BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Share your BimmerTech PP82DSP Amp Tune Files **Updated 01/15/18
proTUNING Freaks
      10-09-2015, 12:45 PM   #1
ronanz
Gettin It Figured Out
ronanz's Avatar
Drives: 435i FBO PS2 bm3 w/ options
Share your BimmerTech PP82DSP Amp Tune Files **Updated 1/25/20
As title states, please share your tune files. Will post mine when BSW Subs come in.
Original Post/Thread concerning this Amp can be found HERE
I will be consolidating tune files on first two post. Please remove .pdf extension when downloaded
BimmerTech's PP82DSP Amp Tune Files v2.93 .afp
Courtesy of:
BimmerTech
Serpent720
Marshalltj
kitw
Ouzzo
AditOakes
LUV335 added 10/30 - Details can be found on Post #3
fhlh added 12/08 - Details can be found on Post #16
My Build Thread can be found HERE
Appreciate 3
      10-09-2015, 10:04 PM   #2
ronanz
ronanz's Avatar
v3.20a / v3.28d Tune Files **Updated 01/25/20
Taken from another Thread...just incase someone else has the same issue.
Originally Posted by trevneal2015 View Post
installed the pp86dsp and i cannot get my laptop to connect to the unit. i wasnt too worried before but i added a subwoofer amp but it will not get any signal from the bimmertech amp HELP!!!!
Originally Posted by Earlybirdy View Post
You need to download and install the driver FT232R USB UART. The driver and installation instructions can be found in the following link.
https://www.usb-drivers.org/ft232r-usb-uart-driver.html
I had the same connection problem with a laptop running Windows 10 and a Windows XP laptop. After installing the driver on both laptops, they connected to the amplifier.
Without the above driver installed, the DSP-PC-Tool software will stay in demo and not connect to the amplifier.
BimmerTech's PP82DSP Amp Tune Files v3.20a / v3.28d .afpx
Courtesy of:
Drew46
fhlh ... . added 01/18/16 - (Details can be found on Post #39)
BimmerTech ... . added 2/2/16, 2/22/17 - (Details can be found on Post #49 & #109)
mtenhoven ... . added 2/5/16 - (Details can be found on Post #55)
saaltonen ... . added 2/29/16 - (Details can be found on Post #59)
arminvb ... . added 5/20/16 - (Details can be found on Post #83)
RoarinRow ... . added 8/02/16 - (Details can be found on Post #90)
Hyperlink ... . added 8/11/16 - (Details can be found on Post #95)
BimmerTech ... . added 9/04/16 - (Details can be found on Post #97)
saaltonen ... . added 4/17/17 - (Details can be found on Post #111)
pacman335 ... . added 5/21/17 - (Details can be found on Post #114)
valley_nomad ... . added 10/15/17 - (Details can be found on Post #210)
twodoor ... . added 01/15/18 - (LUV335 Edit - Details can be found on Post #220)
foveon ... . updated 1/31/18 - (Details can be found on Post #123)... ... My personal favorite!
LongRuf ... . added 02/04/19 - (Details can be found on Post #310)
vithy ... . added 11/02/19 - (foveon Edit V9 - Details can be found on Post #345)
danyro ... . added 1/25/20 - (Details can be found on Post #353)
File Type: pdf Drew46_SEPT 26_BSW_OEM SUBS_DelayCenter.afpx.pdf (1.9 KB, 798 views)
File Type: pdf Drew46_SEPT 26_BSW_OEM SUBS_DelayNoCenter.afpx.pdf (1.9 KB, 586 views)
File Type: pdf fhlh_Jan 18_HiFi.BSW OEM Subs_LHD.afpx.pdf (2.0 KB, 538 views)
File Type: pdf BimmerTech_F30 BSW Jenhert underseat subs_.afpx.pdf (1.9 KB, 583 views)
File Type: pdf saaltonen_F31_LHD_BavStg1+BavGhst+TrnkSub.afpx.pdf (1.9 KB, 612 views)
File Type: pdf Hyperlink - F30 BimmerTech Baseline Modified.afpx.pdf (1.7 KB, 540 views)
File Type: pdf BimmerTech - F36 Full Bavsound including Ghostsubs.afpx.pdf (1.9 KB, 822 views)
File Type: pdf BimmerTech F30 BSW S1 with BSW Ghost Subs.afpx.pdf (2.1 KB, 611 views)
File Type: pdf saaltonen_F31_LHD_BavStg1+BavGhst+TrnkSub_Revised.afpx.pdf (1.9 KB, 545 views)
File Type: pdf pacman335_LHD_BSW stage 1 + SWS.afpx.pdf (2.0 KB, 473 views)
File Type: pdf Vithy] [F30] [PP82DSP] [BAV S1] [OE Seat Subs] [TSub] - V9d.afpx.pdf (2.1 KB, 254 views)
Appreciate 3
      10-30-2015, 01:10 PM   #3
LUV335
Drives: 2012 F30 335i MPPK
Ok so I have been tuning this amp for weeks now and finally I think I have one worthwhile posting. This is a tune for BSW speakers, OEM sub, LHD. Change the file extension to .afp. I listen to all kinds of music, so I tried to get a happy medium. Its not too bright or harsh and I like loud music without it getting tiring. So here it is.
This tune is not perfect by far, so please try it out and feel free to provide any feedback.
Thanks.
      10-31-2015, 10:24 PM   #4
ronanz
ronanz's Avatar
Thanks.
