The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY: Install SSD in CIC
      09-30-2017, 05:17 PM   #1
Jagaer
430
Drives: 2011 E91 328xi 6MT
I wanted to create a hard drive image of my CIC, to be able to restore it in the future in case my hard drive died. Since the hard drive was out of the CIC, I figured it was a great time to upgrade to an SSD.
UPDATE - 21 Jun 21
The SSD drive was erroring out when updating the maps. I don't know if this is related to SSD life, TRIM support in QNX or some other factor. When replaced with the CF card, the map update was able to complete successfully, so this is probably a better solution now, than the mSATA card and Marvell adapter.
The Marvell based adapters are getting harder to find, however Compact Flash has now dropped in price. So I recommend getting a CF to IDE adapter sled. Note that you will need one that has both Master and Slave, as the CIC expects the IDE drive to be a Slave: https://www.amazon.ca/Syba-Connectiv.../dp/B0036DDXUM
The IDE Adapter and 128GB Compact Flash Card
The CIC expects the hard drive to have the IDE set as "slave" (This may have been the issue with other drive adapters. The CIC port captures both the IDE pins and master/slave jumper pins on the Toshiba Drive. If the mSATA to IDE sleds do not have the same jumper configuration, they would not be set to "slave" and would therefore not work)
Background
The hard drive in the CIC is a Toshiba automotive grade SSD, the MK8050GAC. https://toshiba.semicon-storage.com/...mkxx50gac.html
The only SSD I could find that was rated for automotive use (-40C - 85C) was the Micron M500IT, which costs ~$300 CAD for a 128GB drive.
Specs: https://www.micron.com/products/soli...tomotive-ssd#/
Price: https://www.digikey.ca/product-detai...643-ND/6135280
I decided to replace the hard drive with a name brand SSD, initially an M.2 840 EVO drive, but when the adapter didn't work, with an mSATA SM841.
Requirements
1. IDE to SATA or USB adapter. I used this one: https://www.aliexpress.com/item/New-...311.0.0.eyj7tI . I've got a spare that I can send out for the cost of shipping to you.
2. SATA to USB adapter, if you use the IDE to SATA adapter above. Something like this: https://www.newegg.ca/Product/Produc...SAAEgKU8fD_BwE
3. Marvell 88SA8052 mSATA adapter. These are hard to find, most of them are JMicron based, which *do not work*
I initially tried this enclosure with a JMicron Controller and the CIC refused to recognize the drive.
You want a Marvell Controller like this one
US: Addonics - http://www.addonics.com/products/adms25ide.php
UK: Lycom - https://www.scan.co.uk/products/lyco...-ide-ssd-drive
CA: https://www.amazon.ca/gp/product/B00...?ie=UTF8&psc=1
4. 128GB mSATA Drive: I used a used Samsung SM841. It isn't automotive grade, but is a Pro-level drive, so should last a long time.
5. Linux UBCD - http://www.ultimatebootcd.com/download.html . This is used to back up and format the hard drive.
6. QNX VM - http://www.qnx.com/download/feature....rogramid=21189
7. VMWare Player - https://my.vmware.com/en/web/vmware/...on_player/12_0
Assumptions
1. You are comfortable with installing computer hardware and software. You will need to boot into Linux as well as Virtual Machines. I'm doing most operatrios from Linux since it handles low level operations more transparently. (Windows typically tries to interfere, which can corrupt the drive).
2. I am running from a Linux partition, but you can run from a bootable USB, min 128GB: https://tutorials.ubuntu.com/tutoria...k-on-windows#0
3. To back up and format the partitions, you will need to boot QNX. This is easiest from the QNX provided virtual machine.
4. I am not covering either the installation of Linux as a dual boot system, or install of VMWare Player, as there are many tutorials available online.
Remove the SSD
I sat in the passenger seat for all of the following:
1. Pull the trim from the left of the Start Button. You don't need to pull it completely off, just enought to be able to remove the HVAC unit below it.
2. Remove the HVAC unit by pulling from the upper right corner. You can leave the wires connected, but I found it easier to remove the radio trim by disconnecting the three plugs.
3. Remove the radio trim by pulling from the upper left. There is a grey cable on the upper left, so you won't be able to remove it completely, but it will swing out of the way.
4. Use a Torx 9 screwdriver to remove both screws in the front face place, and pull out the HDD. It is on rails so it will get stuck if you don't pull it out straight.
