New 2009 2010 BMW Z4 - ZPOST
      04-14-2023, 10:07 AM   #45
KennyP
KennyP's Avatar
Estonia
147
Drives: 2009 Havana E89 Z4 Sdrive35i
Originally Posted by LoveZ4 View Post
If I change the runflat to regular tyres on the aftermarket wheels, what size would I need to get. The current size is front 225/35/19 & rear 255/30/19 . 2009 E89 2.3i
i think just use oem tire sizes. 255/30 is probably more than enough grip for the 23i.
Just today i ordered a new set of Michelin PS4S in oem sizes (225/35 and 255/30 19"). Will get them fitted on monday. I have no issues with stock sizes nor do i wish for meatier tyres. If it is enough for a stage 1 360hp-ish 35i then its surely enough for a 204hp 23i, is it not?
Good tyre brand and model probably makes more difference than going up in size. So dont cheap out on tires.
2009 35i DCT Havana brown with ivory white interior. Mods: Cobb stage 1+FMIC, Wagner EVO1 FMIC, BMS DCI, KW V3 suspension, M3 front control arms, Hardrace RTAB, Michelin Pilot Sport 4S tires.
      04-19-2023, 02:21 PM   #46
giloup57
Drives: Z4 E89 Sdrive 20i
nouvelles roues
jantes de LDPrestige
LDP - LDM164 - 80x18" 5x120 ET34 72 Poli Anthracite
LDP - LDM164 - 90x18" 5x120 ET40 72 Poli Anthracite
Le choix s'est porté sur ce modèle car je cherchais à moderniser la roue avec une jante bi ton anthracite (salissure moins visible, je l'espère).
J'ai monté des Michelin Pilot sport 5
2x PNEU MICHELIN PILOT SPORT 5 255/35 R18 94 Y
2x PNEU MICHELIN PILOT SPORT 5 225/40 R18 92 Y
      05-07-2023, 06:39 PM   #47
Drummer$Dude
Drummer$Dude's Avatar
Drives: 2009 BMW Z4 E89 35i
My current wheels n tires.
https://www.fitmentindustries.com/wh...han-ds08-stock
Will be installing mild lowering springs when I install new Bilstein struts and shocks in a few weeks.
Wheels were purchased from eBay and tires from TireRack.
2009 BMW Z4 35i
2009 Infiniti EX35 Journey AWD
2017 Lincoln MKC AWD
      02-27-2024, 12:37 PM   #48
roshperera
Drives: Z4 E89 20i sDrive
Hi! I recently bought a pre owned z4 e89 20i sDrive and I’ve been having a lot of trouble with the wheels and tires.
First of all, the factory fit wheels (17 inch) were removed and were replaced by after market 18 inches by a previous owner. Now the tyre sizes are 225/40 R18 for the front and 265/35 R18 for the rear.
I got the tire pressure signal just a few days after I bought it and had to replace the tires, which again kept loosing air, then got the rims checked and fixed.
I am not losing air now but the tyre pressure warning keeps coming on. Is this something related to the tyre pressure really? Because I pump 36psi to the front and 42psi to the rear. Should I change that? According to the tire sizes I have on now, what tyre pressure should I pump in?
      02-27-2024, 12:59 PM   #49
B21
B21's Avatar
153
What MY is the car..do you have idrive ..the screen in the middle of the dash?
      03-01-2024, 07:19 AM   #50
Steve Jarvis
Steve Jarvis's Avatar
17
Drives: BMW M4, BMW M550i, 911 Turbo
I guess I should add mine here so they'll be in one place.
2011 35i 6sp
H&R Sport Springs
-1.3 degrees negative camber front and -2.5 degrees rear
Modified rear inner fender liners. Below is a link to the modifications.
https://e89.zpost.com/forums/showthread.php?t=2083616
APEX VS-5RS wheels in anthracite
Front: 19x9.5" +35mm offset (with 3mm spacer)
Rear: 19x10.5" +45mm offset
Michelin PS4s tires
Front: 265/30R19
Rear: 285/30R19
2011 BMW Z4 35i 6sp wh/rd
2017 BMW M4 Comp DCT blk/blk
2001 Porsche 911 Turbo 6sp blk/blk
zpost
