BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > 10.25" Android 9/10 HU theming and discussion
Studio RSR
      05-24-2020, 07:05 AM   #45
RedErik
RedErik's Avatar
Scotland
1024
Drives: E63 645Ci
2004 E63 645Ci  [0.00]
By a popular demand I have added two additional rev counters to my ID7 theme. Now you can choose from 3 options: 5k, 5.5k and 7k rpm red line. Mega folder updated - download whichever you like and simply change its name to id7_btn_dial.png
      05-24-2020, 09:36 AM   #46
kenza750
kenza750's Avatar
Netherlands
16
Drives: BMW 525d E61
Cool!
Matches the Diesel engines.
Diesel4ever
      05-24-2020, 09:54 AM   #47
RedErik
RedErik's Avatar
Scotland
1024
Drives: E63 645Ci
Originally Posted by kenza750 View Post
Cool!
Diesel4ever
Yep, that was the idea
However I kindly disagree with your statement regarding diesel engines. May I suggest a small correction?
15486372 the soundtrack of my life
      05-26-2020, 04:43 AM   #48
Kostisuk
Drives: Bmw e64
Ok, so I have finally finished first model for the dashboard app - E60. Only 11 left
How can we replace the default model in the app with the new model ?
      05-26-2020, 04:49 AM   #49
RedErik
RedErik's Avatar
Scotland
1024
Drives: E63 645Ci
At the moment you cannot I'm afraid. These models were intended for a standalone app and I'm still working on them. If you wish to use these in stock dashboard you would need to modify layout.xml file and this gets completed rather quick.
      05-27-2020, 01:18 AM   #50
Kostisuk
Drives: Bmw e64
I am talking about the standalone app. I am using it and its wonderful. I was wondering how we can replace the default car icon with the newer ones you are starting to provide. There will be a different apk for each model ? Thank you !
      05-27-2020, 01:35 AM   #51
RedErik
RedErik's Avatar
Scotland
1024
Drives: E63 645Ci
In this case I need to speak to daschacka. The plan was for me to finish all models first and then he would implement these in his app. But as I'm far from finished maybe he could swap images and release a version with a specific car... don't know. You see it's not just me It's a collaboration project and every aspect of it is time consuming - the core code is there, but creating these 3D models take time and then implementation which again takes some time. I will find out if we can do anything about that.
You want to use E63 image instead of your E64, right?
      05-27-2020, 10:20 AM   #52
Kostisuk
Drives: Bmw e64
I understand now. I thought we should add manually the new models and i wondered how we could do that. Of course i understand it is very time consuming. Actually I have an E64. Yes ,i put my name in the list ,but i now saw you released an e63 image so i thought i could use that until an e64 is released. Thank you so much for your effort
      05-29-2020, 04:14 PM   #53
haibn92
Drives: BMW
Boot animations and splash images
Universal boot animations along with splash images for 1240x480 units.
How to install:
1. Create OEM folder in the root directory of your SD card/USB stick
2. Copy both bootanimation.zip and splash.img to OEM folder
3. Plug in to your Android unit
4. Wait for confirmation of successful installation
5. Reboot and enjoy
Hi RedErik,
Can we use these splash for PX6? Someone has tested on PX6 devices?
      05-29-2020, 05:23 PM   #54
RedErik
RedErik's Avatar
Scotland
1024
Drives: E63 645Ci
Originally Posted by haibn92 View Post
Hi RedErik,
I don't see why not. Personally I haven't tested it as I don't have access to PX6, but this should work.
      05-31-2020, 09:48 AM   #55
haibn92
Drives: BMW
Yeah, I’m afraid to break my unit because Kri said testing was only on SD unit
      05-31-2020, 10:12 AM   #56
RedErik
RedErik's Avatar
Scotland
1024
Drives: E63 645Ci
Hmm... when boot animation doesn't work, unit then displays Linux tux image. Bootanimation.zip technically should work on a PX6 unit, however splash.img I think only works on SD.
      05-31-2020, 11:08 AM   #57
haibn92
Drives: BMW
Visually, if bootanimation is working and not for splash => what will happen on screen?
      05-31-2020, 12:07 PM   #58
RedErik
RedErik's Avatar
Scotland
1024
Drives: E63 645Ci
I think in both cases there would be Linux tux displayed. However I have not tested this so I can't tell you for sure.
      05-31-2020, 12:17 PM   #59
haibn92
Drives: BMW
Honestly, I cannot see the difference between bootanimation and splash. Take my PX6 unit for example: when booting unit shows 1st the "BMW Connect Drive" then "Android" text. So:
+) Splash = "BMW Connect Drive" text
+) bootanimation = "Android" text
Can you confirm ?
