The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY - Removing / Replace Roundel (roundel removal)
      03-30-2007, 11:05 PM   #23
Chesmu
Chesmu's Avatar
Drives: 2013 X6
2006 330i  [0.00]
2006 330i  [0.00]
the e92rear roundel has been a concern. Search for Picus' thread on "problem with e92 roundels" for details.
"Teach the ignorant. Ignore the stupid."
      05-20-2007, 08:24 PM   #24
Spazdoc
Spazdoc's Avatar
42
Drives: 2020 C63S, 2001 S4
2007 335i  [0.00]
Where do you get the grommets?
      05-20-2007, 09:25 PM   #25
E90330iS
Germany
143
Drives: BMW M4
2006 330i  [0.00]
Cool! I did the sticker mod... looks the same!
      05-20-2007, 09:57 PM   #26
wj4
Drives: E90 manual 335i
You can re use your OEM ones. I installed some new roundels last week and I didn't even bother to use a tweaser to pull the grommets out. I just slapped the new roundel on and push until it goes no further in.
      05-20-2007, 10:13 PM   #27
Chesmu
Chesmu's Avatar
Drives: 2013 X6
2006 330i  [0.00]
2006 330i  [0.00]
the grommets are re-usable if the car is new. On older cars the grommets crack over time.
      05-20-2007, 10:19 PM   #28
Spazdoc
Spazdoc's Avatar
42
2007 335i  [0.00]
Are the roundels for the 335i the same as other models? I was going to buy replacements on one site, and they said it will fit e90, but not 335i or convertible.
      05-21-2007, 01:11 AM   #29
wj4
If you have read the first and second page, you would see that there is a problem with the roundels fitting on the trunk of the E92s.
      05-21-2007, 06:50 AM   #30
Spazdoc
Spazdoc's Avatar
42
2007 335i  [0.00]
I did, but the site I am buying from said that all 335i will not fit.
      06-16-2007, 02:11 PM   #31
BMWCali
Expect the Unusual
BMWCali's Avatar
Drives: 2018 X6M
Originally Posted by sp8w View Post
A friend at the dealership offered me a great suggestion. When I went in to get a new roundel, he asked if I would like to borrow their high-tech tool to remove the old roundel. j/k
He went in the back and cut a piece of nylon strapping that they use to band pallets. It worked great because it was thin enough to get behind the roundel and strong enough not to break.
If that really works, it's a great solution. I'm going to try it later tonight. Might wait until Monday when I can get another set of grommets though. Is the roundel or grommets ununsable after taking them out?
      08-08-2007, 04:31 PM   #32
Papi
Drives: e90
I am just wondering if you guys know where to order the carbon fiber roundel?
      08-09-2007, 12:18 AM   #33
Chesmu
Chesmu's Avatar
Drives: 2013 X6
2006 330i  [0.00]
2006 330i  [0.00]
"I got it on.....E-Bay!!!!!"
(psst!....click on the link)
      08-09-2007, 02:32 AM   #34
al4m
al4m's Avatar
Drives: e90 328i - sgm
2007 328i  [0.00]
got mine on bimmerfreak.com
      02-11-2009, 04:19 PM   #35
Otto Feather
Flying Mach .92/Driving E92
Otto Feather's Avatar
Drives: '09 AW 335i E92
+1. Used a screwdriver just enough to get the credit card under roundel. Then slid the nylon strapping under the card/roundel and left it there in case strap slipped out. It did. Worked it loose. No prob.
      07-17-2009, 01:34 PM   #36
aaronmiz1989
Drives: 2007 335i
The nylon idea is the best way. Dental floss was hard (for me) to get underneath the roundel. It doesn't even have to be nylon, just something thin that won't break or scratch your car (no metal). I used a small piece of window blind that I found in my garage. Took me all but ten seconds.
      08-06-2009, 10:57 AM   #37
Bimmer /E93
In The Flesh
Bimmer /E93's Avatar
Hong Kong
18
Drives: E93 (Sold), Z4 35i on board
I got mine this afternoon...
The hood roundel, went out easy and the CF fitted perfectly.
The Trunk Roundel was slightly harder to pull out, simply because of the double side tape used... Though the CF roundel, did fit in, but I would say 95% it is not the exact fit. but you will need to be picky to complain. Yet, remain to see when it rains if water will leak inside the badge and start dripping...
The steering wheel, that was easy, I just stuck the CF on the top of the original one.. Emm.. I am not quite happy from the result; it looks a little thick, if you know what I mean... It was not just a sticker rather a CF steering wheel roundel... I am not quite sure if I will try to pull out the original one...
Emm...
      08-24-2009, 12:58 PM   #38
joed1
ED RN
joed1's Avatar
19
Drives: 2009 335xi coupe/2011 X3
This is without a doubt the easiest and least dangerous way to do it. Worked great!!!! You don't even need to use the screwdriver just slide the strapping from the top or the bottom and advance it to the middle of the emblem use both hands ans pull straight up.
Thanks.
      02-12-2010, 11:04 AM   #39
OnTheGreen
Drives: 2001 325IT
Great thread, thank you.
Quick Q, can someone verify the sizes on the hood and trunk for a 2007 328i? Just picked up last night.
Thanks
      03-27-2010, 10:17 AM   #40
RichReg
RichReg's Avatar
Drives: 2015 435Xi GC & 2000 323Ci.
Does anyone know what to do if the plastic pieces happen to snap? Both of the plastic tabs broke while I was trying to loosen them and are stuck inside the hood.
Any ideas?
      03-27-2010, 10:41 AM   #41
mike3000fl
138
Drives: 06 330i
this is exactly what my parts guy gave me when i bought mine.
i went from top to bottom though when i pulled it off since the pins behind are on the left and right.
someone had used a little silicone to the back of the roundel to keep it in place so a good tug was needed to pull it off.
      06-29-2010, 12:14 AM   #42
playstereo
Drives: BMW 335I 2008
Tried Pry the hood and dental floss and screwdriver no luck the Nylon worked like a charm.
trunk was even easier. Worked Great thanks !!!
      09-18-2010, 11:46 PM   #43
mikegronholz
Texan By The Grace of God
mikegronholz's Avatar
Ireland
Drives: 2011 335i MSport
wow ... all of the credit card and nylon talk ...
pop the hood, look directly behind the release lever. see the small hole ? see the plastic nipple in there ? that is the peg from the roundel. push it with a screw driver. that will be the peg on the right side of the roundel. now just grab hold of the roundel and pull it off. takes about 15 seconds and no possible way to scratch the paint.
      09-21-2010, 07:25 PM   #44
mikegronholz
Ireland
My appologies to all ... soooooooo ... 2011 body change !!! Confirmed tonight that this little access hole is new to 2011. So how about that ?
