2010 2011 BMW 5 Series Forum F10 Rennline phone mount install |
01-14-2020, 12:29 PM | #1 |
1301
Rep 2,591
I was never satisfied with any of the other options out there, so I bit the bullet and bought the Rennline phone mount for the F10. At $45, it's pricey, but probably the cleanest option.
The kit comes with a magnetic phone mount. What comes in the package: Screw on the bolt, use some pliers and a hex bit to tighten it down. Forget the size of the hex, surprised they didn't bother to include a hex bit in the kit. Pull your trim out. Ideally use a trim tool, but I just used my fingers. Be firm but gentle, it's all held on by clips. Might need to open passenger side door to get the far passenger side trim out. Undo the torx screw that is just to the right of the center console air ducts. It's T-25 or T-20, I forget which. Install the Rennline bracket, and tighten down. Don't tighten down too hard, it's threaded into plastic so its pretty easy to strip This is what it looks like with nothing attached to the ball It's a standard ball size, so pretty much any holder, mechanical or magnetic, will fit on it fine. My wireless charger as proof Fat cat tax Some questions that might get asked: Q: Does the magnetic mount damage your phone? A: No, the magnet is not strong enough to damage your electronics. Q: Will the metal plate affect wireless charging? A: Yes. No. Maybe. It really depends on where you place it, most phones have the induction coil at the center of the phone's back, so as long as you don't place it there you're fine. I placed the rectangular plate at the bottom of my phone, and my phone wirelessly charges just fine (Pixel 3 XL). If you can't get it to not block the coil, skip the magnetic part and just get a mechanical holder, the gravity style ones are slick. The balls these phone holder use are pretty much all standard ball sizes. Q: How's phone navigation with the phone that far offset? A: It's fine. If you glance at the map and can't remember at least the next turn, I'd be concerned. If anything, turn on voice navigation. Q: Does it block anything? A: For the driver, no. The passenger might have a tad bit harder time seeing the iDrive screen, but that's not a big deal imo
2015 BMW 535xi
Bootmod3 Stage 2 | ER charge pipe | ER Catted DP | Remus Exhaust | Gplus FMIC | KW V3 | Turner Monoball thrust arm bushings | Wallet regrets ISTA VM Setup/Tutorial |
01-14-2020, 01:33 PM | #3 |
1301
Rep 2,591
Nope, didn't do any cutting or modifying. Plug and play.
2015 BMW 535xi
walmark85.50 StradaRedlands4946.00 |
01-16-2020, 06:32 AM | #4 |
Rep 1,873
Thanks for posting this - I've been looking for something better than what I've been using.
The majority of times I'm in the car I don't mount my phone though, only for longer trips. I see your picture of just the ball sticking out - is it easy to install/remove the plastic caddy part on a per-trip basis? Or too much of a pain? I was also thinking of a Proclip - center dash mount option on the right side. Have you ever directly compared Rennline with Proclip by any chance? |
01-16-2020, 09:12 AM | #5 | |
1301
Rep 2,591
If so, yea very easy. You unscrew a plastic nut in the back so that the socket holding the ball can flex again, and you pop it right off. Takes probably 10 seconds. One thing to keep in mind, you really need to take a wrench and torque that metal ball down (within reason ofc). Otherwise, undoing the plastic nut can loosen the metal ball. I ran into this issue when I first installed and only hand tightened the ball. My friend used to have the ProClip one. There's a couple of issues I had with it. Large phones can be a bit awkwardly angled. Larger passengers might bump into your phone a lot. Looking at the phone requires you to directly look down, taking the road completely out of your LoS. Rennline one at least keeps the road in your peripherals. Looks kinda jank (in my opinion). It's not a bad option, I just think Rennline is probably a bit better of an option.
2015 BMW 535xi
Bootmod3 Stage 2 | ER charge pipe | ER Catted DP | Remus Exhaust | Gplus FMIC | KW V3 | Turner Monoball thrust arm bushings | Wallet regrets ISTA VM Setup/Tutorial Last edited by Unspec; 12-02-2023 at 02:23 PM.. |
01-16-2020, 02:24 PM | #6 | |
Rep 1,873
It sounds like the Proclip you experienced was the one that put the phone down by the shifter. I'm looking at vent-level. The catch I see is that it probably doesn't angle the phone towards the driver unless you also include a ball. I would put it on the right like in the small inset picture. It's probably pretty close to where the Rennline goes. |
01-16-2020, 03:36 PM | #7 | |
1301
Rep 2,591
If you want a more mechanical holder, look for "gravity phone mount" on amazon and you'll find a lot. Basically, the arms are connected via gears to a bottom lever that the phone pushes down with it's own weight. The arms come in when the bottom goes down, grasping your phone. Lift the phone up, and the bottom will come up, making the arms go out. Pretty clever!
2015 BMW 535xi
01-18-2020, 07:51 AM | #8 | ||
Rep 1,873
01-18-2020, 10:31 PM | #9 | |
1301
Rep 2,591
No problem!
2015 BMW 535xi
11-14-2023, 11:09 AM | #10 |
DIY Mechanic
77
Rep 127
Drives: 2012 BMW 535i xDrive
Sorry to revive this old af thread but it seems like my mounting bracket is kind of wobbly. Anyone have any issues with this?
You can live in a car but you can’t race a house.
11-14-2023, 05:27 PM | #11 |
1301
Rep 2,591
Try tightening the screw. It tends to get a little bit loose. I'd also add a dab of blue locktite.
2015 BMW 535xi
11-15-2023, 02:30 PM | #12 |
Rep 598
12-07-2023, 05:27 AM | #13 |
Rep 504
Drives: 2013 BMW F10 N55 535i XDrive
....More like screw in and play... lol, I just put one on myself a few months agao, and I got their tow hitch license plate frame
$ PURE STAGE 2 {} JORDAN CUSTOM TUNE {} DORCH HPFP {} SNOW METH {} DINAN EXHAUST {} EVOLV DARK OLIVE WRAP $
