08-06-2018, 11:34 AM | #23 | |
Rep 465
Setting front camber to negative 2.5 or 3 will not only save your tires but will improve the handling dramatically.
"Racing is life. Anything before or after is just waiting." Steve MCQueen
Blubaron791434.50 |
08-06-2018, 11:41 AM | #24 | ||
Rep 4,724
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
08-18-2018, 02:25 AM | #25 | |||
256
Rep 245
Drives: F10 M5, E36 M3
BMW F10 M5
BMW E36 M3 |
08-18-2018, 05:30 AM | #26 | ||||
78
Rep 143
JG_Coupe88255.50 |
08-18-2018, 09:07 AM | #27 | |||||
256
Rep 245
BMW F10 M5
BMW E36 M3 |
08-18-2018, 10:38 AM | #28 |
Rep 3,540
JG_Coupe88255.50 |
08-18-2018, 06:43 PM | #29 |
256
Rep 245
Used a similar one that belonged to a buddy a while back. Thank you I'll check those out on Amazon prior to the next track day.
BMW F10 M5
BMW E36 M3 |
08-21-2018, 07:41 PM | #30 |
Rep 1,288
Drives: 2015 335i xdrive Msport Mbrake
I read thru the posts and for xdrive yes trail braking or what I like to do is engine braking (major down shifting) which throws the weight on the front and keeps you in the right gear to blast out of the corner... also you hit the apex different than you would in a normal RWD car.... you have AWD .... take advantage of it... here is a good video explaining different lines to take.... all in all it's a lot of fun!
08-21-2018, 08:56 PM | #31 |
Rep 1,468
Here is how both of my front tires look after 3 track days; this is my outer edge. The track is very technical. My rears look pretty good.
All tires are 5/32" Here is my alignment specs as well. Thoughts? He said he dialed in more negative in the rear due to my lowered suspension (KW V1).
2014 EBII 435ix - Stage 2+ Dragy: 0-60 3.61; 60-130 10.18
2020 MG M340ix - Dragy: 0-60 3.48 2018 LBB X4M40i - Stock Dragy: 0-60 4.85 |
08-23-2018, 07:27 PM | #32 | |
70
Rep 206
In a previous post you asked about a whether a track spec tire would help, and yes, something like the RE-71R would be more predictable and not heat up as fast. I tried out a set of the Firehawk Indy 500s on the track at the beginning of this season and they were horrible due to the same issues (heat and pressure management), and wore as bad as your tires are. They got really hot really quick, and it was impossible to find a sweat spot for tire pressure where they weren't too greasy or completely ruining the shoulders, which I eventually did. Some of this is of course driving too hard in the corners and something I'm still working on as well. However, I switched to the RE-71R (same 255/40-18 tire size on the same 18x8.5 wheels) and it was night and day. Yes, they still warm up and you need to keep and eye on pressures, and eventually they will get too hot and get somewhat greasy (and will also start "melting" a bit) but still to a much lesser degree, much more predictable, and less shoulder wear even when over-driving them. My times in autocross went up significantly and overall I had much better control of the car. I can't speak to the tires you currently have as I've never run them, but even with a treadwear of 280, you are quite a bit higher than the 200 you get with an RE-71. Note that the lower the treadwear, the quicker they will wear out, and you will be lucky to get a busy season out of a set (but you will have more fun wearing them out) . So consider them a track-day-only tire if that is possible and if you have a square wheel set you can still rotate them front to back. One last note on using Sport+ - don't. Use DSC off as you can use this to your advantage to steer out of corners as you accelerate. With the amount of power you've got, surely traction control is getting in the way, even with Sport+ and DTC. It's very difficult to lose control with DSC off and xDrive unless you upset the car by abruptly letting off the throttle. You can power through the corner and let the front pull you out, while the back steers around for you. When you get it right, it's a great feeling. Also, comfort mode will give you much more predictable throttle modulation which will allow smoother acceleration out of corners and reduce the amount of understeer if you try to accelerate too much too soon powering out of a corner. Hope this helps...just sharing some things I've learned this year |
08-24-2018, 09:30 AM | #33 |
Rep 1,468
Tons of help man. I am running a staggered setup. I do plan on getting some 18s and throwing on RE-71s next year. Its good to know that 255's square can fit. I can tell I am not doing well in my turns because i am probably putting too much power down when trying to exit and traction is kicking on. I will definitely try comfort mode with traction off.
Also, these tires are going to be replaced before next spring for the street.
08-26-2018, 08:32 AM | #34 |
78
Rep 143
Use chalk to mark the outside edge to sidewall on first 1-2 heat works well for me at autocross. Check the mark and adjust ur tire pressure right away if the wear pattern is not where you expected.
08-26-2018, 12:03 PM | #35 |
Rep 1,468
I do need to do that. If you over inflate/psi rises, does it wear more on the outside or do i have it backwards?
08-26-2018, 02:52 PM | #36 | |
78
Rep 143
Here is a quick video on how to read the chalk mark from your tires: |
