19 and 275/30/19. H&R lowering springs.
2009 Z4 35i 6mt, SpeedTech 6266 Gen2 turbo kit, Tial WG, VRSF 7.5 race IC, ER charge pipe, Tial BOV, Radium Fuel cell w/ surge tank and twin Walbro 525 pumps, Radium FPR and return line, Bluetooth ethanol sensor, Phoenix intake manifold w/PI, JB4 tuner, PR coil packs, Custom oil cooler, ECS Radiator, Spec 3+clutch, Mfactory flywheel, single 3.5" into dual 3" exhaust, H&R springs, 19" TSW wheels, 235/19 & 275/19 RE11 tires
      10-26-2019, 02:17 PM   #27
cuddapah
Drives: 2011 BMW Z4 sDrive 35i
Passenger side rear tire got screw'd. It is time to get new tires anyway. Right now Potenza RE050AI are on the car. I am thinking of going for the same or maybe P Zero RFTs as they are cheaper. Any suggestions for RFTs ?
      10-27-2019, 06:55 PM   #28
orionx
Drives: z4 e89
Exclamation
Question: How much extra space do we have between F/R stock wheel and stock suspension strut? Would a wider wheel that is 26mm closer to suspension strut cause rubbing?
A friend (nonlocal) has a set of 9Jx18 ET42 square setup with 235/45 tires to sell and I'm wondering if this setup would work or not.
It seems like the front wheels will be 25.7mm closer to suspension struts whereas the rear wheels will be 8.4mm closer and poke out 4.4mm more. In the attached pics, orange lines denote the recommended stock setup whereas green lines denote the 9Jx18 ET42 setup.
URLs to actual calculations:
Front --> https://www.willtheyfit.com/index.ph...h=9&offset2=42
Rear --> https://www.willtheyfit.com/index.ph...h=9&offset2=42
Got the recommended stock specs from here:
https://www.wheel-size.com/size/bmw/...ve35i-usdm-300
Front: 8Jx18 ET29, 225/40ZR18 88W
Rear: 8.5Jx18 ET40, 255/35ZR18 90W
      10-28-2019, 01:54 PM   #29
Asbjorn
Asbjorn's Avatar
China
90
Drives: Z4 N54 DCT (VTT GC lites)
I'm running 8.5J ET35 with 235/40R18 front no problem. Once I also had the stock rear tires mounted up front. They touched the inner liner on full steering lock (my stock rear wheels are 8.5J ET40 with 255/35R18). My track setup is a square 9J ET30 with 245 or more, which is only possible with lots of camber up front.
You might need a small spacer up front to be able to run a square setup with such a high ET. With lower ET you may need to add camber up front.
      10-29-2019, 03:42 PM   #30
Bob20124
Retired and Enjoying it
Bob20124's Avatar
Drives: 2011 Z4 35i Alpine White 6MT
Fronts 8.5x18 ET 30 with 245x40x18 PS4s. rears 9.5x18 ET 35 with 275x35x18 PS4s. Wheels are Flow 1 F3's. Stock non adaptive suspension, all good.
2011 35i BMS High & Low side OCC, Custom tune, CDV delete, Eldor coils, ER Charge Pipe w/Tial BOV, ER Comp. FMIC, K&N drop in,40W LED Halo, LCI side markers, M-Factory LSD, NGK plugs, Racing Dynamics strut brace, Stubby, Windrestrictor
      11-02-2019, 09:53 AM   #31
shockin330i
shockin330i's Avatar
798
Drives: 2016 ZCP M3
How much space do you have there in the rear?
ERnie
2016 BSM/f80/ZCP
      11-02-2019, 12:19 PM   #32
Eracer76
Eracer76's Avatar
Clearance behind the wheel/tire is about 1/2" all around and less then a 1/32" clearance for the front fender lip. My fenders are not rolled though, which would increase that clearance some more. With the lowering springs installed though, I did need to trim the fender liner directly above the tire, because it was rubbing on big bumps/dips in the road...