Back Up the Hard Drive
5. Connect the IDE->SATA Adapter, and the SATA->USB Adapter. (My USB goes into a USB->PCIe card, to make a wonderfully long chain of adapters). Pin 1 on the adapter card goes on the side with the jumper pins (4xPins that are slightly spaced away from the rest of them)
6. Boot your Linux partition or USB (with at least 80 GB free) and back up the OEM HDD to an image file on your PC
Code:
jagaer CIC_Drive # dd if=/dev/sdc of=CIC_Drive.img status=progress
80008954368 bytes (80 GB, 75 GiB) copied, 2944 s, 27.2 MB/s
156301488+0 records in
156301488+0 records out
80026361856 bytes (80 GB, 75 GiB) copied, 2952.03 s, 27.1 MB/s
7. Disconnect the OEM Drive and store it in a safe place. Connect your new SSD, and copy the image file from the PC onto the SSD.
Code:
jagaer CIC_Drive # dd if=CIC_Drive.img of=/dev/sdc bs=64k status=progress
80021094400 bytes (80 GB, 75 GiB) copied, 579.003 s, 138 MB/s
1221105+1 records in
1221105+1 records out
80026361856 bytes (80 GB, 75 GiB) copied, 810.815 s, 98.7 MB/s
8. Check to make sure the copy worked. If you run a "parted /dev/sdc" and "print". The partitions should look like:
Code:
jagaer CIC_Drive # parted /dev/sdc
GNU Parted 3.2
Using /dev/sdc
Welcome to GNU Parted! Type 'help' to view a list of commands.
(parted) print
Model: SAMSUNG SSD SM841 mSATA (scsi)
Disk /dev/sdc: 128GB
Sector size (logical/physical): 512B/512B
Partition Table: msdos
Disk Flags:
Number  Start   End     Size    Type      File system  Flags
 1      32.3kB  80.0GB  80.0GB  extended
 5      64.5kB  60.1GB  60.1GB  logical
 6      60.1GB  63.3GB  3150MB  logical
 7      63.3GB  65.0GB  1752MB  logical
 8      65.0GB  66.2GB  1176MB  logical
 9      66.2GB  79.9GB  13.6GB  logical
10      79.9GB  80.0GB  173MB   logical
9. Put this back in your CIC and test it out. If Nav loads, you've successfully cloned the drive, and have a working adapter. If you don't want to increase the media partition, you can put the trim back in place and have a drink
Set Up the QNX VM
If you do want to extend the media partition, there are a few more steps I'm doing all of the following from the QNX Neutrino VM.
10. Download, and extract the QNX VM onto your computer. Add the QNX VM into VMWare player, using File->Open and clicking on "Neutrino650Target.vmx"
11. Boot QNX to make sure it works. Great, now shut it down.
12. Edit VM Settings, and add the UBCD to the virtual cdrom
13. To pass the SSD directly into the VM, you'll need to add new hardware. Click add -> Hard disk -> IDE -> Use a Physical Disk
14. If you're doing this from your Linux partition, you can find the address of the hard disk by performing an "ls /dev/disk/by-id"
15. Click "Use Entire Disk" then "Finish"
16. Increase the amound of RAM for the VM to 2048MB
Back Up the Existing Information
17. Start Up QNX. You may notice an "unable to mount qnx4" error message, this is due to the way BMW has configured their factory HDD. Login with "root" and no password
18. Open a terminal, and check "ls /dev" for hd1t77
19. **Bonus Info** Running strings on 9283426A firmware displayed the CIC Fstab for partition mount point names.
20. Make mount points for partitions. I'm backing up all partitions, but you only need to back up hd1t77.4 and hd1t77.5.
Code:
mkdir hbnavi
mkdir hbcddb
mkdir hbdata
mkdir hbuser
mkdir hbmedia
mkdir hbdebug
21. Mount the partitions "mount -t qnx6 /dev/hd1t77 /root/hbnavi". If you forget the "-t qnx6" it will give you a mount error - corrupted
Code:
mount -t qnx6 /dev/hd1t77.1 /root/hbcddb
mount -t qnx6 /dev/hd1t77.2 /root/hbdata
mount -t qnx6 /dev/hd1t77.3 /root/hbuser
mount -t qnx6 /dev/hd1t77.4 /root/hbmedia
mount -t qnx6 /dev/hd1t77.5 /root/hbdebug
22. I'm saving all partitions to my NAS, so I also need to mount my shared drive
Code:
fs-cifs 192.168.1.100:/other /root/other guest none
23. You only need to save hbmedia and hbdebug, but I backed up all partitions to my NAS. We need to copy those two partitions back to the drive after extending the partitions. (You may get a "set permissions" error for .boot. It is safe to ignore this error message.)
