BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY - E92 CDV (Clutch Delay Valve) Removal
      12-06-2006, 02:39 PM   #45
rkg
Drives: e90
I put mine in after sending two and then receiving one modified valve back from zeckhausen. I got my CDV's in Germany, but they can't be much more here in the states ... around 3 Euro each. So, for a total of around 10 bucks including shipping, it is the only way to go.
Shifting is much better and unless the dealer cuts apart the valve, no way they can tell. Regarding not using a valve, my e90 looked like it had enough slack to do it but did not want to risk the whole dealer issue.
      12-09-2006, 07:56 AM   #46
s4iscool
Drives: 06 330i
btw, much easier wit a Mityvac 1 man bleeding system
      12-14-2006, 06:13 PM   #47
M335i
13
Drives: F80 M3
Will the modified E90 CDV work with the E92?
      12-14-2006, 10:11 PM   #48
txusa03
Drives: TS330iPPSP6MT
lol, let have a cdv terminator meet.
under construction!
      12-17-2006, 01:56 AM   #49
850CSi
16 years and counting...
850CSi's Avatar
101
Drives: '06 325i 6MT
A couple of guys have said that they suspect the difference is really more psychological than anything. I'd like to get more opinions on this if anyone else cares to chime in....
Also, is not having one in the first place as good as having the modified one?
It's so cheap that part of me wants to try it just for the hell of it even though I'm a little skeptical.
E90 325i 6MT + E61 530xiT 6AT = N52B30*2
      01-08-2007, 06:56 PM   #50
SROC3
The limit of adhesion is my home.
SROC3's Avatar
Drives: Like a Boss.
any takers on this one? I'm pretty curious myself actually.
2019 X3 xDrive30i Glacier Silver | Cognac w/ Fine Cove | MSport | Premium | Dynamic Handling PKG | Drive Assist | HK w/ Bavsound Upgrade |
      01-08-2007, 07:05 PM   #51
Chesmu
Chesmu's Avatar
Drives: 2013 X6
2006 330i  [0.00]
2006 330i  [0.00]
as per the website, yes.
http://www.zeckhausenracing.com/
"Teach the ignorant. Ignore the stupid."
      03-07-2007, 11:23 AM   #52
teknochild
Your resident 4um troll
teknochild's Avatar
125
Drives: 335 coupe
ressurection time
i got my car and ive turned the DTC off a few times for some fun, but it seems like either
A: everyone on this forum lies and the traction is wonderfull, or
B: im burning clutch like there is no tommarow (though im not getting any of that wonderfull smell)
im guessing its B, but at the same time, i feel like its not, normally if a clutch is slipping it will rev way up and then drop down real fast, im not getting any of that, but the lack of any wheelspin what so ever is really disturbing (im not dropping the clutch but im going WOT in 1st the second i i feel its engaged) ive even waited for a bit at 1k to be absolutly sure and then floored it, same at 3k
has everyone just WAY over-exagerated the lack of traction?
the question:
could it be that the CDV is forcing the clutch to slip all the way up until i shift, (note that the car is still accelerating like a rocket though)
maybe the new tires just have a lot of traction and will lose a lot once they wear more?
RAWRrrrr
      03-09-2007, 09:45 AM   #53
Sho
Sho's Avatar
35
Drives: E90 325i 6-speed
I am doing this tomorrow....how to bleed the clutch correctly?
2006 325i Sport - SSR GT7, Euro tails, Rogue Ikon muffler/w custom 3.5" piping, Painted OEM Splitters
2005 Toyota Matrix - Commuter
      03-11-2007, 03:08 AM   #54
Sho
Sho's Avatar
35
I did it today with a friend, and we pump the break padel to let the air out. He step on both break and clutch when i open the bleeder valve. We did it couple times, and it is all good now. Now I feel I can drive manual car again :-) (over 10 years experiences with manual cars).
      03-14-2007, 06:20 PM   #55
Carlito12
Carlito12's Avatar
Drives: 07 E92 335i 6MT TiAg
ordered my modified CDV today...
hope its as good as advertised without the CDV...
will need help in removing the old one and installing the modified one.
ANY SUGGESTIONS WOULD BE GREATLY APPRECIATED.
cant do it myself cause i dont have a lift of any sort plus i am not too keen on mechanical stuff...
liitle angle eye mod or the rear fog light mod ... no prob.
but i am weary of removing the wrong pin or not bleeding correctly.
JB3 KW V2 i-Forged Senekas & ETC
      04-09-2007, 02:50 AM   #56
850CSi
850CSi's Avatar
101
I'm thinking about doing this during the summer..
      04-09-2007, 10:09 AM   #57
Maestro
Drives: 2007 335i Sedan, 2021 X3
Originally Posted by teknochild View Post
ressurection time
the question:
To get wheel spin you have to turn off both DSC/DTC, i.e hold the button for 5 secs then they are both turned off. You can smoke off the tires easily with them off, if not you need to press on the gas harder .
