07-13-2020, 12:59 PM | #1 |
2014 435i (F32) 8SP RWD Base Mineral Gray in TX
Rep 4
Wheel Fitment for Novice
I am new to aftermarket wheels and need help and guidance with the wheels, as below, I would like to upgrade on my F32 RWD N55. If they will work, what are my limitations or additional modifications to ensure flush fitment? I realize the fronts are super aggressive but want to know will work or not. Thanks!
BMW 405M style wheels 19x9.5 ET37 5x120 72.6CB square set up |
07-13-2020, 02:49 PM | #2 |
Rep 4,374
the rears will fit fine, however you'll need a 3-5mm spacer up front so the inside lip doesn't touch the strut. 255/35/19 should be the max front tire size.
07-13-2020, 05:29 PM | #3 |
74
Rep 113
like alohasurftoad said your good on the rears to be safe you should shoot for +35 et all around thats no modification upfront. If your cool with 3 or 5 mm spacers up front than you can make the +37 work.
08-06-2020, 10:31 AM | #4 |
Rep 4
Thanks for the advice. I decided to go with 8.5 front, 9.5 rear, just to be safe.
alohasurftoad3125.50 |
19x9.5 front, 405m, f32 4 series coupe, fitment issue |