If you don't already have your 1B file, you can create it from the "data03" file from the "hbdebug" partition
24. Once all the directories are saved, umount all the partitions "umount /root/hbcddb" etc...
Code:
umount /root/hbnavi
umount /root/hbcddb
umount /root/hbdata
umount /root/hbuser
umount /root/hbmedia
umount /root/hbdebug
25. Shut down QNX and power off the VM
Extend the Partitions
26. Boot Neutrino, hit Esc, and select option 3 (CDRom Drive). You will likely have to "click" on the Black screen before you can hit Esc.
27. Browse down to "Parted Magic", and boot default settings.
28. Look at the size of the default partitions. We need this info for later.
Code:
root@partedmagic:~# fdisk -l /dev/sdb
Disk /dev/sdb: 119.2 GiB, 128035676160 bytes, 250069680 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x6ad4b821
Device     Boot     Start       End   Sectors   Size Id Type
/dev/sdb1              63 156296384 156296322  74.5G  5 Extended
/dev/sdb5             126 117451214 117451089    56G 4d QNX4.x
/dev/sdb6       117451278 123604109   6152832     3G 4d QNX4.x
/dev/sdb7       123604173 127025954   3421782   1.6G 4d QNX4.x
/dev/sdb8       127026018 129323249   2297232   1.1G 4d QNX4.x
/dev/sdb9       129323313 155959019  26635707  12.7G 4d QNX4.x
/dev/sdb10      155959083 156296384    337302 164.7M 4d QNX4.x
29. Open Partition Editor. Resize /dev/sdb1 to fill the entire disk.
30. Delete /dev/sdb10 and /dev/sdb9. This is why we needed to save the information earlier. You did save it, didn't you?
31. Create a new /dev/sdb9 partition, using the following - Create as: Logical, File system: unformatted, Free space following (MiB): 170, align to MiB
32. Do the same thing for the /dev/sdb10 partition, with no free space following
33. Click "Apply Changes"
34. Open terminal and type in "fdisk /dev/sdb". If you type "p" you'll see that the first 4 partitions are Id "4d" but the two new ones we created are type "83". We need to change these to 4d.
35. Change the partition ID. Type "t", partition 9, and type 4d. Do the same thing for partition 10. Write the changes to disk by typing "w".
36. Restart back into QNX
Format and Restore Partitions
37. Format the new partitions with "mkqnx6fs /dev/hd1t77.4" and "mkqnx6fs /dev/hd1t77.5"
38. Mount the hbmedia and hbdebug partitions. I mounted them all, just to make sure that no info was lost when I increased the size of the hbmedia partition.
Code:
39. Mount the NAS file share where you saved your files.
Code:
40. Copy the files from the NAS back to the HDD. You don't need to copy the .boot partition
41. Unmount the partitions and shut down QNX.
Code:
umount /root/hbnavi
umount /root/hbcddb
umount /root/hbdata
umount /root/hbuser
Reinstall SSD
42. Reinstall the SSD back into the CIC. Before placing all trim back in place, check to make sure the Nav works - This verifies that the hbnavi partition is functioning. Then check the Media Info to see the available size. If you have more than 12GB free space, it shows as 100% free
43. Reinstall your trim and enjoy knowing you don't have an old, spinning hard drive in the CIC *and* you have more space for music.
Appreciate 19
      09-30-2017, 06:47 PM   #2
opjose
opjose's Avatar
242
Drives: 335xi
43: and that you have a backup of your CIC drive in case it ever fails.
(Results in reboots, strange behavior from the radio, screen shutting off while driving, etc.)
What an awesome post!
Deserves a permanent stickie.
Question: did you leave the battery connected while you did this?
      10-01-2017, 04:02 AM   #3
C.D.335xi
C.D.335xi's Avatar
22
Drives: 2013 X3
2014 Z4 35is  [0.00]
+1
2014 Z4 35is Deep Sea Blue - Sold
2009 E92 335i X-Drive 6MT - Sold
      10-01-2017, 11:53 AM   #4
Jagaer
430
I did leave the battery connected, in fact I didn't remove any of the connectors either. After removing the key, it appears the CIC headunit is still receiving power (it looks like a mainboard led is lit), but you can hear the hard drive spin down immediately following shutting off the car.
