TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY- Transfer case shift actuator motor servo- 5F39
      08-15-2017, 02:39 PM   #23
freon480
12:34
freon480's Avatar
57
Drives: 06 E90 325xi
Originally Posted by Moorea
Originally Posted by freon480 View Post
im a tech with a shop. ive never had these codes come up and have it be anything but the motor. if the tcase was bad internally you would know.
Thanks for the advice! As an FYI the codes are here.. Does that change your opinion at all?
Error Codes
5462 VTG: Fault, servomotor or coupling force too high
5463 VTG: Mechanism faulty
55C3 VTG: AWD limp-home control activated. No DSC specified nominal torque
5F3A DSC: Transfer case: internal
those are all right in line with the servo being bad.
      08-15-2017, 03:53 PM   #24
Moorea
Drives: 2008 BMW 335xi
Thanks again!!! Super helpful.
      10-16-2017, 12:38 AM   #25
Lotus77
Drives: E91 325xi
I have a 2006 E91 and had symptoms of hesitation when accelerating first on sharp 90 degree turns then at highway speeds and eventually in 2nd gear and above. After 4 months of this the ABS, 4x4, DSC lights come on regularly after starting to drive.
I changed the actuator motor and that did not fix it. Took apart the original motor and yes, the gears are all metal and aren't worn out. Erased all the error codes and tried to run the VTG calibration which gives 54C4 calibration faulty and 54C6 oil wear error codes. There's also a 'status of classification resistor' message showing as 'Invalid'. The resistor was reused from the original actuator.
Any advice why the VTG isn't calibrating? The 3 lights all come on now after the car is started.
      07-30-2018, 12:47 PM   #26
Spitzenpradator
Dan
Drives: 2008 335Xi Coupe
Anynews since ??? I'm afraid that is also my story ...
[FONT="Arial"][SIZE="2"]335Xi Bilstein B8 H
      08-30-2018, 09:37 AM   #27
saijin
25
Drives: BMW 328xi 2007
Well, I brought it to a mechanic and he suspected it's the transfer case that needs to be rebuilt.
Apparently my service guys never changed the TC fluid affter 160.000miles
      09-17-2018, 08:26 PM   #28
karijbrafford@gmail.com
Drives: 2006 BMW 325XI
2006 BMW 325XI  [0.00]
06 Bmw 325xi
I took mine in for those errors and after replacing the brakes and tires it is still on. 4x4, ABS and Cruise is disabled and it is only in rear wheel drive. I have read quite a bit that replacing the actuator motor fixes it. The mechanic says that is the transfer case. I just wanted to check that is what your's was doing and fixed it once you replaced it.
      09-25-2018, 03:51 PM   #29
Samiseferi
Drives: 2008 335xi
2008 335xi
I just changed my transfer case box and actuator and I'm still getting just the 4x4 light on the dash. Code keeps coming up as servomotor or coupling force too high??? Never got this before and it's the only code coming up. I have abs and traction control just dont have 4x4 never seen this before please help!!!
      07-05-2019, 06:42 AM   #30
Twinkie93
Twinkie_e92
Drives: 2008 bmw 328 xi e92
So about a year ago my dad gave me his old BMW E92 328xi coupe and got himself a new one, i've been on this site since i got the car, and have been maintinng it decently and doing minor tweeaks here and there two weeks ago i kept getting the AWD ABS 4X4 (Red BRAKE) lights and tried mino things ive read on here, however my machine came in today and i was able to plug it in and got these codes, what is my first step how can i fix it? i belive i need a new transfercase, because i've already put in new camshaft sensors, and cleaned and Vano's and next week im going to replace my spark plugs and coils they come in tomorrow but with work and class i can't do it till next week becasue i read somewhere to replace them at 100K miles well i currently have 92K miles on it when he gave it to me it had 78K and no problems so this is the first major thing i've had here are the readings.
Dynamische Stabilitaets Kontrolle / DSC
Fault Code: 005F39
Fault Explanation: istribution transmission ECU: VG - clutch position unknown. / Distribution transmission ECU: clutch position unknown. / Distribution transmission ECU: VG Disorder - clutch position unknown --- (DSC: Transfer Case: internal) / Distribution transmission ECU: VG clutch defective - clutch position unknown
Then i also got AWD - CC - ID 370
i tried unpluging fuse F20 for the DSC but it still came on the lights, it's weird tho casue when i went to read the car i put it on (On Mode) pushed the buttton without holding brake, and the Reader said car didn't have any fualt codes, it only picks up the codes when the ignition is actually on.
Thanks again guys for all the help if there's anyhing that i missed please let me know.
So as I don't to try and fix my problem today I added new spark plugs, and coils, I also tested my transfer case actuator with the electric red and black thingys (sorry I forget what that's called) and it read 1 and no other numbers which from the site I was on says it's not faulty so now back to the drawing board. 😪
      09-14-2020, 07:08 PM   #31
bimmerzeit
44
Drives: E28, E39, E90
I'm pretty sure the gear in the e90 is the same as the one for the e53?
      10-06-2020, 09:28 PM   #32
freon480
12:34
freon480's Avatar
57
it is different than x3
      10-04-2022, 11:56 PM   #33
samneedssleep
Drives: 328XI
2007 BMW 328XI  [0.00]
I hate to revive an old thread, but I am having a similar issue, I replaced the actuator motor when i bought the car about 15-20k ago and recently had my t case fluid changed less than 1k ago as I was getting a shudder, after some very spirited driving I blew the o-ring on my coolant bleeder screw and had the trifecta lights come back on shortly after seeing the low coolant light, all in the same drive( not sure if it relates but I figured I’d include it), after pulling codes I get;
5463 fracture mechanics
5F3A transfer case EGU: VG fault - clutch is in open position- RWD!
The next morning:
5F39 transfer case EGU: VG Malfunction-clutch position unknown
I have yet to get under the car due to weather conditions, but how can I tell the difference between 1) a bad t case motor 2) a bad sensor?
Thank you in advance
      10-05-2022, 08:23 AM   #34
Suvorovo
Suvorovo's Avatar
254
Drives: Broken e90 330xi 6MT
The next morning:
Did you reset the oil wear?
      05-27-2023, 01:37 PM   #35
CarManNJ
Drives: Too Many to count
Anyone know if replacing the servo motor is going to require coding on the car. I was told this my a mechanic.
      05-28-2023, 06:03 AM   #36
CarManNJ
      10-27-2023, 03:20 PM   #37
Phangnga
Drives: BMW X3
Replace TC Actuator - must switch off terminal 15 for VTG reset
Just replaced TC actuator with a new one (not Germany built). Codes 5F3A, 5463, 5F39. My Foxwell 510 says: must first switch off terminal 15, then replace the actuator, then switch on terminal 15 for VTG reset.
Where is Terminal 15, please !
      02-13-2024, 11:17 AM   #38
asearle74
Drives: 2006 330i
Coding for replaced transfer case actuator motor?
I am in the same boat. I replaced the worn gear in the actuator motor and reinstalled, but the 4x4 light is still on. Do I have to take it to a shop to get coded to accept this, or is there a workaround that doesn't require an expensive coder?
