05-04-2015, 12:25 PM | #8581 | |
24
Rep 179
EDIT: I read that Mini's uses NCS Expert when coding.. Last edited by Sleepwalker; 05-04-2015 at 12:36 PM.. |
05-04-2015, 12:35 PM | #8582 |
General
10445
Rep 40,789
You can test on F54/F55/F56, which are the Cooper & Cooper S Clubman. I have no idea what Cooper Paceman S.
05-05-2015, 08:51 AM | #8583 | |
10
Rep 103
you see there if you have a tcp/ip connection or not. This tool is in the ediabas package. Also had issues connection with another laptop and after I was having the engine running I could connect. Then i got a connection everytime, and even without engine running I could connect. With another laptop it was not necessary to have engine running. |
05-05-2015, 09:33 AM | #8584 | |
24
Rep 179
05-05-2015, 10:22 AM | #8585 | |
General
10445
Rep 40,789
But understand that ZGW_Search is a non functional, informational only utility. It will tell you no more than what displaying the Windows LAN Adapter Status => Details shows.
05-05-2015, 10:29 AM | #8586 |
24
Rep 179
05-05-2015, 10:32 AM | #8587 | |
24
Rep 179
05-05-2015, 10:34 AM | #8588 | |
General
10445
Rep 40,789
He then wrote how on one car he had to run motor to get IP address, and on another he did not.
05-05-2015, 01:28 PM | #8589 |
24
Rep 179
05-05-2015, 01:45 PM | #8590 |
General
10445
Rep 40,789
I think you do not try very hard:
05-06-2015, 02:57 AM | #8591 | |
24
Rep 179
The zgw_search gave me nothing but a blank page. I tryed a 3rd computer last night with no luck. I even tryed to bridge local network with wireless, and that didn't help (doesn't hurt to try :P) I want to this to work so bad! need to code my LED fogs |
05-06-2015, 03:45 AM | #8592 | |
10
Rep 103
05-06-2015, 04:03 AM | #8593 |
General
10445
Rep 40,789
Are you running this in a Virtual Machine?
05-06-2015, 04:23 AM | #8595 |
General
10445
Rep 40,789
Since you have EDIABAS, check and see if you can connect with Tool32.
First, make sure in EDIABAS.ini file to "INTERFACE = ENET" 1) Launch C:\EDIABAS\Bin\TOOL32.EXE 2) Hit F3 3) Load C:\EDIABAS\Ecu\F01.PRG 4) In the "Select Job: F01" window, select FS_LOESCHEN_FUNKTIONAL 5) Hit F5 6) "Results" window should show "JOB_STATUS = OKAY" Does it work?
05-06-2015, 04:40 AM | #8596 |
24
Rep 179
When I connect directly to my home network with an ethernet cable I get ip 193.69.160.65.
05-06-2015, 04:54 AM | #8597 | |
24
Rep 179
After loading f01.prg it says EDIABAS Fehler 162 : NET-0012: NO CONNECTION Doens't work. I'm no expert, but I think It is quite obvious that I don't get an IP-adress and not being able to connect when my LAN Adapert doesn't turn on when connecting the cable to the computer. The LAN Adapter stays disconnected. The computer doesn't register anything at all when I connect the cable to the computer. Same problem for all three computers I have tryed. Last edited by Sleepwalker; 05-06-2015 at 04:59 AM.. |
05-06-2015, 04:56 AM | #8598 | |
General
10445
Rep 40,789
And I hate to ask the obvious, but are you positive the ENET cable is making good contact in your OBDII Port?
05-06-2015, 05:19 AM | #8599 | |
24
Rep 179
I would assume the ENET cable is making good contact with the OBSII port. Pushed all the way inn and checked that is sits well. Do you know witch pins in the OBDII port in the car is Ground and Power? |
05-06-2015, 05:23 AM | #8600 | |
General
10445
Rep 40,789
05-06-2015, 05:36 AM | #8601 | |
24
Rep 179
The port got unswitched power right? |
05-06-2015, 05:42 AM | #8602 |
General
10445
Rep 40,789
I do not know if it is switched or not, but I am inclined to think it is switched. Otherwise, people with P3 Vent Gauges, etc. would never shut off, and would drain the battery.
