New 2009 2010 BMW Z4 - ZPOST
      02-22-2024, 09:26 AM   #1
kgie1217
Drives: 2011 BMW Z4 30i
Auto dim - Homelink Rearview Mirror Retrofit
I have done a search on here about retrofitting an OEM autodim/homelink rearview mirror to a Z4 that only came with the standard mirror. My question is it a direct swap and work like designed or is there a harness that has to be purchased? I saw in one post that you have to re-program the car as well. Any insight to this is appreciated.
      03-03-2024, 03:48 PM   #2
GerryC
GerryC's Avatar
1618
Drives: BMW Z4 M40i, BMW X5x40i
There is (or was) one available that is plug compatible with your car. All it needs is power. Go to RealOEM and put in your VIN. Then 'Browse Parts', Click on 'Vehicle Trim' and the 'Interior Mirror'.
From the list, find the mirror with "Integrated universal remote control" to get the part number. (I believe there is also one with both the remote and the digital compass, but it's a lot more expensive.) Once you get the part number just Google "BMW xxxxxxxxxxx" where xxxxxxxxxxx is the part number. That will bring up any online sources of it.
It takes less than 10 minutes to swap. I did it on my E85. My E89 came with the remote.
2023 Z4 ///M40i Thundernight Metallic/Cognac Vernasca/Moonlight/Shadowline/19" Black 799M/PP/DAP/ACC/HK
2022 X5 xDrive40i Phytonic Blue/Cognac Vernasca/DAPP/LSP/PP/CCP/PAP/20" Style 738/Spare Tire/Trailer Hitch
      03-04-2024, 01:44 AM   #3
DavesZed
DavesZed's Avatar
151
Drives: BMW E89 23i, 2011
If you only have the standard mirror and no RLS (auto wipers/lights, VO 521) then this is fed with power via the roof light unit (Function Control Centre). This will also only have the one power feed. To have the auto dim and/or the homelink (and also the RLS if required) you need a second power feed to the light unit. So that's the first part of the mod. You then need new wires from the light unit to the mirror. Once all of this is completed you will then need a coding session, to code in Auto Dim (531) and Homelink (no VO code).
Take a look at this post....
https://www.e90post.com/forums/showthread.php?t=450516
Dave
2011, E89 23i, Grey with Red leather.... relatively basic (getting less and less basic with every new retrofit)!
My Z4 E89 YouTube channel...
https://www.youtube.com/channel/UCtt...0vHFUQnoEvKB2Q
      04-03-2024, 01:52 PM   #4
kgie1217
Thanks for the follow up. I have auto wipers and lights but the rear view mirror is just a standard mirror. So, I'm assuming based on your post that if I got the autodim/homelink mirror this would just be a swap as long as there is power near by?
      04-03-2024, 02:40 PM   #5
DavesZed
DavesZed's Avatar
151
Yes, as long as you provide the additional power feed then it'll work.
Dave
zpost
