BMW M3 Forum (E90 E92)
European Auto Source (EAS)
      07-14-2013, 12:43 PM   #89
W Cole
Drives: 2009 M3
FYI to anyone else doing the swap. Bolt #1 on the rear suspension (see photo in post above) does not need to be removed. Just put two wheel lugs into the hub and use your leg or a buddy to put some downward pressure on the suspension and you should be able to get the spring out, the shorter OEM spring should go in even easier.
This bolt is a bit of a pain to line up correctly and its very easy to damage the lower control arm ball joint/bushing when re-installing so its probably best not to remove if you don't have to.
When re-tightening bolt #2.. Before starting the install measure from the center of the hub to fender at normal ride height and then mimic this measurement using a hydraulic jack to compress the suspension when tightening to avoid any undue stress on the bushing.
      10-07-2013, 07:48 PM   #90
Jaymax85
Addicted to Speed.
Jaymax85's Avatar
Drives: m3 zcp, macan GTS, f15 x5
How many people bought new nuts and bolts while doing the spring installed? Is there a part number list? It seems like numerous people have asked but there has been no answer. thanks!
2017 991.2s
2015 F15 35i
2017 Macan gts
      10-07-2013, 09:46 PM   #91
GregW / Oregon
Commander-In-Chief
2122
Drives: 2023 M2 Coupe, 2020 GLE 450
Does this help?
Greg Lake Oswego, Oregon, USA
2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450
      11-17-2013, 04:19 PM   #92
J5isalive
49
Drives: '20 M2C, '15 GT3
I tried this method of not removing the bolt, I could not get it to work. I even broke out a small jack and jacked the suspension down to try to get the spring out, no go.
In the end I removed the bolt. 1 side took me 5 minutes to get the bolt back in. The other side took an hour!!!! That bolt is a huge pain, very easy to damage the ball joint.
The front is a breeze.
      02-25-2014, 10:09 PM   #93
SR-71
SR-71's Avatar
Drives: 09 E90
Has anyone had issues with their headlights adjusting too high after installation? Is there a way to reset the headlight sensors? Thanks for the help.
      02-25-2014, 10:55 PM   #94
W Cole
Drives: 2009 M3
You most likely did not get the headlight leveling sensors oriented correctly when you reinstalled. If you search there is a thread explaining how to correct this.
With that being said, despite correctly reinstalling the headlight leveling sensors my headlights aimed too low after installing my coilovers. There is a knob on each headlight that you turn in order to adjust the height.
      02-27-2014, 04:58 PM   #95
SR-71
SR-71's Avatar
Drives: 09 E90
I figured I had somehow messed up the rear level sensor. I just wanted to do some searching/asking for help before getting crazy. Thanks for your help W Cole.
      04-18-2014, 02:26 PM   #96
tmntmn
///M
Drives: e92 M3/M-DCT
Does anyone know the Wrench socket size of the TOP HAT NUT?
thinking about making a tool like a fellow forum member robc1976 did in this picture
THANKS TO:~<RPM>~ ~<SONICMS>~ ~<MODECARBON>~ ~<McKennaPerformance>~
MODS: MODECARBON V2 GTS FRONT LIP & REAR DIFFUSER, AA GREEN FILTER, RPI SCOOPS, PSW, Verstraβe Extended DCT Shifter, ZCP WHEELS (SEMI-GLOSS), OHLINS R&T, Megan Exhaust, AKRA XPIPE, BMW LED INTERIOR, BLACKOUT W/ORION V4 LED AE, OSRAM CBI
      04-18-2014, 02:39 PM   #97
adc
Drives: 2018 F80 M3 ED
This tool has a cutout and might work.
http://www.zorotools.com/g/00141033/...FQ2hOgoda2oAJw
Edit: I think the nut is actually 22mm. I used a plumbers adjustable wrench at the time, but will try to source or fabricate a tool when I change springs next month.
2018 F80 Santorini
2019 Z4 3.0i
2022 X2 M35i
      04-18-2014, 03:18 PM   #98
tmntmn
///M
Thanks!
I'm planning on picking up a cheap socket to cut open
      04-18-2014, 03:49 PM   #99
adc
Thanks!
I just ordered a 22mm oxygen sensor offset socket, which looks like it might do the trick. $9 on amazon. I'll post back here after I receive it.
