06-29-2014, 12:35 AM | #133 | |
General
21125
Rep 20,742
Drives: 2021 911 turbo
06-29-2014, 02:16 AM | #135 | |
Law Enforcer
25167
Rep 22,295
Drives: '22 Chalk Gray Porsche C2S
06-29-2014, 08:47 AM | #137 | |
Rainbow Racer
1008
Rep 2,540
the n55/n54 can handle up to E50 safely without a complete reflash. Anything higher will require a reflash. However, Terry@bms has always stated than gains above an E60 mixture isnt as significant as adding E30-E50, so the most "potential" in gains happens in the smaller mixture of ethanol, and decreases exponentially in gains the more you add. This mainly applies to stock fueling. Terry will find ways to add an external line booster that the JB4 can control to boost fueling needs without reflashing (though, reflashing is always recommended for best performance).
-Loe P.-
Prior Car:'14 Audi S5 3.0t DSG [ APR ECU/TCU | Pullies + basic bolt-on mods | 10.861@127.90mph ] Current Car: F82 M4cs | TT-RS | On Order: i4 M50 |
06-29-2014, 10:38 AM | #138 | |
99
Rep 2,000
The lightest E9X six-speed car I've seen (tested by Car & Driver) came in at 3552 pounds full of fuel, with the Competition Package and not much else. If memory serves, the lightly optioned DCT cars come in at around 3600 pounds (Car & Driver and others). Judging by just the single road test I've read in Motor trend, the new cars will come in just a bit lighter than those C & D cars mentioned, but not by a bunch ( a few pounds at most), and certainly far away from the 80-kilo lie that the BMW marketing mavens have come up with. Still, lighter is better, even if it's by a teensy bit. |
06-29-2014, 06:46 PM | #139 |
Rep 3,214
Drives: f25 X3 AW
Garage List 2004 e46 M3 AW RETIRED [0.00]
2003 e46 M3 CB RETIRED [0.00] 2013 f25 X3 AW [0.00] 2007 e92 328i SG RE ... [0.00] 2007 e90 335i AW RE ... [0.00] |
beautiful cars.
06-29-2014, 06:55 PM | #140 | ||
159
Rep 261
Drives: 2016 750i xDrive
2019 X3 M40i Phytonic Blue/Oyster
Past BMWs: 2016 750i xDrive 2013 335i Sedan Sport Line, 2005 645Ci Coupe 6MT, 2001 M5, 2001 540i 6MT, 2001 M Roadster |
06-29-2014, 07:47 PM | #141 | |
Rep 5,678
2020 X3 M40i | Black | Current DD
2020 C8 Corvette | Z51 | Torch Red ... built and waiting for delivery 2016 M2 | Long Beach Blue | 6MT 2015 M4 | Austin Yellow | DCT 2012 MB C63AMG | 2011 E92 M3 | 2010 E92 M3 |
06-29-2014, 07:53 PM | #142 | |
Rep 3,099
i've found non-stripper DCT idrive ones weighed at ~3550lb WITH DRIVER the kerb weight for the 'pure edition' stripper here in australia was ~3450-80lb... again, with driver afaik. i worked out, that given accurate scale measurements of an F82 vs E92 with similar options (so the E92 has CF roof), the E92 inc driver and half tank of fuel was over 200lb lighter... so unless the measurements are inconsistent or incorrect.. i guess, plenty of people unable to add and subtract? haha |
06-29-2014, 07:57 PM | #143 | |
Rep 3,099
the thing with E60 not giving gains, is the HPFP can't keep up at high power. you can't give it enough fuel to make power dual HPFP's you'll be able to make GOOD power on E85, no meth ever needed! |
06-29-2014, 08:04 PM | #144 | |
Law Enforcer
25167
Rep 22,295
06-29-2014, 08:08 PM | #145 | ||
Rep 5,678
The one thing we know... the F8X weighs less than an E9X when equipped the same way. We now also know that a complete Australian stripper weighs less than a well equipped US car
06-29-2014, 08:42 PM | #146 | ||
Rep 3,099
the opposite is true, we know that F8x and E9x with similar options, the F8x weighs more (marginally, at least...).. the proof is here on these very forums. Quote:
uh no, that's not what i said i said the STRIPPER DCT in australia (aka the 'pure' edition') weighs <3500lb.. and a non-stripper (idrive, whatever else) is ~100lb more on the scales. >(...and links to magazine tested and weighed E9X's have been included in this thread). yes, and you remember some have weighed in at <3600lb.. i believe it was C&D? >Let's keep in mind that most of these F8X's are fully loaded or nearly fully loaded. We have yet to see what a stripper/low-optioned car weighs. i'm comparing it to the one in the OP, which has the same weight as an E92 with driver and half a tank (larger tank mind you!) with CF roof, DCT, upgraded stereo, whatever else... with no driver, 1/4 tank, couple more options... remember, the E92 weight i'm quoting is non-stripper with a 176lb driver, and ~30lb more fuel. the F82 has to get to say 3450lb stripper (again, i believe inc average weight driver and a half tank) to be lighter than an E92 stripper. Last edited by flinchy; 06-29-2014 at 08:47 PM.. |
06-29-2014, 08:45 PM | #147 | |
Rep 5,678
So, I think you need to post a picture of something to prove 3,550 for an E90 with DCT with decent options WITH a driver or it is simply not credible IMO. Nothing personal but I just don't see it as even remotely possible given it would be a one of a kind car.
