BMW M3 Forum (E90 E92)
BPM
      08-15-2023, 03:19 PM   #1
charliev68
charliev68's Avatar
204
Drives: bmw m3
Remove Valve Covers and Timing Covers
Set Timing and Lock Bank 1 at 10* BTDC (T)
Lock Exhaust Phaser with tool (optional)
Pry off old VANOS Covers
Remove cam bolts and install VANOS Plates with new bolts (Reverse Threads)
Stretch Bolts and Set Timing:
Do for both EX Cam and IN Cam (Remove EX side first, Install IN side first)
Hand Tight, 10NM, 20NM, 80NM, 200*, Back Off, 10NM
Unpin Crank and turn engine to TDC (O)
Set Timing and Lock Bank 2 at 10* BTDC (T)
Hand Tight, 10 NM, 20NM, 80NM, 200*, Back Off, 10NM
Anyone in SoCal need help, let me know!
CamasM3e933165.50
rcracin1242.50
      08-15-2023, 06:29 PM   #2
Redd
Drives: 2010 BMW E92 M3 Dakar Edition
Are these the Carbahn washers? Do you re-use the stock (small) washer under the bolt, or replace that with the new vanos washers?
      08-15-2023, 06:33 PM   #3
charliev68
charliev68's Avatar
204
Drives: bmw m3
Disregard the washer. The Carbahn plate acts as the washer. Lol, I would say, Carbahn is basically an oversized washer.
      08-15-2023, 06:52 PM   #4
Redd
Yes pretty much. Thanks for the detailed writeup!
      08-17-2023, 03:01 PM   #5
charliev68
charliev68's Avatar
204
Drives: bmw m3
What’s needed
      08-17-2023, 03:09 PM   #6
spammysammich
spammysammich's Avatar
1585
Drives: 2009 E92 M3 Dakar Yellow II
2009 BMW M3  [10.00]
Sorry if this is a dumb question but do you end up doing the timing (including pre-tensioning and bolt stretching) 4 times? Each cam gear being timed independently?
      08-17-2023, 03:16 PM   #7
charliev68
charliev68's Avatar
204
Drives: bmw m3
You do one Bank at a time, each Phaser at a time. Stretch the bolt at (T) then advance the engine to (O) for final stretch/torque. So, yes, 4 times in 2 stages.
      08-17-2023, 03:18 PM   #8
spammysammich
1585
2009 BMW M3  [10.00]
Gotcha that makes sense. Doesn’t seem terribly difficult if you have the tools and good work instructions. I have access to ISTA and want to learn this eventually
      08-17-2023, 03:19 PM   #9
charliev68
charliev68's Avatar
204
Drives: bmw m3
If it’s your first time doing it, I suggest having an extra set of bolts on stand by. The first time I did it, I got confused and stretched the bolts at the wrong stages. Had to wait for new bolts and start all over.
      08-17-2023, 03:23 PM   #10
spammysammich
1585
2009 BMW M3  [10.00]
I think that step where you back off then put on 10NM before moving to TDC is gonna trip a lot of us up. Very essential to give the phaser the right tension to be able to retard and advance properly.
      08-17-2023, 03:24 PM   #11
spammysammich
1585
2009 BMW M3  [10.00]
I think I would want to sharpie the washer at 10 BTDC so I could see the movement of the washer/phaser.
      08-17-2023, 03:28 PM   #12
charliev68
charliev68's Avatar
204
Drives: bmw m3
Yeah, because the first time you get all nervous and anxious. Just work slow and stay focused!
I’ve seen people do it, then start up the car and get the timing error message! Sucks because you have to go back and do it all again
      08-17-2023, 04:09 PM   #13
spammysammich
1585
2009 BMW M3  [10.00]
Some people also think that you can spin the crank 360 degrees to check timing. Don’t forget folks, two full spins of the crank to get back to a full revolution of a cam. Made that mistake with my Subaru once.
      08-17-2023, 04:19 PM   #14
charliev68
charliev68's Avatar
204
Drives: bmw m3
Yes, that’s something I forgot to mention. Before you attempt this job, you might want to get a full understanding of engine timing. Learn it to the point where you can check the timing with the tool in your sleep!
      01-18-2024, 10:39 PM   #15
gkgsvensson
gkgsvensson's Avatar
75
Drives: 2007 Z4 M Coupe
Reading through TIS forensically, the one difference I see between your process and that one is that TIS says set crank at TDC FIRST, then lock cams, then remove central bolts, THEN go 10 degrees before, then stretch/unstretch, THEN TDC, then final stretch.
You suggest lock cams and removal of bolts at 10 degrees before TDC, so only one adjustement is made to the crank. Im confused why you do it this way, but I suppose it works? Maybe i misread TIS?
2001 E39 M5 - Titanium Silver
2007 Z4 M Coupe - Sepang Bronze
2008 E92 M3 - Jerez Black
      01-18-2024, 10:58 PM   #16
charliev68
charliev68's Avatar
204
Drives: bmw m3
Both ways come to the same conclusion. Just as long as the final stretch is done at TDC, ensuring the chain is tight.
m3post