For my next set of wheels, I'd like to find some that are 19x8.5 et25 for the front so I wouldn't need spacers to push them out... and then 19x10 et40 for the rear
      01-01-2020, 01:06 PM   #33
key_89
Drives: 2011 BMW Z4 SDRIVE35i
Wheel Question!!
I have a 2011 35i and I am currently on 225/40/R18 F and 255/35/R18 R and want to run 18x9.5 +22 F and 18x9.5 +22 R Kansei KNP wheels. I would like to know if there would be any issues with this setup on stock suspension. If anyone has the same specs I would very much appreciate photos! Thanks
      01-04-2020, 02:10 AM   #34
Asbjorn
Asbjorn's Avatar
China
90
Thats a low ET.
I wonder if 275/30R18 on 10J ET40 wheels could work for a square setup with -3deg camber up front and a small spacer.
There would definitely be alot of rubbing on full steering lock though.
key_890.00
      01-07-2020, 01:30 PM   #35
Crazy8
Crazy8's Avatar
Drives: 2013 Z4 sdrive35is
Car: 2013 35is
Suspension: H&R sport springs, E9X front control arms, Turner adjustable rear camber arms, H&R sways
Wheels: BBS CH-R (19 x 8.5 et32 front, 19 x 9.5 et 35 rear)
Tires: Michelin Pilot 4s 225/35r19 front, 255/30r19 rear
Current: 2013 Z4 sdrive35is MHD 2+ E50 OTS Tune, Wagner EVO 1 Comp FMIC, ER CP, Tial BOV, VRSF CLDPs, E9X Control Arms, H&R Springs, H&R Sways, Turner Rear Camber Arms, M Performance BBK, BBS CH-R wheels, Stubby, CeramicPro, Late Side-markers, Michelin Pilot 4s
Past: 1995 840ci Calypso Red/grey w/a bunch of modz
      03-09-2020, 08:34 AM   #36
Leek78
Drives: M240i
Hi First post on this forum, will post a welcome with photo a bit later. However I some assistance is required regarding tyre sizes. My M326 alloys are cracked and I've purchased some Avant Garde M355 but cant decide which tyre sizes to get, but don't want any chub rub due to my tyres being overly fat, but i want the widest possible !!
Car = 2012 M sport 2.0 with M sport suspension
Current wheel set up = Front 225/35/19 8' ET29, rear 255/30/19 9' ET40 (standard)
new wheel Avant guard M355 = Front 9' ET35 and rear 10' ET38
Tyre options :
1) Front 235/35/19 Rear 265/30/19 - recommended by Avant Garde, but these seem on the lower side for the wheel. Wheel has increased in width by 25mm but Tyre width increase is only 10mm
2) Front 245/35/19 rear 275/30/19 - protects from kurb rash
3) Front 245/35/19 rear 265/35/19 - protects the rear from cracking
      03-10-2020, 06:31 PM   #37
starrman
Drives: Nissan Altima
Originally Posted by Vetracr View Post
My car is a 2010 3.0si 6 speed with 12K miles on the odometer. I've set the car up to handle like a sports car rather than like a touring car. It has an E46 M3 rear suspension and an E90 M3 front suspension, Grountd Control camber plates, Turner strut bar, Koni FSD shocks, H&R sway bars and stock springs. I've upgraded to 330i front brakes with 340x30mm rotors. It rides on TSW Bathurst 18x8.5 front and 18x9.5 rear rims mounted with 245/35-18 front and 265/35-18 rear Firestone 500 (rebranded Bridgestone R003's) tires. I also added an oil cooler for hot Florida weather, oil and water temperature gauges and an oil pressure gauge. I've removed the side and rear badges and painted the side lights and reflectors to clean up the lines of the car.
Very nice, would like to see your gauge mounting. Painting the side marker is awesome.