06-29-2014, 08:52 PM | #148 | ||
Rep 3,099
not to mention the vert weighing.. what was it? 4100lb (not really useful info for this comparison, but still, M4 vert >4000lb) Quote:
https://www.google.com/search?q=e92+...on+kerb+weight that's the pure edition, 1580kg kerb weight = 3480lb. still porky imo haha. as far as i can tell that's actually *without* driver. i can't find an accurate source though.. some claim with, some claim without. doesn't seem to be a real 'standard' here... the 3550 i found googling 'e92 m3 kerb weight' and there was a few results from here, plus elsewhere. there's results of non-stripper (i believe fairly optioned even) E92 M3's without driver at 3550lb on another forum. ED: 3550 with Options: -19" wheels -M-DCT -EDC -Nav (Tech. Package) 1/4 tank of fuel. i really am curious as to the weight of a full stripper F82 though. <3450lb w/o driver would be pretty awesome. Last edited by flinchy; 06-29-2014 at 08:57 PM.. |
06-29-2014, 08:56 PM | #149 | ||
Rep 5,678
Bottom line... put a car on a scale and weigh it and let us know the options. I think you will find they are closer to 3,650 without a driver than 3,480... having said that, I'm not familiar with the "pure edition."
06-29-2014, 09:03 PM | #150 | |
Rep 3,099
could have been scales way out of calibration, but there's a handful of other people saying about the same? will have to get a similarly optioned E9x and F8x side by side same day same scales hahaha.. put to rest the debate, because you can find a variance of what.. 3500-3800lb with E90/92 M3's... depending on options, scales, driver/no driver.. 1/4 tank, half tank.. cf roof, non cf roof... what's the variance of F8x so far? we've got about 3560-70lb with a few options (not FULLY loaded though?), have there been any confirmed lower? what about higher? what's the upper limit for the F8x? Apples to apples stuff. this is beginning to sound like dynojet vs other dyno debate haha considering a 335i weighs less than that (quoted kerb weight with similar options, stock (steel?) roof), yet the N54+turbos etc. weighs MORE than an s65..?.. talking purely engines being the difference, the 335i should weigh slightly more. Last edited by flinchy; 06-29-2014 at 09:09 PM.. |
06-29-2014, 11:38 PM | #151 | |
Rep 10,407
My actual test results were not very conclusive, despite some care in the choice of the accelerometer and DAQ. There was some evidence in that data arguing for a truly zero shift time when it comes to simulation (in the S modes). There was also evidence for a drop in acceleration qualitatively like a MT shift. Using 50 ms seems like a conservative approach (i.e. not to incredibly pro M-DCT, which I am). Now that being said the performance improvements in times to speed will only change by the difference in those shift times 50 ms to 0, i.e. 0.05 seconds which is insignificant.
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK | | Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors | | Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels | | XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit | |
06-29-2014, 11:40 PM | #152 |
Rep 10,407
Guys, keep in mind the almost mind numbing array of weight specifications listed in the sticky here in this section. BMW's optimistic 1500 kg / 3300 lb thing was an empty fuel tank, no driver at best. That being said I also agree that having an E9X M3 at 3550 with driver is pretty well impossible.
06-30-2014, 06:13 AM | #153 | |
Rainbow Racer
1008
Rep 2,540
I agree with you, the dual HPFP will be able to make good power some blends of E85. The need for a line booster may not be neededfor mild mixtures , but at this moment, I think Terry is the only one who can report fuel trims as he's experimenting more and more with E85, but no fuel trim logs have been reported (yet). Can't wait for results from him soon.
-Loe P.-
06-30-2014, 07:43 AM | #154 | |
General
21125
Rep 20,742
On the E9X chassis, a DCT car will be faster due to the faster shift times in most scenarios. But I agree with you, there are more losses with the DCT and the E9X DCT made up for it through better gearing. |
dyno, eas, macht schnell, spacers, weights |
