BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F34 3-Series GT (Gran Turismo) Forum > Rim and tyre specs
GetBMWParts
      03-26-2024, 04:51 PM   #1
rusb.gdan
Drives: f34
Hi, im currently running 225/45/19 front tires and 255/40/19 rear tires and i dont want to swap them.
I want to buy new rims with the following specs:
1st spec: 8.5jx19 et 30 front and 9.5jx19 et 35 rear.
2nd spec: 9jx19 et ?? front and 10jx19 et ?? rear.
My questions are the following:
-will my tires fit the 1st and 2nd specs with or without them stretching?
-what would be the perfect et’s for the 2nd spec?
NOTE: i’ve installed eibach prokit on
      03-26-2024, 09:26 PM   #2
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
Wrong forum. Post in https://f30.bimmerpost.com/forums/fo...play.php?f=423
      03-26-2024, 10:37 PM   #3
Mkesler75
35
Drives: BMW f34
1st spec you are at the max limits on tire size but would work. 2nd spec would be stretching it. Pun intended. Plenty of info with a quick google search. I run a 225/45 19 8.5 square with no issues. Also tire brands vary somewhat so may be a crap shoot trying to get a 225 on a 9” rim and certainly not reccomended. However, it’s been done.
      03-27-2024, 09:34 AM   #4
Oksamit78
Oksamit78's Avatar
272
Drives: E39, F30 & F34
1. What is perfect ET in your opinion? Everybody has different understanding of perfect ET.
For example: I wanted stock staggered 598m rims to sit level with fenders. So I've used spacers 10/12 front/rear to make the ETs 20 and 30 respectively (rims are 8"x19 ET30 and 9"x19 ET42 front/rear). I have Prokit springs installed in the front only.
2. This is a very handy and accurate tool for doing wheel/tire combinations as compare (including offsets): https://www.wheel-size.com/calc/
2003 E39 530i 5-Speed w/ M Spec, Saphire/Black, M54B30, Active Autowerke Performance Tune
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12
2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0
2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1
