04-29-2019, 10:43 AM | #45 |
Rep 8,942
Post some pics when you do. I have the same thing on my F23 and am thinking another set for the F31 (but in silver this time).
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
08-29-2019, 06:21 PM | #46 | |
Rep 832
Drives: 2019 G01 X3
Also, which model are the lightest 18" wheels? |
08-29-2019, 09:01 PM | #47 | ||
346
Rep 378
275/35 18 out back on 18x9.5 EC7 245/40 18 up front on 18x9 EC7 I'm running -3 degrees of camber up front and -2 out back. Fender liners in the front were rolled by a body shop. Specifically, the plastic and felt wheel well liners... not the quarter panel. The back is 100% stock no rolling there. I'm lowered on Ohlins with M3 LCAs and Ground Control plates up front. The LCA's added enough castor that a 19" wheel with a 245/40 tire would rub the front part of the wheel well when turned in... but my wheels and tires clear it by about 4mm.
/// F80 M3 CS ///
alohasurftoad3079.50 |
08-30-2019, 09:51 AM | #48 | |
Rep 832
Drives: 2019 G01 X3
How do you like the Ohlins and GC plates, particularly in terms of track handling and overall NVH? |
08-30-2019, 10:24 AM | #49 | ||
346
Rep 378
18x9 et 31 (front) 18x9.5 et 43 (rear) Ohlins are amazing... sooooo smooth. I have them on damper setting 8 of 30 (1 is full track and 30 is full comfort). I wouldn't want them any more towards comfort, if anything I'll go the other way. NVH is not noticeably different from where I was before (stock struts and Dinan springs). Honestly I can't tell a difference. The Toyo R888r's are wicked loud but that's ok... brakes are way loud too but also ok... I suppose my thought on the matter is that 'performance' comes with some sacrifices... noise being one of them
/// F80 M3 CS ///
dr.roro195.50 |
09-18-2019, 12:32 AM | #50 | |
Rep 31
Apex wheels Canada
Cheers! |
03-26-2020, 03:39 PM | #51 |
Big Turbo Boys N Girls
327
Rep 579
Do you have any pics of 19x9 ET30 SM-10 wheels in Anthracite on a lowered Black F30 or F80?
2012 F30: G25-660 Bottom Mount Mani+ DP+ Intake, CSF FMIC, VRSF CP, Walbro 450 LPFP, PR Injection with AIC 4, S63TU Injectors, Tuned with BM3, ZF Race 4 Puck and Non SSA Pressure plate, Catless, 3.5" Quad Muffler, Custom Valved Bilstein B8 + H&R SS. Max 456 WHP - 452 WTRQ. Currently tuned down to 434 WHP and 362 WTRQ to save the rods.
03-26-2020, 04:16 PM | #52 | |
3526
Rep 6,752
This is the closest picture I could find to your request: F31 328d on 19x9" ET30 SM-10 wheels in Anthracite with 245/35-19 Michelin PS4S tires. Hope this helps! -Geirsen
03-26-2020, 06:05 PM | #53 |
Rep 8,942
That looks really good! I was down to those or one other option for my F31. I have Apex on all my other cars love them.
2022 Macan S
03-27-2020, 12:33 PM | #54 |
48
Rep 101
Wheels:
Flow Formed SM-10 in anthracite 18 x 8.5 ET35 squared Tires: Michelin Pilot 4S 245/40/18 Additional Mods: M Performance yellow BBK |
alohasurftoad3079.50 visionaut1310.00 |
03-29-2020, 11:57 PM | #55 |
61
Rep 151
Loving my Apex wheels.
APEX Arc-8 19X9 ET28 19X9.5 ET 33 Tires: 245/275
03-30-2020, 04:17 PM | #58 | |
3526
Rep 6,752
For an ARC-8R square setup on an X-drive F30, I would suggest the following fitment: Front & Rear: 18x9” ET30 or ET31 with 255/35-18 tires -Front negative camber may be required depending on ride height. -Rear fender roll may be required depending on ride height and tire brand. -245/40-18 tires can be used for an easier fit. On a completely stock car, you can typically get away with a 245/40-18 as a direct fit if you are using less-aggressive street tires. However, we do still recommend a touch of camber to really dial-in this setup from a fitment perspective. If you have any questions, please do not hesitate to reach out. -Geirsen
04-06-2020, 04:14 PM | #59 |
30
Rep 42
18x9 et30 square - bring on the concavity baby
245 40R18 H&R Sports |
AndrewC198910931.00 F36Donut94.50 |
04-06-2020, 09:16 PM | #60 |
69
Rep 150
04-21-2020, 02:54 PM | #63 | |
3526
Rep 6,752
Enjoy your wheels! -Tom
04-21-2020, 03:21 PM | #64 |
3526
Rep 6,752
Mineral Grey F31 328d with APEX EC-7 Wheels
Our BMW product expert Max recently got some EC-7s for his F31 diesel daily! These wheels are a direct bolt-on fitment with stock alignment settings and OE suspension as well as H&R lowering springs!
APEX wheel and tire info:
Modifications:
04-23-2020, 11:33 PM | #65 |
94
Rep 60
Just installed some Anthracite EC-7s on my 340i! Love how it looks.
EC-7 specs: 245/40R18 MPS4S on 18x9 ET31 275/35R18 MPS4S on 18x9.5 ET43 Suspension: Stock M Sport suspension Alignment changes: None, no rubbing. Body modifications: None |
04-24-2020, 05:45 PM | #66 | |
1427
Rep 2,650
-Tom
