Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > CalWaterboy's EXCELLENT New Year - E93 Suspension DIY
      03-13-2012, 12:12 PM   #1
CALWATERBOY
CALWATERBOY's Avatar
146
Drives: 2009 E93 N54
Preface: I've embedded this lengthy post with many links hoping to assist those as inexperienced as I was with the E9x when I bought my car. There's much here but it won't turn you into a mechanic! That said, this project can be done by anyone with a level of determination, a nearby Sears, and good credit.
You'll learn much though your ride may be laid up awhile - not being my daily driver, I was able to take whatever time was needed - it was a pleasure doing work at my leisure, well over a month on jack stands from start to finish. Accomplished BMW pilots have done it over a weekend. Do these mods if you can - you won't regret it - my best to ya'll!
Contents:
Beginnings
DO'S and DON'TS
Raise the vehicle on jack stands
Remove E93 undercarriage braces
R&R front wishbones and tension struts
R&R front shocks/springs [struts]
R&R front sway bar
R&R strut brace - engine compartment
Drop the rear subframe but not the exhaust
R&R rear subframe bushings
R&R rear sway bar
R&R rear wishbones and guide rods
R&R rear springs, shocks, camber arms; toe arms
Finishing touches
Appendix A - Wheel normal ride height
Appendix B - Torque Values
BEGINNINGS
It all started when I drew inspiration from replacing my vile Bridgestone Potenza RFT's w/Michelin PS2's -- like taking off a tight shoe, my life improved.
Boldened, I purchased a Wavetrac LSD and had Sonic Motorsports do the install. I immediately felt the difference - I can feel it while moving slowly down my driveway - found major performance boost in curves, especially accelerating.
I searched, found, and read the Classics....Speediance....1fastBMW....jprandkpr....a host of others; my future became clear....total suspension replacement and M strut brace mod.
One thing stood out: There are just about NO examples of E93 suspension mods.
I purchased a Bentley manual....thus began my adventure. After some study, late last year, I went ALL-IN.
Ordered: Street/School kit from Ground Control, a few miles East of Sacramento. Added end links for front sway to that order.
Ordered: M control arms, M sways, M rear subframe bushings, M strut brace, rear toe arms, and rented a bushing install tool from HP Autowerks in Santa Barbara.
Ground Control took awhile as rear E93 shocks are not the same as other models....the top mechanism adds 400 lb. Not having any in stock, I waited for Koni to make 'em in Holland and ship to Ground Control....this was unexpected, but to do it right....
Toe arms were hard to come by. But, HP Autowerks was able to supply their new toe arms fresh from the anodizing shop exactly when I happened to need 'em - good to go!
WARNING: MY SETUP IS PREDICATED ON THE PRESENCE OF A LIMITED SLIP DIFFERENTIAL - UNPREDICTABLE RESULTS MAY OCCUR IF NOT INSTALLED - GROUND CONTROL NEEDS M SWAYS WHICH NEED A LSD FOR BEST OPERATION
DO'S and DON'TS
DO acquire a comfortable creeper. I used this Craftsman 40" padded unit:
Name:  Creeper 40 in.jpg
DO use at least 2 floor jacks for this project. You'll thank yourself for that. I used this Aluminum Craftsman, pricey and works no better, just liked it; Milwaukee by far the best if used often over time:
Name:  Al Floor Jack.jpg
DO use an air driven 1/2" impact wrench. I used this Craftsman, an indispensable tool:
Name:  Craftsman Professional half inch Impact Wrench.jpg
DO use a quality 1/2" torque wrench. 3/8" will work but the longer handled 1/2" gives you more leverage; power. I used this electronic Gearwrench -- beeps when target torque is reached; accurately measures and beeps on user set angle past torque as BMW requires on some bolts. Replaced my analog breakaway wrench with this - glad I did:
Name:  Grearwrench Electronic Torque Wrench with Angle [a 50].jpg
DO dress all bolts & studs with anti-seize - I used Permatex 81343, Ace Hardware:
Name:  Permatex 81343 Anti-Seize Lubricant 133 [50].jpg
DON'T depend on floor jacks to keep your ride up! Not even close to reliable for that duty. Use a 3+ ton jack stand at each pad. They're inexpensive -- 6-7 jack stands might be used at some points in the job. Remember to use wood between the jack stand and the point of contact to prevent damage.