      05-31-2020, 12:45 PM   #60
RedErik
RedErik's Avatar
Scotland
1024
Drives: E63 645Ci
Honestly, I cannot see the difference between bootanimation and splash. Take my PX6 unit for exemple: when booting unit shows 1st the "BMW Connect Drive" then "Android" text. So:
Can you confirm ?
Splash - static image that you see first. In your case "BMW Connected Drive".
Boot animation - dynamic sequence / short animation. In your case "android" with animated colour change.
So splash and boot animation are two completely different things.
      06-01-2020, 03:58 PM   #61
haibn92
Drives: BMW
Hi RedErik,
I take a look in my PX6 headunit to see if there's a partition block named 'splash' or 'logo'. And here what I found at "/dev/block/bootdevice/by-name/":
View post on imgur.com
So, would I rename bootanimation => boot and splash => logo to match with OEM files ?
      06-02-2020, 12:36 AM   #62
RedErik
RedErik's Avatar
Scotland
1024
Drives: E63 645Ci
Hi RedErik,
I honestly don't know what these are but I would be very hesitant to rename any of these files. Simple reason if you're not sure what they are you could brick your unit. Safest way is to install custom bootanimation and splash is by letting unit do the job itself - plug in USB stick with bootanimation and splash in the OEM folder and let it do the thing.
      06-02-2020, 01:34 AM   #63
haibn92
Drives: BMW
I don’t change the OEM files, but rename the “custom” files to match them? Because the name is slightly different as you see (boot instead of bootanimation). Do you have a picture of your dev/block/bootdevice/by-name partition?
      06-02-2020, 03:02 AM   #64
RedErik
RedErik's Avatar
Scotland
1024
Drives: E63 645Ci
No, I don't, I might have a look later on today. But I'm almost certain that these are not the files you are look for. Bootanimation.zip is located in /system/media folder and splash.img is part of Android kernel so it's not a standalone file. The files you pointed out are most likely code - not image files.
      06-02-2020, 03:30 AM   #65
VincentZ4
VincentZ4's Avatar
France
26
Drives: BMW Z4 28i M Package - 2014
bootlogo and bootanimation on PX6-9.0
Hi ! I have a PX6-9.0 and I do not recommend to touch these files.
You risk to brick your screen.
On PX6-9.0, it is quite "simple" to change the boot logo and bootanimation.
No need to try to hack things out.
Boot logo:
- Create PNG image 1280x480
- Transform this image into bmp
- Put the logo.bmp in usb OEM folder
- Turn the device off
- Wait 15 sec
- Plug the usb in
- Let the system start
- Stop the system
- Start again
Bootanimation.zip
on PX6, you will need to use adb as root from a computer.
There are 4 steps to follow:
STEP 1: create bootanimation.zip
bootanimation.zip is a set of files as described here: https://android.googlesource.com/pla...tion/FORMAT.md
One thing to know, in the desc.txt, the last txt line is empty :
-- beginning of file --
1280 480 25
p 1 0 part0
p 0 0 part1
-- end of file --
Step 2: enable adb WIFI.
- connect the HU and computer in the same WIFI network
- go in developers options: -> enable USBdebug.
- install Terminal Emulator in your HU
- run HU Terminal Emulator and enter following commands:
> setprop persist.adb.tcp.port 5555
> setprop sys.rkadb.root 1
> reboot
When the HU is rebooted:
- launch Terminal Emulator in your HU
> ifconfig wlan0 : to know your HU address in WIFI, remember this lan address !!! like for example 192.168.0.3
Then in your computer:
> adb connect 192.168.x.x:5555 (fill in the remembered address)
> adb root
> adb disable-verity
> adb reboot
STEP 3: To have root access to your HU from your computer
in terminal command in your computer:
> adb devices (you should see your HU IP address listed, remember it)
> adb connect 192.168.x.xxx:5555 (fill in the remembered address)
> adb root
> adb remount
NOW, you have a temporary root access to your HU.
Be carefull, big power comes with big responsibility.
STEP 4: install bootanimation.zip
Put the bootanimation.zip you want to install in the root of your USB.
Computer terminal command:
> adb shell cp /storage/usb_storage/bootanimation.zip /system/media
> adb shell cp /storage/usb_storage/bootanimation.zip /data/local
> adb shell chmod 644 /system/media/bootanimation.zip
> adb shell chmod 644 /data/local/bootanimation.zip
> adb shell chmod 755 /system/media
> adb reboot
You should see the animation now !
PX6 4-32 - Android 9
RedErik1023.50
      06-02-2020, 04:21 AM   #66
haibn92
Drives: BMW
It's perfect . Merci Vincent!
