02-18-2024, 10:16 PM | #1 |
Rep 3
Hit pothole - can this be fixed or should I order a new rim?
Hi,
just bought this F32 440i Gran Coupe a few days ago. A few miles into my journey I hit a pretty bad pothole near Fremont CA on the freeway. The left front wheel is now visibly bent and the tire a bit damaged. Driving-wise it's not really noticably at the moment, but something I should probably get fixed. Question: Can this type of wheel/rim damage be fixed/straighened or not? New wheel rim would cost $499+tax (that's the cheapest I could find): https://autorimshop.com/products/201...style-w86568ms Haven't had the time to take it to a shop yet, but if you're convinced that this needs to be replaced instead of fixed I'd order the wheel already ahead. I understand the tire needs to be replaced regardless. |
02-20-2024, 08:07 AM | #3 |
Rep 16
I'm not sure if that specific damage can be fixed, but probably. My local tire place (Big-0 Tire) sent one of my wheels off to be straightened. If I recall, it was about $75 for that service
02-20-2024, 09:39 AM | #5 |
188
Rep 274
Drives: 2018 440i xDrive Gran Coupe
Had the same bend in my car on the left front wheel. Took it to a repair shop and they said they can try and bend it back but will have to grind the wheel down a bit. Had them do it but I couldn't help but notice that small spot where it was fixed, so ended up finding one on Ebay for $220.
03-12-2024, 07:41 PM | #6 |
Rep 1,381
I had this straightened..
The place I used have a 3D laser scanner with built-in sonar (not my wheel results) They heated it up, pressed it out bit by until it was near perfect, but sadly yeah they had to grind a little off the back to make it the best it can be, it drives like new now. Years ago I had a wheel that was straightened by eye and DTI runout gauge.. that never felt perfect and had a tiny bit of vibration no matter how many places I had attempt to re-balance it after.
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) |
04-03-2024, 08:48 PM | #7 |
Rep 8
If you insurance coverage includes pothole damage, I would file a claim if my deductible is less than a new wheel. I hit a pothole and decided to take the wheel to a wheel shop for straightening. Once I removed the wheel it had a hairline crack from the hit. I checked my insurance policy and pothole damage is covered. My deductible is $100 for the incident. Once the bodyshop accessed the damages....found out the strut, strut housing, etc. was damage. $5300 worth of damage.
Last edited by Seiko49; 04-03-2024 at 08:55 PM.. Reason: Click submit by accident/ needing to add more to post |
