BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > [DIY] KAFAS2 for SLI or 5AS retrofit for F3x
GetBMWParts
      07-22-2020, 03:08 PM   #89
rickynguyen
14
Drives: Bmw F30 320i sedan
Can i use kafas2 function if i not change the windshield ?
      07-22-2020, 05:45 PM   #90
freespirit
freespirit's Avatar
83
Drives: f30 2016 BMW 328i
I don't think so.
Click appreciate if this post has helped you
Retrofits: NBT evo ID6, 6wb cluster, heated steering wheel, HUD, Kafas2 with LDW, SLI, HBA, FCW and pedestrian warning, LCW, Surround View, Parking Assist and ACC with Stop
      09-16-2020, 01:52 AM   #91
Shonky
Australia
17
Drives: F31 320i, E46 M3
I have a 2016/07 build F31. Has ACC stop and go, LDW, FCW, LCW (5DF, 5AG, 5AS) but no SLI (ie 8TH). I believe I have all the hardware required and only need a FSC to add 8TH (and maybe a software update to KAFAS2) at worse.
Does that sound correct?
If I get a FSC from those that offer them here are there any issues with it getting wiped with updates and/or no longer working? How are they different if I was able to convince BMW to even sell me one (seems unlikely in Australia).
Thanks
      10-01-2020, 03:41 AM   #92
ichooo
Bulgaria
Drives: F31
Thanks
Hello mate, I can provide you OEM FSC that will never be wiped. If you still need it let me know
      10-02-2020, 07:06 AM   #93
jkwhar
Drives: F30 328i Xdrive | F15 x35i
If anyone is interested, I have KAFAS2 camera, ECU and wiring for sale!
Did my post help? Click "Appreciate!"
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD)
      10-08-2020, 06:09 PM   #94
Shonky
Australia
17
Thumbs up for ichooo
Had a minor issue with networking being slow but he had a backup plan for that, that worked no problem. Very helpful and friendly guy.
My car had already been updated to 2020-03 so didn't need a firmware update. Seems to work well although a bit hard to tell if it's properly reading the signs or just getting the speed from the navigation so far. Need to go through some roadworks or similar to know for sure I'd say.
Does anyone know if it reads the "inverse" LED signs in tunnels etc in Australia? The ones with the black background and red/white LEDs. edit: It does appear to read them correctly but haven't hit one with an altered speed yet so not 100% if the speeds from the map or the camera.
      10-13-2020, 10:07 AM   #95
escribblings
Drives: F54 Mini Clubman
Posting in here, despite being a different model, as you guys seem to have some experience in this.
I hope you can help me.
I am retrofitting 5AS Driving Assistant and Adaptive Cruise Control 541 to a 2016 F54 Mini Clubman
Can you confirm what I need...
KAFAS was installed as standard, so I don't *think* I need a specific FLA camera. I got a bit confused when I read on NewTIS.
If the customer orders exclusively the high-beam assistant (5AC), the system is implemented with a camera and its own control unit in the inside mirror.
Then last night I re read that paragraph and noticed EXCLUSIVELY ORDERS 5AC - so I'm reading that as not in conjunction with anything else KAFAS based... Which would also explain why it's impossible to get part numbers for the mirrors with an FLA camera, if I'm correct in that assumption.
I went down a rabbit hole and now it looks like I have been getting hung up on semantics...
The F54 brochure only mentions the driving assistance 5AS and the adaptive cruise control 541 (which is only available with 5AS), not mention of 5AC at all.
So.... I have KAFAS
I have the stalk with the high-beam assist button.
I have the steering wheel buttons for Adaptive Cruise Control.
But I'm now seeing that I might also need an SAS module!
Do I need anything else?
What would show up in ISTA/ESYS if it's already installed?
Do I need to change the ABS pump? I already have Cruise control with breaking, but none of the other autonomous braking systems.
I've checked the wiring diagram.
272*1B is the connector I'm looking at. There are several unused pins and 8 for, I presume, the adaptive suspension - so I'm ignoring all those (Suspension?: 2,3,7,8,14,15,19,20 Not used: 4,5,6,10,13,16,17,22,24,25,26)
That leaves:
1 -> Z7*6B 5 30B<92 Fuse 92
9 -> X190*1V S_CAN_H S_CAN bus signal
11 -> A258*8B 12 FR_BM_2 Flexray signal
12 -> A258*8B 11 FR_BP_2 Flexray signal
18 -> Z10*7B 31 GND
21 -> X190*2V S_CAN_L S_CAN bus signal
23 -> Z7*3B 19 15N<60 Fuse 60
I'm guessing I don't need 1 of those fuses.
Lastly, I've seen comments about opening ports using tool32, can someone give me a bit more guidance on this?
Many thanks.
      12-05-2020, 08:49 AM   #96
josejoshua
Drives: f01 740i, i01 94Ah REx
Hello,
I have retrofitted kafas 2 in my i3 3/2017. The car was recently updated (09/2020). Is here somebody who can provide all FSC codes for kafas even for a car which should not have it? Will the FSC codes work with ISTA programming and will the codes be still accepted after update?
Thank you
      12-05-2020, 08:01 PM   #97
maaii11
21
Drives: Mini F54
I can help you to retrofit ACC in F54.
Yesterday I finish this job without problems.