      04-13-2023, 02:27 PM   #38
LoveZ4
Z4 lover
South Africa
Drives: BMW Z4 Roadster 2009 E89 2.3i
Unhappy Aftermarket wheels and Runflats
I'm so confused, I need to replace 2 rear wheels due to cracks, but considering putting aftermarket wheels on the Z4, as it's more cost effective than original BMW wheels. However, my tyres are runflats and staggered. I'm getting conflicting information and need to know if my runflats will be compatible with the aftermarket wheels. Changing to regular tyres on a Z4 that has minimal boot space and 2 tyre sizes, is not an option for me now. Would I have to replace these wheels with the original BMW wheels? ��
      04-13-2023, 03:15 PM   #39
Marcoose
Marcoose's Avatar
Drives: 2016 sDrive35is
Disclaimer: Tyres and wheels isn't my wheelhouse.
I reckon if diameter, width and offset of the aftermarket wheels match the OEM's, then you're good.
However, TPMS compatibility may be the problem. I'd wait to buy aftermarket wheels until somebody can opine, or the seller guarantees TPMS compatibility.
2016 35is, monoballs, camber plates, KWV3, PS4S, xHP, MHD, LFB pedal, flat bottom wheel, red indicators, black headlamps
      04-13-2023, 04:16 PM   #40
B21
B21's Avatar
153
Modern runflats can run on almost all modern alloy wheels..
So you can transfer your tyres across…
That assumes the wheel widths are compatible..
What wheels do you currently have ? What model and when was it produced ?
As was suggested depending on the year of manufacture of your car you may have one of two puncture monitoring systems..
The later system TPMS has a radio transmitter in each wheel, yiu will need to transfer those as well or buy new ones..
      04-13-2023, 06:11 PM   #41
roadracer516
Drives: X3 M40i, Z4 35i
The short answer is NO, you do not need original BMW wheels, any aftermarket wheel will work with RFT's. Just need to be sure the diameter and width of the new wheels are the same or close to what you have now if you are going to use the tires off your existing OEM wheels to transfer to the new wheels.
If you go the new wheels route, you might consider an offset that give it a wider stance? Or you can use wheel spacers as I have on my stock 18" style 325 wheels. I went with 15mm fronts and 20mm rears and like the increased stance with these additions per this thread: https://e89.zpost.com/forums/showthread.php?t=1997777
Stock wheels specs are as follows, addition of spacers effectively only change the offset:
Front: 8Jx18 ET+29 Offset. With the addition of the 15mm spacers, the new effective offset is ET+14
Rear: 8.5Jx18 ET40. With the addition of the 15mm spacers, the new effective offset is ET+20
Current: G01 X3 M40i (Carbon Black / Black Vernasca, Blue stitch Leather), E89 Z4 35i (Alpine White / Kansas beige leather), Ram 1500 Limited 4x4 (Black / Black leather), 2004 Honda Goldwing - Previously owned BMW's: E36 M3, E46 330i, E46 M3, F25 X3 3.5i M Sport, G12 750ix M Sport, F32 435i xdrive M Sport.
      04-13-2023, 11:22 PM   #42
LoveZ4
Z4 lover
South Africa
Thank you so much for the input and advice. My current tyre size is front 225/35/19 & rear is 255/30/ 19. The car 2009 model , E89, 2.3 hard top .
      04-13-2023, 11:53 PM   #43
LoveZ4
Z4 lover
South Africa
Runflats and Regular tyres
If I change the runflat to regular tyres on the aftermarket wheels, what size would I need to get. The current size is front 225/35/19 & rear 255/30/19 . 2009 E89 2.3i
      04-14-2023, 06:46 AM   #44
Marcoose
Marcoose's Avatar
If the new wheels have the same OEM diameter, width and offset, then same tyre size. Some folk have gone up one width size for more kerb protection and to fill more the arches/wings.
Do get a good tyre patch kit and pump. And a roadside assistance plan. That’s a must.
zpost