      04-09-2007, 10:19 AM   #58
Maestro
If you are going to remove the CDV, and do not have someone to help you or even if you do I would recommend buying a brake line vacuum bleeder, it works better then pumping the peddles and you do not get brake fluid all over the place. Remember brake fluid makes great pain remover. I have seen where people bleed brakes and with hands covered in fluid touch the cars paint. Leave a nice permanent hand mark in the paint.
http://store.summitracing.com/partde...5&autoview=sku
      04-09-2007, 02:03 PM   #59
teknochild
teknochild's Avatar
125
Drives: 335 coupe
that posts really old btw, but yea i had both off, the issue was that yes, everyone on this forum is full of shit when it comes to traction, combined with the extra traction from the tires being very new
RAWRrrrr
      04-09-2007, 02:23 PM   #60
Maestro
Sorry, your right, I thought the date said 4/7 not 3/7... I smoked off my tires with with no problem even with the CDV
      04-09-2007, 06:24 PM   #61
SoCal335i
Drives: 2007 E92-TT Jet Blk Coral Red
I did the cdv mod on the weekend and the car drives much smoother. I like it way better with the modified cdv.
      04-09-2007, 09:54 PM   #62
itsbrokeagain
itsbrokeagain's Avatar
Drives: 1999 528iT, E53 X5, E46 325xi
Originally Posted by shimshimhada View Post
The purpose of it is to protect noobs from burning up the clutch, however, it's only detrimental to people with standard experience.
Actually if you try to beat on it, it burns up the clutch. Its designed to prevent damage to the transmission from all the harsh abuse by some n00b...
And I didnt read the previous page, so I just n00bed myself by repeating what someone else did.
Since next week is my vacation, I think I will stop down in NJ and pay a visit to them and buy a modified CDV.
      04-10-2007, 10:05 AM   #63
STE92VE
STEVIL Empire
STE92VE's Avatar
Drives: Fast
Originally Posted by EvanL View Post
Hey, just removed the CDV from my 335i today. Very straightforward and much simpler than the CDV removal from my E46 M3. Steps are as follows:
1. Jack the front end up and put it on JACK STANDS. Do not get under a car that is supported by a jack only.
2. Remove the 6-or-so 8mm screws that hold the center underpanel in place. This should be the one under the transmission, with the air vent in it.
3. Release the clips from the CDV inlet, and the CDV outlet (actually the regular clutch line adapter). These clips are just small, paper-clip like clips that you'll see on some electrical connections (at least on older BMWs).
4. Remove the CDV, and install the rubber clutch line directly into the CDV adapter. Replace the spring-clip on the adapter.
5. Use a 7mm box key wrech and a friend to bleed the clutch valve. Be sure to pump the clutch a few times to get the air out of the system and into the bleed valve inbetween bleed sessions. 2-3 times should be ample.
6. Replace the aerodynamic underpanel.
7. Lower the car, and enjoy your new CDV-less shifting!
-Evan
EDIT: See post #19 for pics.
Just would like some confirmation for what I think I understand and from anyone who has done this.
The CDV is held in place only by clips and no tools are required to remove/install a modified CDV other than a screwdriver to remove the panel that covers the location?
The 7mm box wrench is used to bleed the clutch valve...turning the valve until air/fluid drips out?
2007 E92 328i 6MT-Space Gray/Black Dakota/Gray Poplar w/heated seats-PCD 4/27/07 (SOLD)
2009 E90 328i xDrive 6AT-Space Gray/Oyster Dakota/Dark Burl Walnut w/ZPP,ZCW,Xenons-ED 4/17/09 - Redelivery 5/30/09 (SOLD)
2014 E84 xDrive28i 8AT-Alpine White/Black Nevada/Silver Matte w/ZMV,ZLP,494 - DD 3/14/14 (SOLD)
      04-19-2007, 06:33 AM   #64
STE92VE
STEVIL Empire
STE92VE's Avatar
Drives: Fast
Originally Posted by boriquaguerrero View Post
:mad: :mad: :mad: :mad:
i tried to install the modified cdv it was simple but my clutch pedal is loose i bleed the system with 2 different vacum pump all the air is out but the pedal still loose. after 4 hour of messing with it, i called roadside asst the have my car, let see what happens tomorrow.
P.S. I HATE Y`ALL :mad:
Did you refill your brake fluid reservoir?
      04-19-2007, 04:26 PM   #65
STE92VE
STEVIL Empire
STE92VE's Avatar
Drives: Fast
Yes i did
Please keep us informed as to the diagnosis of your problem.
      04-22-2007, 02:24 PM   #66
MacAttack
MacAttack's Avatar
Drives: fast enough
2007 BMW  [0.00]
Maybe air is getting back in somehow. Double check it one more time and try again. Sometimes you just need time to think things over before re-attacking.
2007 E92 335i Coupe: Monaco Blue/Premium/Sports/Winter Package/Nav/CA/6MT/TT/Active Cruise/Active Steering/iPod/Rear Shade/Tint/Short Shifter/OEM Alum Pedals//