Unlike SATA, IDE is not hot swappable, but if the HDD is spun down it is a good bet that the heads are parked and it is safe to remove.
Also, QNX is designed for harsh environments, so it is quite tough to corrupt the QNX filesystem.
      10-02-2017, 10:09 AM   #5
W37V
[Oo=||=oO]
1103
Drives: e92n52 & f15n57
Originally Posted by Jagaer View Post
Requirements
I am bit confused with your requirements esp 1st 3. So in total I would need 3 adapters to make this work: IDE to SATA, SATA to USB, and mSATA??
      10-02-2017, 01:11 PM   #6
opjose
opjose's Avatar
242
Drives: 335xi
The CIC has an IDE interface, so you need to go from SATA to IDE, in turn if you are using an mSATA drive you need the circuit board plus enclosure.
You can avoid both of these if you purchase an IDE SSD drive (yes they are available) made for older laptops.
However this gives you a different problem. Your computer or laptop is likely NEWER with no small IDE port so you'll need to get from USB to IDE somehow, hence the third interface he lists.
I already had an IDE-USB interface thanks to a old defunct portable USB drive, and I purchased an IDE SSD drive for this purpose which brings me down to a simple USB cable for the cloning.
With his list the Marvell mSATA bay is already KNOWN to work, which is a big plus. Others report that not all IDE SSD drives work.
      10-02-2017, 05:08 PM   #7
Jagaer
430
opjose is correct, and I can understand your confusion.
The Zheino IDE SSD (https://www.amazon.com/Zheino-128gb-...rds=zheino+ssd) is known to work with the BMW CIC, but other IDE SSDs do not, such as the SuperTalent (https://www.amazon.com/Super-Talent-...ywords=ide+ssd)
I preferred to use an mSATA SSD with mSATA-to-IDE adapter as:
1. The mSATA drive plus adapter is still cheaper than the Zheino SSD; and
2. I have no idea if the build quality of the Zheino is any good, but I do know that a Samsung Pro SSD is well made.
One Adapter Version: Zheino IDE SSD with an IDE to USB Adapter: https://www.amazon.com/UGREEN-Adapte...e+to+usb&psc=1
Two Adapter Version: Marvell mSATA to IDE Adapter and the IDE to USB Adapter above.
Three Adapter Version, as listed initially. The reason I listed the three adapter version, is because IDE to SATA and SATA to USB adapters are very common, but IDE to USB is a lot harder to find.
      10-03-2017, 02:33 AM   #8
MAN15H
MAN15H's Avatar
46
Drives: G20 BMW 330e MSport
Great post and nice write up, will have to give this a go.
      11-05-2017, 07:57 PM   #9
opjose
opjose's Avatar
242
Drives: 335xi
I finally got around to doing this.
It went very smoothly thanks to the guide above.
Note: I'm using an EIDE Zhenio drive.
The only snag I ran into was that I had to mount the drive on a computer and create a partition table so the USB interface will recognize my drive. Until then even the USB status LED on my USB to EIDE adapter would not go green, meaning the drive is ready.
Any table will do, but it needs something to start with.
Once done the drive was recognized by Linux and QNX and I was off to the races.
My NAV boots up instantly now. No more delay as it comes up after starting the car.
As soon as the key is in or I start the engine, the map appears.
      01-08-2018, 09:02 AM   #10
tacaza
14
Drives: Bmw 320i
amazing post
      01-10-2018, 05:25 PM   #11
destive
Drives: 2009 BMW M3 coupe
This is a great guide! Did you see any performance improvements in loading times for apps or in navigation?
Noir883.00
      01-11-2018, 05:41 AM   #12
Jagaer
430
The only speed improvements I noticed were to zooming in/out of the map, and navigating media. Clicking through music folders took 1-2 seconds per folder, and now its near instant.
The real benefit to me was taking out the spinning hard drive, and having a backup. The added space for music is a nice bonus.
      01-11-2018, 01:32 PM   #13
Greyfox
Greyfox's Avatar
1208
Drives: 2007 328xi E91 - 330k+ (miles)
Tag....
