Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Tire size advice....please!
      04-13-2024, 11:31 AM   #23
oVeRdOsE.
oVeRdOsE.'s Avatar
2718
Drives: F25 E91 Audi Avnt E90 Cayenne
square is better for tire rotation.
12.5mm seems a lot, read few post on that or even measure it.
rdcobra91 ebay seller provide great spacers, using him on few of my car.
      04-13-2024, 11:44 AM   #24
_whittle
_whittle's Avatar
Drives: 2007 BMW 328xi
Good call. I’ll get the tires, put them on and then measure to the fender from there and see what feels right. Thanks for everyone’s help on this!
      04-13-2024, 12:34 PM   #25
335i54n
Drives: e90 335i, e39 m5
iirc rear oe is 8.5 et37 and 9.5 et35 is usual ez fit rec, so up to a 20mm spacer is no problem with 8 et35. would do 15mm to match front sunk in
https://www.1010tires.com/Tools/Whee...et-Calculator#
      04-15-2024, 06:18 AM   #26
wrevilo
25
Drives: 2010 E92 335i N55 6MT
Yes I would really recommend using a fitment calculator like the above to determine where the old/new wheels would sit relative to each other and figure out what size spacer is necessary.
For example I run the 19" Style 313 wheels on my LCI E92 335i and need spacers to clear my brake calipers. I run a 12mm spacer at the front and rear. However, I want to reduce this slightly at the rear as I do get some arch rub on full compression.
      04-15-2024, 04:55 PM   #27
_whittle
_whittle's Avatar
Got the tires mounted and balanced today. Absolutely love them!
      04-15-2024, 04:57 PM   #28
_whittle
_whittle's Avatar
HOWEVER, rear tires are too set in like everyone said.
It’s about 1.5 inches to the OUTSIDE of the fender. I don’t want it outside the fender and maybe I bit inside. Looking for recommendations on spacer size. Isn’t 1 inch a lot?
wrevilo25.00
      04-15-2024, 06:02 PM   #29
_whittle
_whittle's Avatar
The more appropriate measurement is 1inch from widest part of tire to INSIDE lip of fender. I guess the question is 17.5 or 20mm spacers. Knowing it’s 1inch max and staying inside.
wrevilo25.00
      04-16-2024, 03:05 AM   #30
wrevilo
25
Looks like you have room for 20mm spacers
      04-16-2024, 11:24 AM   #31
oVeRdOsE.
oVeRdOsE.'s Avatar
2718
wow that's a lot.
If you want a flush look, big spacers are needed. There's debate on that, personally I dont like big spacers, and they are illegal here anyway. I run larger tire to run smaller spacer.
If it's hubcentric, and a well known manufacturer, then go for it.
      04-18-2024, 12:27 PM   #32
_whittle
_whittle's Avatar
Went with KSP spacers that are hubcentric and came with correct lug bolt length. Nice product with good reviews. 20mm in the rear and 12mm for the front (if I decide it needs it).
Definitely flushed them out but still just inside of the fender lip!
wrevilo25.00
      04-18-2024, 06:18 PM   #33
335i54n
Thats how its supposed to be to contain the road debris. ur already 15mm past oe stock but at ur ride height (unless blown suspension) it shouldnt rub and past 20mm its rec to have bolt on spacers
      04-18-2024, 06:21 PM   #34
_whittle
_whittle's Avatar
My “!” was of excitement haha I’m thrilled with the outcome. My inflection didn’t come across. I meant “just inside of fender lip” in a good way.
Thanks for everyone’s help! I think it looks great and was the right way to do this. Ideally I would have bought 18x8.5 for the rear to reduce need for larger spacer but knowing it’s quality hubcentric with correct lug length, I think it should be fine.
335i54n295.00
      04-19-2024, 07:40 AM   #35
oVeRdOsE.
oVeRdOsE.'s Avatar
2718
I wont do that much difference of track length from front and rear axle. Having different track length on a car can be important on high speed stability.
This is why most FWD car are wider in front and RWD in rear.
Anyway, not the end of the world if you dont do 150mph+
I dont run spacers on my daily, but aggressive wheel offset instead. Had to run stretch tire
      04-19-2024, 07:44 AM   #36
oVeRdOsE.
oVeRdOsE.'s Avatar
2718
Also fixed that wheel gap
      04-19-2024, 07:48 AM   #37
_whittle
_whittle's Avatar
Nice lol
