New 2009 2010 BMW Z4 - ZPOST
      12-18-2023, 03:13 PM   #1
Rah-Vee
Drives: BMW Z4 09 30i, 2016 C450 AMG
Fixed airbag light after new seat install
After looking around the web on how to cancel the airbag light and passenger occupancy sensor. I decided to try just ripping everything out of the old seat.
Pulled out the entire occupancy sensor, side airbag, seat belt and wiring harnes which plugs into all 3. Then just plugged it back in and tucked the occupancy pad under the seat and left airbag on the side till I figure out a better placement. All warnings for airbag and passenger occupancy cleared after clearing codes.
      02-16-2024, 04:57 PM   #2
Rah-Vee
Adding some pics of my home made seat brackets and seats for reference. As well as some content for a slow moving forum, lol.
      02-17-2024, 03:12 AM   #3
B21
B21's Avatar
153
Good to see a seat mod…so you have the old bits tucked under the new seats ?
Yes this is a bit of a slow forum these days…
      02-17-2024, 07:21 PM   #4
Drummer$Dude
Drummer$Dude's Avatar
Drives: 2009 BMW Z4 E89 35i
B21, you are correct about the forum being slow. I have really enjoyed your helpful guidance and shared knowledge over the winter. Once spring arrives I’ll be tackling quite a few projects on my Z4 and will document some of those here.
Rah-Vee, those are some nice seats!
2009 BMW Z4 35i
2009 Infiniti EX35 Journey AWD
2017 Lincoln MKC AWD
      02-18-2024, 03:23 AM   #5
B21
B21's Avatar
153
It is what it is…I see some other forums which have died on their feet..hopefully more posts here will generate more views / traffic etc..
      02-18-2024, 04:09 AM   #6
KennyP
KennyP's Avatar
Estonia
147
Drives: 2009 Havana E89 Z4 Sdrive35i
Putting sportier seats isnt a bad idea... I owned a few Type-Rs before my Z and seats in those were amazing..
but then you still need to retrim the seats to match you other interior bits... in your case red...
Also what happens to the airbag you stuck under the seat in say.. a side impact.. its going to deploy explosively under that seat... these things have some power when they deploy...So its basically like a selfmade ejectorseat ...
There has to be a way to code seat airbags off or replace it with some dummy item in the harness...
There was this one guy on forums who had buckets in his car.. Asbjorn..
He used to post here, but his build thread is on spool street forum.
Maybe you could shoot him a PM and ask how he got all the seat errors sorted.If he did...
2009 35i DCT Havana brown with ivory white interior. Mods: Cobb stage 1+FMIC, Wagner EVO1 FMIC, BMS DCI, KW V3 suspension, M3 front control arms, Hardrace RTAB, Michelin Pilot Sport 4S tires.
      02-18-2024, 11:56 AM   #7
B21
B21's Avatar
153
He's still got the car..over 200k km on original engine..but given up racing it..goes karting instead!
KennyP146.50
      02-19-2024, 08:18 PM   #8
Jakeinaka
Drives: E89 Z4 20i
Replace the airbag with a resistor, the car thinks the airbag is there so won't get a light on the dash. Common mod when fitting after market steering wheels.
I did that with my old Z3
      02-20-2024, 11:58 AM   #9
Steve Jarvis
Steve Jarvis's Avatar
17
Drives: BMW M4, BMW M550i, 911 Turbo
Rah-Vee,
What's the box between your seats?
2011 BMW Z4 35i 6sp wh/rd
2017 BMW M4 Comp DCT blk/blk
2001 Porsche 911 Turbo 6sp blk/blk
      02-21-2024, 02:48 PM   #10
Rah-Vee
@Steve Jarvis
Its a Kicker(46HS10) 10inch powered sub, I usually have it behind the passenger seat but pulled out for the install. It should fit under with these new seats which ill test fit soon.
@Jakeinaka
Yup I just found the resistors and will be trying to swap the airbags for them soon.
@KennyP
Im considering having a shop swap the blue fabric to black suede. The airbag goin off under the seats was a concern but im going to test some resistor replacements soon. The seats are great, the side bolstering feels like its actually holding your sides, very comfy and secure.
zpost