Name:  3 Ton Jack Stands [70].jpg
DON'T completely remove a bolt with an impact wrench - turn those last threads out by hand. If a bolt is removed under power it may rocket out of the impact socket with enough energy to damage the thread where it next makes contact. Not a happy occurrence....PITA to fix!
DON'T install a bolt using an impact wrench until well started in the threaded area. Always start threading in a bolt by hand - otherwise, you stand a chance of screwing up the threads. You don't want that!
____________________________
I bought this 3 ton Craftsman set on sale - floor jack & jack stands worked well; 36" creeper was crap, being 2-piece and too short for this tall boy with no dip in frame rails for shoulder room [see the creeper I used, above]:
Name:  3 ton jack and creeper set.jpg
I now see the above set as a poor value -- I've yet to use the uncomfortable creeper and the floor jack quickly became on/off....little fine control. On the up side, the jack stands work.
Recommend: Purchase a quality floor jack. Used way too much for low cost performance! $300+ might be a good ball park.
Recommend: 4 post lift [Example] with jack so wheels can be R&R'd. Don't yet have; purchasing when I decide where can set up. Not a 'light weight' but immensely useful.
RAISE THE VEHICLE ON JACK STANDS
The whole project took place in a warehouse space. I followed forum advice to raise my ride on 4 jack stands. They served me well, providing a very stable, safe platform for work:
Name:  Max 2012 03_06 [sm].JPG
I used Race Ramps Jack Assist Ramps to raise my rear wheels 3" - enough to slip a floor jack under the rear jack pads. Can use scrap wood to do the same thing if $ an issue. CHOCK YOUR RIDE!
Initially installed tall Race Ramps under each rear wheel [see next 2 pics] then raised front end from the center jack pad. Installed front jack stands w/2" thick wood at front side jack pads. Raised rear at the differential w/4x4 wood to provide enough loft to place jack stands w/2" thick wood at rear jack pads, then removed tall Race Ramps. Ready for work!
I didn't like the idea of my 4000 lb ride pivoting on the first two jack stands as the vehicle was raised to install the second pair. Tall Race Ramps provided the stable platform I wanted as a temporary measure.
Here are jack points. Again, use the differential as a rear center jack point, but be careful not to include the cover in the contact patch. After up on all 4 jack stands, took all wheels off.
REMOVE E93 UNDERCARRIAGE BRACES
The E93, unlike any other 3, has undercarriage bracing that must be removed. Starting in the rear, it was as simple as unbolting:
Name:  2012 01_06 [E93 Rear Brace sm].jpg
Name:  2012 01_06 Rear Center Brace Removed [sm].jpg
I removed the plastic aero tray under the front of the car - about 20 bolts - and unbolted the front E93 brace:
Name:  E93 Front Brace Unbolted [04 sm].jpg
Remove the front brace arms. Now the suspension can be accessed.
R&R FRONT WISHBONES AND TENSION STRUTS
Not much to this. Each arm is bolted at one end; needs nut removal at the other. Pull off. Replace w/M part.
Doing one side at a time, use impact wrench to remove bolts/nuts. R&R one arm before doing another - a wishbone and a tension strut for each side - view stock arms #14 & #9 here and M parts #14 & #19 here.
It's best to jack the knuckle up to normal ride height to remove/install, otherwise you'll find undue stress.
IMPORTANT: Suspension bolts should be started but not torqued until all bolts are in - give your suspension room to move so that all bolts can be fitted w/o stress - if necessary, loosen a few other bolts to achieve this. Otherwise you could cross thread a bolt!
IMPORTANT: Torque all suspension parts while at normal ride height with steering wheel centered. See Appendixes A & B.
Name:  Wheel jacked to normal ride height.jpg
Pic borrowed from 1fastBMW - thanks!