2018 F80 Santorini
2019 Z4 3.0i
2022 X2 M35i
      04-18-2014, 06:36 PM   #100
tmntmn
///M
sounds good! please keep me updated!
      04-19-2014, 07:30 PM   #101
adc
Just found this: http://www.ecstuning.com/News/Schwab...Kit/ES2652183/
2018 F80 Santorini
2019 Z4 3.0i
2022 X2 M35i
      05-09-2014, 12:00 AM   #102
apecush
30
Drives: 2008 E90 M3
Just wanted to say thanks for the DIY. Did my springs, camber plates, and rear dinan mounts over two evenings, a grand total of about 5 hours (not working particularly fast). I think I spent more time finding the right size socket or wrench than actually working. This car has every metric size under the sun! I'm used to working on Japanese cars, where everything is 10, 12, 14, 17, 19, or 21mm.
FYI, on my car, 08 w/edc, the front strut nuts were 21mm.
      06-28-2014, 03:27 PM   #103
adc
I just did the rears on my car, took around 2.5 hours with a second pair of hands helping. I found it easier to use 3 jacks: one to raise the car, one to raise/lower the suspension arm as needed, and the third to raise or lower the disc brake (suspension hub) as needed.
The difficulty came from the fact that you need to adjust the last bolt in 2 directions, left right and up down. So while I could get enough leverage with a wrench, I couldn't maintain the support long enough to line the holes correctly.
With the 3 jacks in place, all I needed was a big old screwdriver to position the holes.
Just did the fronts, took again about 2-2.5 hours. I used this tool: http://www.ecstuning.com/News/Schwab...Kit/ES2652181/
21mm for my 2009 with EDC.
Didn't get an EDC fault, but I think I messed up a brake sensor because i got the yellow car-on-the-list symbol and I noticed one of them hanging at the front. I'll check it next week when I do track pads.
2018 F80 Santorini
2019 Z4 3.0i
2022 X2 M35i
      07-31-2014, 03:43 PM   #104
MFL
MFL's Avatar
174
Drives: E92 M3
2010 BMW M3  [9.00]
Spring Compressors aren't required. I recommend that you keep tension on the front struts/springs until the top bolt is out, then slowly lower it down. There is no drama or surprises when doing it this way.
Also, if the strut is not popping out, turn the wheel so that the front of the brake disc turns in and it will come right out.
I honestly found the front to be much easier than the rears. First time around took around two hours, if I do another set it would likely be done in under an hour.
      07-31-2014, 06:43 PM   #105
adc
Still not sure how you can take the front spring assembly out from under the fender without the spring being compressed. I had to compress them at least 2-3" otherwise the upper spring loop wouldn't clear the fender lip.
2018 F80 Santorini
2019 Z4 3.0i
2022 X2 M35i
      07-31-2014, 07:40 PM   #106
W Cole
Drives: 2009 M3
Same here. Are some removing the stut and spring from the car with the top hat already off. How do they clear the fender?? I want to know the secret. Does turning the wheels help?
      08-08-2014, 02:24 PM   #107
MFL
MFL's Avatar
174
Drives: E92 M3
2010 BMW M3  [9.00]
You have to turn the wheel, you can bend compress the spring slightly by hand which will clear the fender well completely and come out towards you.
      08-08-2014, 02:25 PM   #108
MFL
MFL's Avatar
174
Drives: E92 M3
2010 BMW M3  [9.00]
Also, while it's up in the air, you can turn the steering rack by hand with the brake disc.
      08-08-2014, 07:49 PM   #109
W Cole
Drives: 2009 M3
Thanks for the info!
      09-05-2014, 05:19 PM   #110
ParisF3
PARISF3
ParisF3's Avatar
Drives: 2011 E92 ZCP M3
Sorry to bring this thread back from the dead, but this doesnt seem to difficult to diy. I dont get why shops quote me 500-600 dollars!! blows my mind!
*2011 ZCP E92 M3- DCT- Jet Black- Blacked out, painted reflectors- Akrapovic Evolution- ESS Flash Tune- Predator Orion V4- BMW OEM CF spoiler -
*2013 F30 328i- White on Fox red int. 6MT
*2002 E46 M3 Silver/ 6MT (Previous)
m3post
