BMW M3 Forum (E90 E92)
European Auto Source (EAS)
      08-09-2012, 09:10 AM   #23
THE TECH
THE TECH's Avatar
307
Drives: BPMsport 2012 E92 M3
Originally Posted by snowmants View Post
Just a few tips from someone who just removed his bumper and headlights:
-Bumper removal is pretty easy and straight forward if you follow the PDF instructions posted above. Don't be afraid to remove more screws from the fender liner than those instructions tell you to. I found it made things easier.
-Make sure you take the front wheels off first.
-Have a "torx 30" bit that fits on your socket wrench. Craftsman makes them and I got one at sears for my 3/8" drive socket wrench.
-when removing the headlights remove the headlight bracket that each of the headlights sit on. It will allow you to remove the headlights without having to try and remove the one almost impossible to get to screw that is directly under the headlight and connects it to the headlight bracket. It took me 2 hours to get that bolt out on the first headlight I did. On the second one I noticed I could just remove the whole bracket with the headlight and it took like 10 minutes instead!
Nice tips!
      08-09-2012, 09:41 AM   #24
snowmants
snowmants's Avatar
Drives: '06S2K,'11EVO,'11Jeep,'13GL450
2008 BMW E90 M3  [10.00]
More info on removing headlights can be found here:
http://www.m3post.com/forums/showthread.php?t=453194
'06 Honda S2000 #555 TT5
'16 Porsche GT4
      12-13-2012, 12:47 PM   #25
blackmist222777
blackmist222777's Avatar
Drives: 2011 BMW 1M
awesome tips guys... gunna give it a go on my ride myself.. just bumper replacement. fingers crossed
2023 G80 M3
2020 F87 M2C
2011 E82 BMW 1M Series Coupe
Check me out at Point.Shift.Drive (YouTube)
      12-25-2012, 07:19 AM   #26
whywhys
Drives: M3 E92
Thanks this helped me a lot!!!!
      12-28-2012, 10:14 PM   #27
snowmants
snowmants's Avatar
You're welcome!
'16 Porsche GT4
      03-12-2013, 07:02 AM   #28
AlpineE92M3
Currently Driving
AlpineE92M3's Avatar
269
Drives: BPM tuned '13 AW ZCP E92 M3
2013 BMW E92 M3  [0.00]
2011 BMW M3  [0.00]
Thanks for the post!
      05-07-2013, 11:30 AM   #29
Lorde
Ya ya ya, I am Lorde, ya ya!
Lorde's Avatar
266
Drives: E90 M3, 2015 SQ5
2008 BMW M3 E90  [0.00]
Originally Posted by mdernst View Post
The same document as above but in English.
Mike
Originally Posted by gatorfast View Post
There is a slight gap between the bumper and headlights as well as where the top of the bumper meets the hood. Any suggestions on how to fix this without removing the whole bumper and putting it back on?
I was looking for a fix for this as well, the PDF attached to mdernst's above post references fixing the bumper height/fitment adjustments in another guide. Were you able to fix the gap between the bumper cover and hood? I have more sag on one side than the other and it's driving me nuts.
      06-15-2014, 04:54 PM   #30
rAdzM
Smashed!
Drives: 2009 E92 M3
2009 BMW M3  [10.00]
2006 BMW M5  [9.00]
thanks to this post! I find everything so much easier when I completely removed the fender liner.
est. 2008
BBS | BREMBO | RECARO | ig: @euro_rad
      06-16-2014, 10:38 AM   #31
Wei718
Wei718's Avatar
340
Drives: 718 GT4
For those of you that has a front lip installed with their oem screws covered by the lip and want to remove the bumper without removing the lip there is a way. You remove the bumper with the lip and whole undertray altogether that way you don't need to detach your lip and having have to get it installed again. I find this method much easier rather than removing everything piece by piece.
Remove both wheels
Remove both fender liners
Remove 4 8mm screws 2 on each end of bumper
Remove the 3 10mm bolts on the undertray
Unhook both cable supporting the undertray
Remove 4 torx screws on top of bumper
ualdrivr158.50
      01-29-2015, 05:14 PM   #32
phrozen06
phrozen06's Avatar
229
Drives: 328it, RIP M3, E46 Sold
nice
      04-03-2015, 02:50 AM   #33
tkordy
tkordy's Avatar
13
Drives: 2009 BMW M3 & 2017 BMW M2
Helped me get a stuck screw driver out
m3post
