BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > BIMMERPOST Universal Forums > General BMW News and Cars Discussion > Bi-turbo Vs. Twin Turbo
Extreme Powerhouse
      01-27-2014, 10:28 PM   #1
Grizz258
15
Drives: 09 bmw 335i sedan
I know what the difference is between the turbos. I'm just wondering if one is more sufficient than the other? I drive a 09 e90 335i. Ive heard its more efficient and I've heard doenst matter. Just needed more opinions.
      01-27-2014, 11:06 PM   #2
Rockette
Rockette's Avatar
Drives: BMW M2 Competition
2012 BMW 135i  [10.00]
Bi = 2
Twin = 2
Therefore: Bi = Twin
“You've gotta dance like there's nobody watching, Love like you'll never be hurt, Sing like there's nobody listening, And live like it's heaven on earth.”
      01-28-2014, 12:21 AM   #3
thai357sig
thai357sig's Avatar
30
Drives: M3
Does it have anything to do with sequence as in parallel or series?
09'M3 JerezB/Tech/Cold/Prem/PDC/SR/Black Leather/ANTHRACITE Sycamore/IPOD/USB/Rear Sunshade/Premium Sounnd/6MT***Just Hit The Ground! Delivery 02/25/2009***
      01-28-2014, 12:26 AM   #4
Ginger_Extract
California-bound
Ginger_Extract's Avatar
Drives: BMW 135i
I have always heard of twin turbos (N54) as being in-parallel, and bi-turbo (a la FD RX7) as being in-series. I'm not sure it really matters either way you splice it, it's just different terminology...
Streets of Willow: 1:27.7 CW 11/15/15; 1:29.5 CCW 8/15/15 |||| Autoclub Speedway ROVAL (CCW): 1.52.6 - 12/2/17
Willow Springs - Big Willow (CW): 1:35.8 - 3/31/18 |||| Buttonwillow #13 (CW): 1:59.3 1/27/18
https://www.facebook.com/JakeStumphRacing |||| http://www.youtube.com/user/RaceMeMZ3
      01-28-2014, 12:46 AM   #5
ybbiz34
ybbiz34's Avatar
670
Drives: 2023 330i M Sport
BMW prefers to use "twin turbo" nomenclature when referring to a motor utilizing two turbochargers.
Mercedes, on the other hand, prefers the "biturbo" nomenclature.
Both references basically mean the same thing but separate labels help to distinguish the brands when the terms are used to describe each brand's respective motor setup/technology.
Current: '23 G20 M Sport 330i
Current: '20 X253 GLC300 SUV
Gone: '20 W205 C43 Sedan
Gone: '18 W205 C43 Sedan
Gone: '13 W204 C63 Sedan
      01-28-2014, 11:05 AM   #6
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6158
Drives: ‘06 Z4MR, ‘20 X7, ‘22 M4x
Just a guess, twin sounds like it was maybe a colloquialism that caught on and stuck, like Bimmer or Lambo
Bi-turbo sounds more technically accurate... Germans
      01-28-2014, 12:46 PM   #7
Twix
Twix's Avatar
657
Drives: 2011 e91
I always thought that twin meant two turbos that feed a single intake plenum, and bi meant that each turbo fed its own plenum
2011 E91
2016 M2 - Sold
2014 X1 - Sold
2002 Land Rover Discovery II - 3" lift & 33s
      01-28-2014, 12:52 PM   #8
Red Bread
Drives: Smog machines
I assume the confusion here is just in wording. N54 = twin turbo. N55 = twin scroll single turbo. As stated earlier, for twin turbos, there's also the issue of whether they work in series or parallel.
      01-28-2014, 01:18 PM   #9
Raja Ventureshield
Raja Ventureshield's Avatar
Drives: BMW M3 coupe
sequential twin turbo is better I think as one spools up while the othe is kicking it. That way you have continuous momentum build up vs. plateau.
bi = twin are the same.
n54 is twin turbo
n55 is twin scroll single turbo
n54 is more tunable from what i heard, but i could be wrong. the last time my sister had Supra Turbo - we blew the turbo by running it too hot. :-(
Un4gettable 435i Extended Test drive thread:
http://www.f30post.com/forums/showthread.php?t=881491
      01-28-2014, 02:39 PM   #10
BavarianN54
Drives: 135i
BMW is partially responsible for much of the confusion. When they named their N55 ' twinpower' it confused many. I also think it was intentional, to let customers believe the new engine was still a twin turbo layout.
      01-28-2014, 08:18 PM   #11
Thumperx
Drives: 335I coupe
I cannot believe this subject is being discussed (????).
Name: Blanca | 07 E92 | AW-Blk | ZSP | Alcon BBK | M3 Bits | VM RR Links | Koni | UUC Sways | V5 | Dinan CAI | ETS IC | Fge DV | ER CP | Cyba | Raden. Exh | Mod Step | Trunk Drawer | Perf LED Wheel | Illum Dr Sills | IS Shifter | Parrot | Philps D1S | 6000k fog | MTECH RR | CSL Trunk | Aero | Roof Spoiler | PSS on BBS RS-GT 19s
      01-28-2014, 08:26 PM   #12
smellfish
No one on the corner has stagger like us
50
Drives: '11 AW E90
Bi is always better regarding cars and women
      03-26-2014, 08:03 AM   #13
Holygrail
Holygrail's Avatar
Drives: 2008 BMW E90 335i
2008 335i Sedan  [0.00]
I always thought that twin-turbos were two turbos of same size, which spooled up at the same rate and rpm, and bi-turbos two turbos of different sizes that spooled up at different rpms. For example, on the bi-turbo, one turbo would kick in earlier at the lower rpm and the other at a higher rpm to eliminate turbo lag. In order to make engines more efficient and to eliminate turbo lag, the Japanese had engines with both supercharger and turbocharger; the supercharger activates at lower rpms and the turbos would kick in at higher rpms ensuring constant power range.
I could be wrong with the whole bi/twin theory, but a supercharged/turbocharged engine does sound interesting. You would need a lot of room, and the N55 535i has a lot of room left and right side in the engine bay compared to no room at all in the N54 335i engine bay.
      03-26-2014, 09:00 AM   #14
The Automotive Enthusiast
Retired BMW Genius
The Automotive Enthusiast's Avatar
Drives: 2018 Audi S5 Coupe
Don't fall for BMW's marketing ploy. BMW calls the N20 a TwinPower Turbo. It's not, it's a single turbo, twin scroll.
Originally Posted by LucBroDude View Post
TRAITOR.
TRAITOR.
      03-26-2014, 09:15 AM   #15
yogi
Ninjapotamus
yogi's Avatar
Drives: F10 & E90
      03-26-2014, 11:53 AM   #16
flavius
46
Drives: 2019 440i Gran Coupe
Because?
-Experienced driver; cocomats
      03-26-2014, 12:01 PM   #17
kyleb350
kyleb350's Avatar
Drives: '21 X3MC
I dunno man. Having twins sounds like a plus too
      03-27-2014, 11:07 AM   #18
Grizz258
15
Thumbs up
      03-27-2014, 12:44 PM   #19
GreyCoupe
Drives: 15 650i Coupe
Uuuuuhhh, marketing.
Enjoyed some fun cars over the years: 1966 Corvette Convertible, 240Z, E24 L6, 300CE-24, 2004 645 Ci, 550SL, A6s, 535xi, E300/Bluetec/420, Grand Cherokee Overland, 2012 650i Coupe, 12 CL550, 13 SL550, 15 650i Coupe
