N52 - compatible ZF auto transmissions
11-25-2021, 04:28 AM | #1 |
144
Rep 150
Hey all.
Long story short, I have a N52 car with the GM transmission, and I want to swap a 2nd gen ZF trans into it. Unfortunately, where I am (Australia), N52 E90's with 2nd gen ZF transmissions seem to be nonexistent. Does anyone know of other cars, whose 2nd gen ZF trans (e.g. E60 530i) will bolt up to an N52 E90? I haven't been able to find much info on this, so any help would be appreciated. Cheers Last edited by cheerio; 05-03-2022 at 09:38 PM.. |
11-26-2021, 07:05 AM | #2 | |
996
Rep 2,287
Maybe this will help. |
cheerio143.50 |
11-26-2021, 08:37 AM | #3 | |
464
Rep 2,773
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
11-26-2021, 09:57 AM | #4 | |
144
Rep 150
I'm toying with the idea of installing the 6HP21 from an LCI 525i, but that would take extra work to figure out the electronic shifter. I know that the TCU in the newer 6HP19's has better tuning options, but is this related to 6HP19 vs. 6HP21? |
11-26-2021, 10:18 AM | #5 |
144
Rep 150
https://www.sonnax.com/tech_resource...2-valve-bodies
according to this link, 2nd gen 6HP starts from 2006? |
11-26-2021, 01:52 PM | #6 |
Rep 852
Any 5 series with this engine will have the ZF box. Also the X5 but that's obviously xi. You might be able to get it from say a 630i or 730i if those were sold in Australia. I know they were in Europe.
Airplane Mechanic
BMW Masochist |
11-26-2021, 02:35 PM | #7 | |
Rep 657
Edit. Also looks like the ZF in the E9x was only fitted to early MSV70 cars and all 335i. Anything with the blacktop N52k MSV80 engine had the GM. All E6x had the ZF. Last edited by F31B48; 11-26-2021 at 02:47 PM.. |
11-26-2021, 02:54 PM | #8 | ||
996
Rep 2,287
BMW called this the 6HP19TU while ZF called it the 6HP 21. |
11-27-2021, 06:47 AM | #9 |
144
Rep 150
Interesting, thanks guys.
Looking on RealOEM, the 2010+ 323i/325i is listed with the ZF trans alongside the GM, but the few I found for wrecking in Aus had GM transmissions. From what I know, the MSV80 125i was built with both ZF and GM, but used the GM transmission here - correct me if I'm wrong. I suppose the E87 130i is also an option. The 630i and 730i are rare as hen's teeth around here. I'd rather not look at those except as a last resort. I guess this leaves the 525i... Did the pre-LCI E60 ever get the 6HP19TU, or is this restricted to the LCI E60 with electronic shifter? |
11-28-2021, 08:53 PM | #10 |
650
Rep 2,018
This may help
335i e92 TPC 19Ts
cheerio143.50 CornerGorillaPit238.50 |
12-06-2021, 04:27 PM | #12 |
Rep 1,922
Drives: 2011 e91
Odd that the chart shows that all E92s got the upgraded ZF trans while e90 got it with all 35 variants and e93 only got it with rear drive. The weird shit BMW does lol
2011 E91
2016 M2 - Sold 2014 X1 - Sold 2002 Land Rover Discovery II - 3" lift & 33s |
12-06-2021, 08:37 PM | #14 |
650
Rep 2,018
Good point, Are there e93s w Awd?
335i e92 TPC 19Ts
12-22-2021, 05:14 PM | #16 |
Rep 1,922
Drives: 2011 e91
And all Canadian E91’s after 2010 I believe also came xDrive only. XDrive was an option for pre lci and early lci
I always thought e93s could be awd but when I researched, it was never available. Guess it makes sense to not add more weight to an already portly car
2011 E91
02-15-2022, 11:30 PM | #17 |
144
Rep 150
Hey again, guys.
I’ve done a lot of research online, have asked my mechanic, etc, and have come to the conclusion that finding a E9x N52 6HP21 in Australia is impossible. I suspect it might be possible to fit a gearbox from a 335i, but the ratios wouldn’t be quite right, so I’m not liking that idea. I also made some custom extra-clicky paddle shifters recently, which just make the slow response of the GM box even more infuriating. Thus, giving up is not an option, and I’ve begun considering other gearboxes. 1. 6HP21 swap from N52 E60 LCI. Electronic shifter retrofit. 2. 8HP45 swap. Electronic shifter retrofit. The latter option is very tempting, considering the shift performance of the 8HP. I’d previously written it off as impossible without a custom TCU, but some Aussie guys seem to be having some success with it: https://youtu.be/Mhx9cP9lNIc The gist appears to be that by flashing the firmware from an E89 Z4, the gearbox will talk to the rest of the ECUs using their native E-series protocols, so that no CANbus translator or other hacks are required. I’ve done lots of work in embedded electronics before, and I’m confident that I’d be able to iron out any communication issues, given enough time to work on it. I’m not quite so confident on the mechanical side, so if anyone has experience there, some advice would be appreciated. As far as I can tell, all 8HP45’s have the same ratios, so there’s no issue there. I’m struggling to find information on 8HP bellhousing compatibility. How different are the bolt patterns for N52 and N55? What about N20? N52 8HP’s are rare around here, but there are a fair few N55 ones, and heaps of N20 boxes available. If the bolt holes are a few mm off, I guess I can Dremel them out. The N52 starter is mounted to the engine block, and mates to the flex plate ring gear. Will mounting a different transmission affect the starter fitment? Thanks guys, looking forward to hearing from you. |
02-16-2022, 11:34 AM | #18 |
464
Rep 2,773
the gearbox ratio usually adopted by rear differential
so you may try 335 box but flash id to 328i
03-29-2022, 07:37 PM | #19 |
eBay Special
3108
Rep 3,038
Drives: E90 330xi
I'm going to be attempting this (well, rather have a shop do it for me because I don't want to deal with it) here soon. Have done a good amount of research myself and the conclusion (although hairy) is that it is possible to swap a 2nd gen HP19/HP21 to the N52 in an E90.
Donor: 2008 (10/07 prod.) E92 335xi MSD81 Receiver: 2006 (10/05 prod.) E90 330xi MSV70 From my understanding, everything should physically connect and bolt up. Gear ratios are believed to be the same. There may or may not need to be some minimal modification to the bell housing for one or two of the bolts to line up. After that, alls that's needed is to program the donor vin to the DME, CAS, and TCU. Now obviously you can't use a 335 vin, and a 528/530 vin may or may not work.. But a 2nd gen 330 or 328 that has the HP19TU would in theory work. I sourced a vin from a Euro E92 330i with the HP19TU and will be coding that to everything. Hopefully that'll work. I'll then transfer my xHP and xDelete license over to the new vin (which will be interesting considering its a RWD vin) and see how it goes. If I could find a 2nd get 330xi vin I'd feel so much safer but alas..
Common sense is a flower that does not bloom in everyone's garden
04-01-2022, 12:54 AM | #20 |
144
Rep 150
Good luck! I’ve settled on retrofitting a 6HP21 from an E60 LCI. Not enough of a madlad to try the 8HP swap.
Have already got my hands on the transmission support bar and electronic gear shifter. I’m using a shifter from a DCT E82, hopefully it will talk to the 6HP… just need to buy the transmission now. |
colorado.e9x3107.50 |
04-01-2022, 02:58 AM | #21 |
eBay Special
3108
Rep 3,038
Drives: E90 330xi
Keep us updated I'm not sure when mine will get done. Still waiting on my mechanic to get back to me on quotes and setting up a time