R&R FRONT SHOCKS/SPRINGS [STRUTS]
First, free wires and brake hose from the strut. Compress the springs - I used these Craftsman spring compressors:
Name:  2012 01_10 - Driver hand tighten [sm].jpg
Jacked the knuckle up & hand tightened, the easy way to do it. When fully compressed, removed the nuts from the strut studs in the engine compartment and lowered the wheel....tilted strut out for removal....CAREFUL not to scratch fender wheel well paint! Some tape the wheel well - look back 2 pics to see.
Name:  2012 01_10 - Driver strut out [sm].jpg
Now the pinch clamp must be widened. I used a 3/8 female x 1/4" male adaptor - 1/4" fits right in; turn 45 degrees. Strut lifts right out! Only good for a couple of tries - corners of the 1/4" end round easily - I went through 2 - they're inexpensive and I didn't want to wait to receive a strut spreader tool.
Thanks, mike-y, for the tip and this pic! [Post #2]
Name:  Ghetto Spreader.jpg
Name:  2012 01_10 - Driver strut pinch bolt [sm].jpg
Reverse order to install new strut - there's a button on the strut that slots through the opening in the pinch clamp - you cannot put it in wrong. Careful to be sure wiring is returned to correct route.
Remember, engine compartment nuts will be torqued when car's back on the ground with the steering wheel centered. In my case, I tightened engine compartment strut mount nuts finger tight - still have strut brace to install using those studs.
I left the gold Ground Control height adjustment collar threaded all the way up until time for ride height adjustment.
Name:  GC Strut [03 sm].jpg
R&R FRONT SWAY BAR
The front sway's easily unbolted, end links & mounts; removed. Then, a problem: How to mount w/2 part M3 sway bushings. Stock here. My solution was to rubber mallet them into place - snap! Apply silicone grease to the bushing prior to install so they can easily rotate on the sway bar. Install new M sway in reverse order.
Move both hubs to normal ride height with steering wheel centered & torque all bolts & nuts. See Appendixes A & B.
Name:  Front Sway Bushing [03 sm].jpg
Name:  Front Sway Bushing [05 sm].jpg
Name:  Front Sway Mount Installed [1 sm].JPG
R&R STRUT BRACE - ENGINE COMPARTMENT
Here's my procedure for the M strut brace, a major pain!
I followed this procedure, but was stumped when the center cast piece wouldn't go over the tab at all. No matter what. No way, no how.
Solved by slipping it in from the side, a tight fit! Perseverance carried the day.
Name:  Strut Brace 01.jpg
Name:  Strut Brace 02.jpg
Name:  Strut Brace 03.jpg
Bolted it together loosely - until back on the ground w/steering wheel centered, front suspension properly torqued, maybe the last part of this job.
DROP THE REAR SUBFRAME BUT NOT THE EXHAUST
I dropped the rear subframe 3-4" to enable rear subframe bushing & sway R&R. Support the subframe with a floor jack under the differential, again being careful not to include the diff cover in the contact patch. I placed a jack stand with 4x4 wood piece under the subframe cross member just rear of the diff; just forward of the brace mount as shown, 3-4" below the cross member [the amount of drop I want].
Name:  Rear subframe jacks.jpg
Unclip all wires at the wheels to allow slack, then disconnect brakes lines here:
Name:  Rear brake lines.jpg
Use flexible line crimps or quickly plug the flex lines to prevent draining brake fluid to your floor. DO NOT allow brake fluid to contact your paint - it will permanently damage the finish! If it does go there, don't attempt to rub it off - dab up w/paper towel.
Next, rather than dropping the exhaust, I disconnected at the flanges forward of the cats, a 4 nut removal, easy:
Name:  Exhaust forward disconnect [75].jpg
Image borrowed from jprandkpr
Also removed the reinforcement plate w/8 torx bolts:
Name:  Exhaust plate [75].jpg
Then removed the mid pipe brace, one bolt:
Name:  Exhaust mid pipe brace [75].jpg
That allowed my exhaust piping to move with the subframe drop; I supported the cats/silencers with a jack stand and section of 2x6 wood. Disconnected rubber hose operating the rear exhaust flap. When I later needed to drop one side or the other, I removed rearward hanger mounting bolts rather than muscling off the rubber hangers.
