12-27-2015, 12:10 PM | #45 | |
Rep 1,199
Drives: 2015 M3
The F80 technical documentation does not address the IHKA system (as the Germans call the HVAC). But, the F30 technical documentation does, at some length, discuss this functionality in book 4, section 16 (F30 general electronics), beginning on page 72. It is logical to assume that the F80 and F30 IKHA controls are the same, or at least very similar. http://www.bimmerpost.com/goodiesfor...ectronics1.pdf It has some really good information that I leave to the reader to digest - but here are some highlights: 1) There is a separate IKHA Control Unit, not located with the IKHA controls 2) Rear seat temperature can be adjusted. The Front Electronics Module (FEM) evaluates the signal from the rear seat area ventilation sensor and makes it available to the IKHA control unit over the CAN electronics bus 3) There are temperature sensors located in the right and left footwells, the A/C evaporator unit, the ILHA control unit in the dash, left and right ventilation ducts, and the rear seat area 4) The front and rear stratification controls (the famed Blue/Red wheel) are potentiometers that use stepper motors to adjust stepper motors to move the air flow from hot source to cold source Armed with this information, moving on to Real OEM website, the following details can be obtained: 1) The blower/microfilter are located behind the glovebox, which is also where the IKHA control unit resides 2) The IKHA temperature sensor is somewhere on the door side of the passenger dash 3) The F30 and F80 share many of the same parts, validating the assumption that they share the same IKHA controls The trail for where the temperature sensors that control the rear environment are located goes cold at that point for the documentation I can find. Hope this helps move the discussion forward in a constructive manner.
Best Regards, Robert (BMWCCA #471893)
Loreley 2015 / //M3 6MT SO over full SO, Exec,Susp & Lighting, HK & Blk 19's - ED 15 May 2015, Redelivery 23 July 2015 My photography: WWW.PBASE.COM/VONMAYR My ED Adventure http://www.vonmayredadventure.blogspot.com Last edited by vonmayr; 12-27-2015 at 02:05 PM.. |
12-27-2015, 01:28 PM | #46 | |
174
Rep 310
Drives: 2018 EB F31 2018 LG F80
Garage List 2020 BMW M2 CS [9.83]
2021 Porsche 718 Sp ... [8.50] 2021 BMW R1250GSA [0.00] 2014 Boxster S [0.00] 2013 BMW R1200GS [0.00] 2011 1 Series M Coupe [10.00] |
I lived in California for 20 years and understand the OP's issue. I have solved the problem in the past by redirecting air vents to the rear of the cabin and tinting my windows. The tint does not have to be dark if you don't want. Llumar has an excellent ceramic window film that will reduce the transmissive UV considerably. The problem is that the sun is so intense that the AC system is keeping the front of the cabin cool, but is not moving enough cool air to cool the rear of the cabin that is heating up due to the sun beaming in through the windows. It would also be interesting to know if the problem differs between freeway driving and driving less congested areas. My thinking there is that if the recirculation is set to auto, the air will recirculate if the system senses pollutants in the air, which will limit airflow. Most cars have cabin air exhaust flaps usually around the tail lights. If the air is recirculating, it is probably only doing so in the front of the cabin and poor air movement is crating uneven temperature. It is also a BMW thing, the 5 series has separate controls, and probably separate sensors in the rear compartment. I can hear a German BMW person in my head saying 'if zis feature was so important he should have bought ze 5er'. I see with the 3 Series, there are the following temperature sensors; - Evaporator - Front Right Footwell - Front Left Footwell - IHKA Unit (dash) - Ventilation Left - Ventilation Right Additionally it uses the Rain sense to also monitor solar I don't see a sensor specifically in the rear, it looks like its integrated into the rear stepper motor (baffle) mechanism. When they say "Temperature for rear-seat area ventilation can be adjusted" I think they are just talking about the hot cold dial on the vents. Looks like the "10 Saturation potentiometer for rear-seat area ventilation" is a sensor, but it is not clear if temperature is a parameter it passes. Off topic, could you imagine a system like this without multiplexed signaling? The car would weigh 300 pounds more for just wiring! No system is perfect, I am sure with some messing with the controls, the OP can solve the problem. I understand his frustration, Auto should mean just that, the system automatically takes care of managing the temperature, alas life is full of disappointments. B. Last edited by bueller; 12-27-2015 at 01:47 PM.. |
12-27-2015, 02:09 PM | #47 | |
Rep 1,199
Drives: 2015 M3
The modern CAN serial bus architecture has enabled truly staggering levels of integration and computerization of cars. For example, it's the only bus running between the FEM and the diplay unit atop the dash.
Loreley 2015 / //M3 6MT SO over full SO, Exec,Susp & Lighting, HK & Blk 19's - ED 15 May 2015, Redelivery 23 July 2015 My photography: WWW.PBASE.COM/VONMAYR My ED Adventure http://www.vonmayredadventure.blogspot.com |
12-27-2015, 05:46 PM | #48 | |
175
Rep 257
12-27-2015, 08:51 PM | #49 |
118
Rep 134
I've tinted all of my windows even the sunroof with 3M crystalline and it helps so much during the hot CA summers. Tinting all the windows has been the best thing I've done to the car as it helps tremendously with cooling down the cabin.
12-27-2015, 08:57 PM | #50 | |
215
Rep 105
12-29-2015, 10:50 AM | #51 | |
Rep 1,001
Now instead of having to muck with the recirculation button (which on older cars was a slider bar to control airflow at different vehicle speeds), if you want air you just turn the fan up or down. And you save gas. Win-Win!