VERY nice Tune!! Nicely done!!
      11-02-2015, 05:51 AM   #5
feng
feng's Avatar
Australia
128
Drives: 2014 F31 328i M-Sport AW
I tried a couple of these tunes, and I noticed that kitw, aditoakes on base set up are noticeably quiet compared to the stock bimmertech tune.
I'm not that schooled in the software, but from what I could see, the gain was set to 0 on all of them. What would cause those two tunes to be quieter?
Also, does anyone here have ASD on with the bimmertech amp? If so, how do you turn the volume on that down a bit (or is that not possible)?
Thanks
Edit: oh I have stock Hifi speakers
      11-04-2015, 11:58 AM   #6
tclardy
13
Drives: 2014 328i
Did anyone compare this to the Bimmertech BSW tune? Any comments?
Thanks,
Tim
      11-05-2015, 06:13 AM   #7
LUV335
Thanks,
Tim
I started tuning using BSW tune as a starting point. For me the BSW tune was to bright and i needed a little bass. The sound was coming from a little to the right, Now its almost directly over steering wheel. Added a little warmth, is less harsh and so on!
Everyone has different taste, you just have to try it out.
      11-05-2015, 07:11 AM   #8
tclardy
13
Drives: 2014 328i
Thanks, I am going to load it up and try it this weekend. I do like a warmer sound when possible.
Tim
      11-06-2015, 07:28 PM   #9
LUV335
Tim
Its not warm enough for my taste. But warmer than BImmertech!
      11-11-2015, 04:22 AM   #10
mightycrown
Drives: f31 320d black sport
Does anyone have tunes with Focal KRS 100?
      11-19-2015, 06:23 AM   #11
diogodasilva
Drives: BMW 328i M SPORT 2015
Thanks
did you check each channel separately?
the gain is set individually on each channel
      11-19-2015, 07:11 PM   #12
feng
feng's Avatar
Australia
128
Heya.
Thanks for the reply.
Yeah I noticed that the Gain was down to like -8 on each of the channels. Even when i pushed everything back up to closer to 0, it still didn't seem as 'loud' as the Bimmertech stock one. I did notice that I could leave ASD on up to about -4 though so i might have to tweak my own tune. The tune I was using was going a bit spazzo after I upped just the gain.
Time to do some reading I think.
      12-08-2015, 08:08 PM   #13
chums
17
Drives: 328
can someone give me a quick tutorial on how to load a tune in the software?
      12-08-2015, 08:44 PM   #14
ronanz
ronanz's Avatar
At the top of equalizer, you'll have "Setup A" and "Setup B". Right click on "Setup A" and choose file from your computer to upload to EQ. Be sure to save file to EQ before closing program
      12-08-2015, 09:16 PM   #15
chums
17
Drives: 328
aah, the infamous right click. thanks. got it. now i gotta learn this software. my front left tweeter doesn't seem to be working or it could be just the tune. i'm using bimmertech bsw tune.
      12-08-2015, 10:26 PM   #16
fhlh
fhlh's Avatar
Drives: 2013 BMW 335i M-Sport
2013 BMW 335i  [0.00]
Stock Hi-Fi tune based off the BimmerTech above. In the original, the center seems pretty up front and powerful. I tried to tame it by cutting the upper end of the speaker. Here it is, you might like it, you might not
2013 335i M-Sport 8spA
2011 M-B GLK350
2000 Dodge Ram 2500 QC 4x4 CTD
      12-10-2015, 02:33 AM   #17
AditOakes
Drives: BMW 320i F30 Sportline 2014
Thanks
Adjust the gains to your liking, but i suggest using that volume cause i think it matches the oem HU gain, but either way that is just a base setup running on software ver 3.11, i suggest to run on ver 3.20 and set the rear and center channel phase on 180 degree, you'll have an awesome staging and depth!
I also dont think the BSW speakers need to be EQ'd, its flat already and natural imo
      12-10-2015, 05:08 PM   #18
feng
feng's Avatar
Australia
128
oh was your hifi oem tune based on v3.x? i loaded it using 2.x and it didn't seem to complain?
      12-12-2015, 03:56 AM   #19
AditOakes
The initial tune that i made is from software 2.80, and i upgrade to 3.11 and is even better, i also try on software 3.20 but it sounds weird, i think it has phase problem, however they revise it in software 3.28 and i think is the best software overall, just try them
      12-23-2015, 09:15 AM   #20
williammm
10
Drives: BMW F80 M3 (2016)
Anyone has Focal setup with Jehnert underseat?
Focal IFBMW-S, IFBMW-C, Jehnert XE200R.
Would love to have ur setup file.
      12-23-2015, 08:16 PM   #21
MSportTune2
Aland Islands
80
Drives: F30 MSport
Thanks for starting this wonderful thread.
I guess I am going to be the odd one here.
My 4 days old set up is currently BimmerTech amp powering 14 HK speakers and 2 base subs on a RHD car. I have not tune as I am waiting for my stage 1 and ghost underseat sub which missed the install date. I am very impressed with the current sound after coding to HIFI. I may decide to get a professional to tune my car due to lack of similar set ups here as I am a noob in tuning. If I get a good tune done up, I will share. Again, a wonderful community here! Keep up the good work!
Merry Christmas and Happy and safe holiday!
Cheers.
      12-28-2015, 12:22 PM   #22
330i-M-sport
330i-M-sport's Avatar
Drives: 2014 bmw 320i
Is there a tune for stock hifi system?