Had I dropped the exhaust, somewhat heavy, I'd of had one big matzoh there with nowhere to go! Totally in the way of my creeper, needs removal from the work area. Big pain. T'heck with that, I said.
I removed all 6 subframe bolts and g-e-n-t-l-y lowered the subframe onto my jack stand's 4x4 wood block [look 5 pics back; above].
R&R REAR SUBFRAME BUSHINGS
Next, I used HP Autowerks' subframe bushing tool to replace all four stock bushings w/M subframe bushings. It's easy enough with an impact wrench, but DON'T forget to lube your threaded rod [used 20/50 motorcycle oil....no lube = seized nut!], and please, butter your bushings with silicone grease for a sa-mooth install.
Name:  Rear bushing butter.jpg
I bought the pictured Dow Corning 111 silicone grease at WW Grainger.
All stock bushings come out from the bottom, but front M bushings go in from the top; rear M bushings go in from the bottom. HP Autowerks' tool highly recommended - <$60 rental - makes the job very easy.
R&R REAR SWAY BAR
M Sway was reputed to be a difficult R&R but critical, as it is dramatically beefier than the stock sway. I didn't find it hard at all, once I devised a way to snap the rear sway 2 part bushings together on the bar.
Simply drilled a couple of holes in bar stock - slowly tightened bolts by hand - snap! snap! The clips went right in on the bar. Use plenty of silicone grease on bushings so that they turn easily on the bar.
Do not use a rubber mallet! Rear sway bushing assy's are of very diff composition than front, and will explode like an evil jack-in-the-box if you try to mallet them together.
Scads of room to maneuver with subframe dropped 4" - a smooth install.
Name:  Rear Bushing unassy.jpg
Name:  Rear Bushing assembled.jpg
Torqued mount bolts but left end links disconnected as the much fatter M sway must be moved out of the way to R&R guide rod mount bolts at the bearing carrier.
Raise subframe and torque the 6 subframe mount bolts.
IMPORTANT: Start all subframe mount bolts by hand, then tighten all barely snug, then tighten to torque value. If you tighten each bolt to torque before starting the next, you stand a good chance of having the last bolt or two not thread in, being offset a small ammt by new bushings. Save yourself some time and frustration - follow this procedure.
Remember to re-clip wires and reconnect brake lines.
IMPORTANT:
Bleed your brakes!! [Post #30] If you get air way up in there, activate the ABS pump.
R&R REAR WISHBONES AND GUIDE RODS
On to M Suspension Arms [Parts #17 & #18]. Stock arms here.
Again, not much to this. I replaced the wishbone & guide rods.
IMPORTANT: At the rear especially, suspension bolts should be started but not torqued until all bolts are in - give your suspension room to move so that all bolts can be fitted w/o stress - if necessary, loosen a few other bolts to achieve this. Otherwise you could cross thread a bolt!
IMPORTANT: Doing one side at a time, move the wheel hub to normal ride height when removing/reinstalling bolts to avoid undue stress. See Appendixes A & B.
Move sway bar up to access guide rod bearing carrier mount bolt. R&R one arm at a time. When finished both sides, install M sway bar end links, both rear hubs at normal ride height; torque all bolts & nuts.
R&R REAR SPRINGS, SHOCKS, CAMBER ARMS; TOE ARMS
Again one side at a time, I then R&R'd shocks, springs, camber arms and toe arms.
IMPORTANT: The headlight leveling sensor is connected to the driver side rear camber arm with a rod. Disconnect before removing camber arm mount bolts or you WILL damage the sensor - think $60 and PITA trip to the parts counter. You may wish to replace the sensor with the M3 sensor to obtain the repositioned sensor arm, ready-made. Read about need for 180° change in sensor arm position on M3 camber arm install, 14 para's below.