So.... I have KAFAS
That leaves:
18 -> Z10*7B 31 GND
Many thanks.
      06-19-2021, 07:57 AM   #98
djolebrankovic
Drives: BMW F30
Thank you mate. But My camera don't have
kafas2 > 3010 > tsm_countru_variation > ece
kombi> 3003 > speed_limit_generation > sli_gen_2_npi
But I find another way to code and make SLI work.
And if someone need FSC for Kafas2 camera I can provide them, All of them. Just contact me if someone need.
Can you send me FSC for Kafas2? My car also does not have
Can you help me to get SLI working?
      07-02-2021, 02:10 PM   #99
dziurbajr
Germany
Drives: BMW F11 N47 TOURING
Hello. I have already kafas 2 5AG, 8TH but I need actived 5AS. I know that I need the 2 FSC code for 5AS
Can someone help me with that. Patient ist F11 2012 WBAMX11010DY02774
Thx for help.
      12-12-2021, 11:22 AM   #100
Jarda_V
Drives: BMW F31 320XD
Hi, I have F36 MR2015 June and thinking about KAFAS2 retrofit. The car is without ACC /stop and go. Does the collision warning system has in stage 3 also break funkcionaliity? I have read various information about it. My previous car, F31, without a manual transmission, had a braking function, but it was LCI. Thanks, Jaroslav
      04-07-2022, 08:11 AM   #101
smartens
Drives: BMW 3 Series GT F34
F34/F30 Camera Compitability
Do you think F30 and F34 KAFAS cameras are interchangeable?
I have an F34 and happen to order two cameras from an F34 and an F30, and I expected them to be different but they are not. Both cameras look identical (so LOL).
Part numbers:
6651-9281715 (F34)
6651-9278359 (F30)
The 6651-9278359 is not listed as compatible with F34 but it physically identical to the one from F34 as you can see from the photos.
Last edited by smartens; 04-07-2022 at 08:22 AM.. Reason: Linked images do not show up
      04-08-2022, 11:48 AM   #102
jkwhar
Part numbers:
6651-9281715 (F34)
6651-9278359 (F30)
I always thought it was the windshield angle difference between f30's and other f3x. Can you face them upside down and see if the angle of the cameras are the same or different?
      04-17-2022, 02:47 PM   #103
blueboy_gigel
blueboy_gigel's Avatar
Drives: BMW F30
Hey
Not wipes when you calculate test plan with ista?
      09-01-2022, 05:17 PM   #104
1aBimmer
Sweden
Drives: 530D
Hi guys..
I've done KAFAS2 retrofit on my F10 2010 and got 8TH (SLI) and 5AD (LDW) working but no matter what I tried I'm unable to get Front-end colletion warning and pedestrian warning to work..
My KAFAS2 ECU have already all 3 FSCs accepted..
but theres 2 thing that I reed in this thread that got my attention.
1. Flashing KAFAS2 (mine have I-level 2013...)
2. Haveing both 5AD and 5AS in FA when coding..
any advaice?
      09-02-2022, 03:53 AM   #105
Siki78
Siki78's Avatar
145
Drives: F30,G30
Originally Posted by 1aBimmer View Post
Hi guys..
any advaice?
You can have just one 5AD or 5AS in FA but not both. Write 5AS in FA and vo code
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
      09-03-2022, 03:45 PM   #106
1aBimmer
Sweden
Drives: 530D
I just tried it.. removed 5AD from FA and kept 5AS..
Coded KAFAS2, DKOMBI, HU_NBT2 (Evo), FRM, ICM and DSC.
LDW still worken even with 5AD removed but still getting 2 errors about Front-end coletion warning and pedestrian warning..
ISTA showes:
[E1146C] No message (display, longiyudinal dynamics managment 2, 0x33B), receiver KOMBI, transmitter KAFAS
[E07C2E] Message (status of object coordination malfunction, 0x21F) missing, receiver KAFAS, transmitter DSC/ICM.
do I miss some other ECUs I should code?
      03-11-2023, 07:49 AM   #107
artur 1234
Drives: bmw f31
Hello, can you still get OEM fsc codes for sli, if so, I'm interested. Regards
      04-03-2023, 10:52 AM   #108
mmk
Drives: F30
Hello, can you still get OEM fsc codes for 7E - BE - Bf , if so, I'm interested
      04-09-2023, 06:54 PM   #109
daMANiack
daMANiack's Avatar
Australia
27
Drives: BMW F26 X4 35d
Hi,
I need to flash Kafas2 ECU with later firmware to try and get SLI working, my 2016 BMW F48 X1 25i already has VO 8TD and SLI FSC is already accepted from factory.
As jkwhar has already asked but I couldn't see a reply to his question, will flashing the Kafas2 ECU with later firmware remove FSC codes already accepted?
Cheerz
I've been told I have to remove VO 8TD, do I then have to add 8TH and VO code?
Originally Posted by jkwhar View Post
I think I read somewhere that flashing the KAFAS 2 ecu remove/erase the FSC code, or did i misread that?
Thanks!
2016 BMW F26 X4 35d, H&R spring lowered 30mm, QUAD exhausts
      04-10-2023, 02:50 AM   #110
TheNine90
Drives: bmw
Flashing only upgrades the software files, the FSC remain untouched.
Adding 8TH is necessary.