Excellent, just what I needed for after getting my retrofit finished and system updated.
Might want to put a redirector over on the iDrive board to this post.
      01-13-2018, 09:43 PM   #14
tdli
Drives: 2007 E93 335I
Great thread and many thanks to the OP for the time and efforts.
      01-24-2018, 05:54 PM   #15
Greyfox
Greyfox's Avatar
1208
Are there any specs about the mSata drives that are specific for this?
      01-24-2018, 06:34 PM   #16
Jagaer
430
All mSATA drives work, and any newer one will have TRIM/garbage collection.
However, consumer-grade devices like the 840 Pro I installed, are only approved for a temperature range of 0-70C, instead of the -30-85C range of the factory hard drive.
- 840 Pro specs: http://www.samsung.com/global/busine..._PRO_Rev12.pdf
- MK8050GAC specs: https://toshiba.semicon-storage.com/...mkxx50gac.html
- Recadata i6m specs: https://www.recadatassd.com/military-ssd/msata-i6m/
I've recently purchased and replaced the 840 Pro with an industrial SSD, Recadata i6m with an operating temperature of -40-85C,
as the 840 Pro was exhibiting some glitches at low temperatures of approx -35C. (https://www.amazon.com/RECADATA-mSAT...ds=msata+128gb)
The Recadata does work, and hasn't glitched yet in the cold weather, but I haven't had it long enough to truly recommend it. I also wouldn't recommend the 840 Pro I originally installed due to the low temperature glitching (Which likely means it will exhibit similar issues at high temperatures as well). Neither of these may affect you, depending on where you live.
The Zhenio IDE is known to work, I just didn't trust a knock-off SSD, with questionable quality. At least the Recadata I put in is a known producer of industrial equipment, which should mean good reliability.
I realize this isn't overly helpful, but thought I should add additional context.
      01-24-2018, 07:48 PM   #17
Greyfox
Greyfox's Avatar
1208
I don't think I will have to worry about that low of a temperature.... lowest it's gotten here is 0F and that was a rarity. But I'll look around. I just wanted to be able to pick up a couple of them just in case.
      01-28-2018, 10:38 AM   #18
n2siast
Drives: E93 335i M-SPORT
Anyone tried this without Linux? Want to do this but I'm not versed in Linux, nor do I have a linux machine or VM.
I have access to both Windows and MAC OS, don't want to screw anything up If I undertake this.
I'm open to paying someone to do this for me if reasonable enough.
      01-28-2018, 12:10 PM   #19
opjose
opjose's Avatar
242
Drives: 335xi
If you wish to expand the partitions you will need Linux and Qnx.
If you do not want to expand the partitions, you can do this with Clonezilla under Windows or IOS.
Windows loves to write data to a new unformatted drive which screws things up.
Your best bet is to just download Linux and create a VM as per the instructions. Once you are done just delete the VM. No big deal.
Everything is done via a command/shell prompt window anyway.
      01-29-2018, 05:58 AM   #20
Jagaer
430
n2siast Everything I performed in the instruction can be done with OSX, but as opjose stated, you do need to use the QNX VM to create the new partitions.
To make a drive image, you need an USB->IDE cable.
Your device will be different (not /dev/sdc, something like /dev/disk2), so you'll need to identify the disk with
Code:
diskutil list
and look for the device that doesn't say "APPLE". Then use that device with dd to save the drive to a disk image
Code:
dd if=CIC_Drive.img of=/dev/disk2 bs=64k status=progress
      02-22-2018, 04:31 PM   #21
Taskmaster
Japan
2465
Drives: M235i 6MT / E92 328 Msport 6MT
Is this something you do for someone (as in, I buy the HHD off you)
      02-25-2018, 05:43 PM   #22
Maniac0908
Maniac0908's Avatar
Drives: Alpine White 07 335xi Sedan
Do i initialize using MBR or GPT?
2007 335XI SEDAN // JB4 G5 // BMS METH KIT // VRSF DOWNPIPES // AFE DCI // ER CP W/ TIAL BOV // MMP SILICONE INLETS // XHP STAGE 3 AT FLASH // TREBILA BEF // BMS OCC // VRSF EXHAUST // FUEL-IT STAGE 2 LPFP // VRSF FMIC // PRECISION RACEWORKS IGNITION SYSTEM // CATUNED COILOVERS // CIC AND COMBOX RETROFIT //