IMPORTANT: The shocks prevent the wheels from articulating to the point of CV joint damage. When disconnecting this assy, support the bearing carrier with a jack stand. Handy point to do so just inboard of the disk, forward.
Unbolted shock & two mounting bolts; removed camber arm. Must drop exhaust some to get inboard bolt out. Dropped each side individually so did not have to drop the whole exhaust - remove hanger mount bolts/nuts on one side to accomplish this. Jack stand can be used to support freed side but I let it rest on my bod [on creeper] as I attached the camber arm; immediately reinstalled the exhaust. Then, did other side.
Springs fall right out. Spring hat pops off by tapping a bladed screwdriver in between hat & subframe. Only the top shock mounts left to unbolt and brother, that's when my troubles began!
The trunk of an E93 is, put mildly, crowded. There're hundreds of lb of hydraulic gear and roof strut to deal with - following this procedure, I attempted to remove side panels.
I swore. I screamed. I sat deep in thought....they wouldn't budge! Understand, they must be removed to R&R the shocks....all would be for naught without that.
I'l skip everything I tried; approaches were many. In the end I cut holes with my Dremel in the felted plastic panels above my struts to access the mounts.
That is not a trivial job in the trunk of an E93. Much is in the way....space cramped....Dremel a touch large....then it hit me: The E93 is uniquely suited to the job!
I raised the top part way, and all was revealed.
Name:  Rear shock mount access.jpg
I cut a hole....
Name:  Rear shock mount cutout.jpg
I discovered: WIRES!
Big danger there....do you see the abraded covering? Luckily, though I didn't know about them until after removing the cutout section, none were damaged. But forewarned is forearmed: be aware of this!
Name:  Rear shock mount cutout problem.jpg
That done, assembly w/M camber arm wasn't a problem. Attach camber arm with inboard bolt; swing up to attach shock with bolt. Tap the Ground Control sping hat into position - O-ring will hold it there reasonably well. Use a floor jack w/bit of wood between camber arm & jack to move camber arm w/attached shock & installed spring up to position.
Careful to guide the spring so that the bottom part of the hat slides into the spring. Attach to bearing carrier with bolt. Leave Ground Control gold height adjustment collars (top of spring) threaded all the way up until ride height adj time, otherwise the rear suspension may not be able to reach normal ride height, preventing the upper control arm & guide arm bolts from threading in properly at the bearing carrier.
Now you'll find the connecting rod for the Headlight Vertical Aim Control Sensor does not reach from the M3 camber arm mount!
The problem is: Sensor arm needs to be rotated 180° to connect. 335i headlight level sensor parts, rear -- M3 headlight level sensor parts, rear Unless connected your headlights will freeze in a fixed position, most often pointing up, irritating oncoming drivers. Yow! The M3 mount is significantly outboard of the 335i mount:
Name:  Offset Arm [003] [30].jpg
New part? Check electrical operation? Rather than fool around, I went KISS: Fab'd a 1.5+" offset bracket from a small piece of Ace Hardware aluminum sheet stock:
Name:  Offset Arm [012] [30].jpg
I rolled the tabs around the M3 mount for a secure fit and bolted together - viola! New mounting hole approx. where the 335i camber arm provided it. Leveling system now works, maybe a quick headlight alignment needed, easily done. No new M3 sensor; no sensor arm rotation. Just good ol' shadetree ingenuity. Did I do good?
Back to installing suspension components:
IMPORTANT: Leave bolts started but not torqued to allow suspension movement until ALL bolts are in. Only then should suspension bolts be torqued down.
Name:  RR Suspension 01 [sm].jpg
Then, toe arms -- maybe the easiest part -- zip, zip.
Name:  Toe Arm installed.jpg
Name:  Rear suspension installed TOP.jpg
FINISHING TOUCHES
End game: Meticulous double check to be sure all nuts & bolts have been correctly torqued with hubs in the normal drive position and steering wheel centered. You'll have found by this point that using a torque wrench is best done on a lift as exerting up to 122 ft lb torque w/ride on jack stands is not the easiest of tasks. Can be done, but you may struggle!
Reinstall E93 bracing, reinstall plastic front undercarriage aero sheet, torque engine compartment strut mount & strut brace bolts with all paws on the ground; do ride height adjustment.
IMPORTANT: After lowering your ride to pavement, start your engine and run your 3 couple of times back & forward a few feet to move wheels to normal drive position. Be sure your steering wheel's centered as you roll. THEN torque strut bolts. Otherwise, you may stress strut mount bolts:
Name:  2012 05_27 - Camber Plate Sheared Bolt [A] [30].jpg
Name:  2012 05_27 - Camber Plate Sheared Bolt [C] [30].jpg
I ground off the tack weld on the broken bolt; threaded in new and installed it correctly. Expecting no further trouble.
Ground Control provides for ride height adjustment -- see the gold rings on struts & spring hats [click here]? They're threaded on the red cyl to provide that adjustment. Sweet! Again, I had screwed all stops to the top of the adj cylinders before final height adjustment to allow knuckle (front) & bearing carrier (rear) movement to normal ride height while R&R'g parts.
GOLF TEE MOD
One last little thing. re: N54 -- If you crimp the rubber vacuum line to disable the driver's side exhaust flap at the rear of the car, you'll change low rpm behavior in a very pleasing way - much better modulation & torque. I did it with a plastic wire tie. Exhaust also louder, not a big plus for me as the sound isn't quite what I like, but good feedback. Known as the "Golf Tee Mod." Easily Googled - you'll find many DIY docs & YouTubes.
__________________________________________________ _
UPDATE: Uncrimped my rubber vacuum line. Found reduced back pressure resulted in lower low rpm torque which, though it seemed to enhance low rpm throttle control, yielded lower low rpm thrust and ran a touch rougher. Restoring to stock was a return to smoothness and torque, so much so that I'm skipping this mod unless/until new engine settings are figured out, maybe adj'd with JB4.
Done! Off to the alignment shop....an OUTSTANDING experience I recommend to everyone.
TOE ARM UPDATE
10 months later, clicking at my rear suspension; suspect worn toe arm Heim joints.
When cool weather's here, no click....yet. Looking into Megan toe arms - more later!
Ride height is measured from the top of the wheel well fender flange to the bottom of the wheel rim.
Front Stock Values:
16" wheel -- 22.99 in -- 584 mm
17" wheel -- 23.58 in -- 599 mm
18" wheel -- 24.09 in -- 612 mm
19" wheel -- 24.60 in -- 625 mm
Rear Stock Values:
16" wheel -- 22.24 in -- 565 mm
17" wheel -- 22.83 in -- 580 mm
18" wheel -- 23.35 in -- 593 mm
19" wheel -- 23.82 in -- 605 mm
But if you wish to work with wheels off the car, which I did, measure from the top of the wheel well fender flange to the bottom of the hub. That was 18.7" front; 18" rear on my car.
Front wheel hubs I raised to normal ride height with floor jack and a piece of 2" x 6" wood under the hub as shown in pic #5 from the beginning of this post.
Rear hubs I raised with floor jack & short length of 4" x 4" wood under the camber arm just inboard of the bearing carrier.
IMPORTANT: Ground Control suspension intended to reduce ride height maybe an inch. I did 3/4".
____________________________________ Ft Lb ________ N/M
WHEELS
Wheel Lug Nuts..........................89..........120
EXHAUST
Exhaust - forward flanges...............15...........21 - turbo
........................................33...........45 - non turbo
Exhaust - reinforcement plate...........43.5.........59 - Torque +90° [-+30°] -- 8 Torx Bolts
Exhaust - mid-pipe brace................15...........20
Exhaust - hangers - differential........26...........35 - turbo
........................................22...........30 - non turbo
Exhaust - hangers - wheel carrier.......15...........21
Exhaust - hangers - rear chassis........15...........20
M3 STRUT BRACE
Bulkhead mounting bolt...............73.75..........100
All other bolts......................25.07...........34
FRONT SUSPENSION
Sway bar end link.......................44...........60
Sway bar mount to subframe..............16...........21....M8 bolts
Tension Strut @ knuckle................122..........165
Tension Strut @ subframe................74..........100
Control Arm @ knuckle..................122..........165
Control Arm @ subframe..................74..........100
Strut Pinch Clamp.......................60...........81
REAR SUSPENSION
Brake line to hose.......................9...........12
Sway bar end link.......................42.7.........58
Sway bar mount to subframe..............16...........21 - M8 bolts
Rear subframe bushings..................73.7........100
Upper Control Arm @ bearing carrier.....73.7........100 - Torque +90°
Upper Control Arm @ subframe............73.7........100
Guide Arm @ bearing carrier.............73.7........100 - Torque +90°
Guide Arm @ subframe....................73.7........100
Camber Arm @ bearing carrier...........121.6........165
Camber Arm @ subframe..................121.6........165
Camber Arm Shock Mount..................75..........102
Upper Shock Mount.......................27...........19.9 - M10
Upper Shock Mount.......................37...........27.3 - M14
Toe link @ bearing carrier..............73.7........100
Toe link @ subframe.....................73.7........100
Disclaimer: I make no representation regarding the accuracy or advisability of any value or procedure in this post - this is what I did for my ride. Yours may be different! Other models may require other procedures and data - verify everything as for your vehicle before you do any of what I've done - you proceed at your own risk.
Appreciate 8
feuer4277.00
BSM n54iS2684.50
spidertri406.50
san40k21.00
      03-13-2012, 12:32 PM   #2
NiVeDh
NiVeDh's Avatar
Drives: '08 E90 335i, '99 E36 M3
Good write-up.
mslam0282.50
      03-13-2012, 01:33 PM   #3
AZ_08_E92
Drives: Alpine White 08 E92 328i
Originally Posted by NiVeDh
Good write-up.
+1. Been looking at Ground Control for my E92.
      03-13-2012, 01:45 PM   #4
CALWATERBOY
146
They have a good rep for matched shocks & springs; wanted yellows. Liked inclusion of rear camber arm. Jay's a character - talk to him!
      03-13-2012, 02:07 PM   #5
cvc 22349a
cvc 22349a's Avatar
Drives: 335i
Very Nice to see a susp other than what's sold by sponsored vendors on this forum. What spring rates did you select?
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS
      03-13-2012, 02:29 PM   #6
CALWATERBOY
146
Jay suggested some pretty high rates, but I mentioned that this ride's unlikely to ever see the track, as most won't let convertibles in the door anyway.
Ride comfort is important; so's handling. The compromise: 430 lb front 650 lb rear. Can change later if the mood strikes.
My 335i lacked competence, IMHO. I wanted a back road machine w/unending grip & precision, yet comfortable.
For a couple thou more I might have bought a M3 or Porsche, but I like creature comfort and didn't want to attract attention.
I have a stealth ride - moves pretty good on meth too. Like JB4's ability to move from map to map at the click of a steering wheel button on the fly....
      03-13-2012, 03:23 PM   #7
CJ421
CJ421's Avatar
1567
Drives: BMW M3
I enjoyed the write-up, thanks for posting! E93 is definitely a complicated beast. I haven't see another E93 here with M suspension parts let alone an LSD. Those toe arms + subframe bushings combined with the LSD make all the difference when accelerating! Can't put down power properly without 'em.
Kudos, and even more kudos for DIY'ing.
2024 BMW M3 Sedan Frozen Pure Grey II/Fjord Blue, 6MT
Past: 2021 Z4 M40i Frozen Grey II/Black Alcantara | 2017 F30 340i Mineral Gray/Coral Red, 6MT | 2011 E92 335i Le Mans Blue/Black, 6MT
      03-13-2012, 07:26 PM   #8
gmdoctor
20
Drives: e90
So what rates and spring lengths did you go with?
      03-13-2012, 07:41 PM   #9
CALWATERBOY
146
Had to stop by & check at the end of the day!
430 Front
650 Rear
      03-13-2012, 09:19 PM   #10
Thumperx
Drives: 335I coupe
Great write up and review, congrats! Glad to read that you got your center V bracket into place. Now i can get mine in -thanks for the tip.
Name: Blanca | 07 E92 | AW-Blk | ZSP | Alcon BBK | M3 Bits | VM RR Links | Koni | UUC Sways | V5 | Dinan CAI | ETS IC | Fge DV | ER CP | Cyba | Raden. Exh | Mod Step | Trunk Drawer | Perf LED Wheel | Illum Dr Sills | IS Shifter | Parrot | Philps D1S | 6000k fog | MTECH RR | CSL Trunk | Aero | Roof Spoiler | PSS on BBS RS-GT 19s
      03-13-2012, 09:25 PM   #11
CALWATERBOY
146
Indeed! Glad to assist.
That center bolt fastening the plastic front piece held me up for days. Wouldn't thread into the clip....diff to access....
      03-13-2012, 09:39 PM   #12
TheSubmariner
Drives: 2010 328i Monaco Blue 'vert
I appreciate your effort in posting this ... Nice.
      03-13-2012, 09:45 PM   #13
mike-y
just another bmw douche bag
Drives: 1.9L of fury
LIKE A BOSS
that was a lot of work to do all at once.. I always say I'm gonna take pictures of my work, but once I start, I always get way too dirty and involved to stop and handle a camera.
great write up! And glad someone else is spreading the word on the 1/4" adapter for the front struts.
      03-13-2012, 10:22 PM   #14
Thumperx
Drives: 335I coupe
Cal, how much time did the m3 bushings take to install?
      03-13-2012, 11:19 PM   #15
CALWATERBOY
146
It went quickly, thanks to the HP Autowerks tool. Extraction straightforward. With impact wrench, ziiiiiiiiiiip. Wasn't a same day thing as I worked on it sporadically - have a full plate elsewhere.
Positioning the bushings to go in was a little persnickety. Particularly the forward bushings, but once started, it was simply a matter of turning a nut.
Part of it was done with a ratcheting box wrench, you'll see if you get into it.
Not hard! Flows well! Rent the tool!
Can fab a tool, but scrounging & cutting parts per another post on this board makes the <$60 rental an insignificant expense. That post exists because OP couldn't get the HP Autowerks rental - they were all out....
Bit more info
      03-13-2012, 11:30 PM   #16
HP Autosport
Supreme Allied Commander
Drives: F80 M3
Good job!
      03-13-2012, 11:56 PM   #17
CALWATERBOY
146
I let Jay recommend & send....his experience is legend.
Actually don't know what springs lengths are, but strut springs left maybe 2" space between the spring and the top stop, open space, fully articulated. Rear springs no play.
That struck me odd, so I placed a call. Ground Control says it's right, and that in normal drive position there's no play. Because springs are linear, they have no preload like progressives.
Torquing bolts - on the ground maybe this weekend.
      03-14-2012, 01:00 AM   #18
intensee92
intensee92's Avatar
Drives: Your Girl Crazy.
great write up!
      03-15-2012, 09:32 AM   #19
CALWATERBOY
146
Thanks CJ and everyone else for your complements. Still tweaking and adding to my story as I remember this or that....
CJ -- you are a Wrangler guy?
      03-15-2012, 08:59 PM   #20
CJ421
CJ421's Avatar
1567
Drives: BMW M3
You're welcome. Not a Wrangler guy ... don't have the car or the jeans (assuming that's what you mean).
      03-15-2012, 09:35 PM   #21
ichi_ban
Drives: X6 50i
First off, good job and great write up. Second of all, why the hell would you cut a hole just to access the rear strut?!
@ichi_ban
      03-15-2012, 11:06 PM   #22
CALWATERBOY
146
Many thanks TS - hope it helps the next guy - coulda used some of the advice I included!
Could not get that #&*@ felted piece to come off! Bcube's cued me in with pics, but I coulda sworn I tried that. On the up side, adjustment of my yellows now a snap....
I'll buy new felted parts and install when happy with the suspension settings. Maybe a followup writeup.
