TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY M3/OEM Upper & Lower Control Arms
      11-09-2013, 11:25 PM   #45
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
Originally Posted by chris98m3 View Post
I just installed my control arms without lifting the hub to tighten the bolts. Now its all out of wack what bolts should I tighten
Food you get a alignment after install?
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
      12-05-2013, 05:42 PM   #46
therealm3
Drives: F30 340 MSport
Thanks for the great write up. I am thinking of DIY these as it doesn’t look too hard. The only question I have is related to alignment. After installing the arms does it have more toe in or more toe out? I am guessing toe in given the knuckle was moved further out and the tie rod length stayed the same, but I am not sure. Any idea of a rough amount to adjust the rods so I can drive it to the shop from my place? It’s about 10 miles. I assume that if I lengthen or shorten each rod the same amount of turns after install the car should be driveable.
      01-19-2014, 07:53 AM   #47
F06msportmia
F06msportmia's Avatar
Drives: BMW
Just finished the install and it was slightly challenging. My car has 91K so the bolts were REALLY on there. Used some WD-40 and air tools and finally came off.
During my install I DID NOT drop the steering the rack, I saw no need at the beginning. There is one bolt that the boot is in the way but it does come out. If anyone else has insight on the steering rack drop please chime in. I am not mechanic and always looking to learn.
One thing I did notice is that the original leveling rod snapped onto the old lower control arm. The new one you need a bolt on both ends and the car only had 1 bolt so I had to run out and get one. Just a tip!
I did the M3 controls arms and Meyle HD outer tie rods. Next step is the alignment.
Thanks for this great DIY!
      02-09-2014, 08:48 AM   #48
BMWNTHZST
Enthusiast
BMWNTHZST's Avatar
194
Drives: 2015 F80 M3
2011 BMW E93 M3  [0.00]
2004 BMW M3  [9.50]
2015 BMW F80 M3  [0.00]
1997 BMW 840CI  [9.50]
2011 BMW X5 M  [10.00]
2008 BMW 335i Conve ...  [8.40]
Excellent write up Rob,
Is this for an E92 or E93 335? I have an '08 E93 with 70,000km (I'm the original owner).
I want to fix the way the car jumps to the side when going over bumps at speed as well as the terrible rebound the car has always had.
Is it safe to assume that the M3 parts from an E93 M3 are what I'm looking for. As for the springs & shocks (maybe coil overs) I'm still not sure what to do there. I don't want to break the bank on the well needed upgrade. I'm not interested in dropping the car and this car doesn't go to the track anymore.
In closing the e93 M parts I need to get would be as follows:
Upper & lower control arms
Sway bar
Strut brace (maybe)
Thanks for your advise.
2017 Porsche 718 Boxster Carerra White / Garnet Red / Black
2013 Porsche 991.1 911 Carrera S Platinum Silver Metallic / Black and Yellow accents
2014 F31 328i xDrive Alpine White / Black
      03-09-2014, 11:49 AM   #49
STONEY_M5
MAAD HEAD
STONEY_M5's Avatar
62
Drives: 2010 X5M 2013 M5
13 F10 M5  [0.00]
2010 X5M  [0.00]
07 335i  [9.26]
Completed this install and without dropping the steering rack, but now I have an issue where when I turn the steering full lock in either direction I hear a sort of popping sound. And instead of the steering trying to return back to center it try to turn in the direction the the wheels are facing most. Intermittent popping while going straight also. Any ideas what could be causing this? I have a camber plate at the top of the shocks I tried to zero them out at it got worse. Putting it back to max new camber today to see what happens. Any help would be appreciated
      03-17-2014, 07:08 PM   #50
romanonj
romanonj's Avatar
147
Drives: F80 DCT
Need alignment.. It's out of whack.
2016 F80 M3 BSM with Black interior DCT/Driver Assistance/Executive/LEDs/Adaptive/Black Wheels
2014 F32 435i xDrive AW/CR
2014 F25 X3 M-Sport Carbon Black
2011 e92 335is 2007 X3 122k miles 2006 e90 330i 132k miles
      04-07-2014, 06:59 PM   #51
parabmw
Drives: 2018 m4
how do you remove the control arm nut with the brake shield in the way?
      05-18-2014, 02:12 PM   #52
branmace
Drives: E90 330i
My thanks go to the OP!!! I installed this upgrade, yesterday, 330i E90 with 93k miles, including the Mayle HD sway bar links (ends). I did not replace the tie rods, no need at this time. I'm still due for an alignment on Monday and wanted to reach out to OP or anyone who had done it:
- Do I need to specify of the upgrade to the alignment tech?
- Does the alignment tech loosen up/tighten up the same bolts in order to have the vehicle aligned?
Thoughts to share: I did not loosen up the steering rack, bolts in the way of the tie rod boot were not that difficult to remove, and dropping the wheel (rotor) 18.7 inches from the wheel well (see OP's photo) did not make much difference in my case. Impact gun was a GODSENT, if you don't use one you're in for a challenge. I was so excited about this upgrade (and adrenalin pumped) that I replaced some additional overdue items like windshield washer pump, spark plugs, cabin filter, fuel filter, and air filter. I agree with OP that this is an absolute must upgrade for your investment. OP thank you again.
      05-18-2014, 02:18 PM   #53
branmace
Drives: E90 330i
I see this is late...did you end up using 5"or 6" extension ratchet?
      05-18-2014, 03:18 PM   #54
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
Your very welcome! The only reason for the 18.7" ride height adjustment is so the bushings are not tighten at wrong height and wear out.
ttthai28.00
      06-07-2014, 10:28 AM   #55
estover
Drives: 2007 BMW 335i
Excellent post. Thanks for the write up. I installed mine last night. Getting an alignment right way. Drives a lot different even with out an alignment.
      06-22-2014, 04:15 PM   #56
Maniac0908
Maniac0908's Avatar
Drives: Alpine White 07 335xi Sedan
Will this work on xi?
      06-26-2014, 03:52 PM   #57
Maniac0908
Maniac0908's Avatar
Anyone? Can someone give me link to xi parts?
      07-08-2014, 01:59 PM   #58
Hierlevelz
Drives: 11 AW E9X M
Just installed a set of M3 front control alarms and I used Robs DIY as a guide. However I did not remove or lower the steering rack and there was more than enough room to remove the arms. Also you need an 18mm wrench and socket for the bolts at the subframe.
I did also run into an issue where I popped the green "circlip" off the rubber boot on the lower tension rod on the subframe side. I could not get it back on without displacing the boot from the groove. I took it to a shop where a mechanic ingeniously cut the clip in half and used a 300 degree section of the clip to hold the rubber boot in place. I felt it had more than enough tension to stay in place and keep the rubber boot seated as well.
trW should have made that bushing solid like the oem. Not sure why they chose a grease filled application.
      07-08-2014, 02:40 PM   #59
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
OEM M3 and are the same way.TRW are "M" Posts with logo shaved off. I agree though, it happened to my buddies also.
      07-08-2014, 04:40 PM   #60
Hierlevelz
Drives: 11 AW E9X M
I used an impact with a deep socket and 4" extension from the top down.
      07-08-2014, 04:41 PM   #61
Hierlevelz
Drives: 11 AW E9X M
I mean oem as in original 335 I arms.
      07-08-2014, 04:57 PM   #62
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
I see
      08-01-2014, 08:56 AM   #63
MadToy
64
Drives: '18 340i Xdrive
Thanks for the guide! I'll be using it this weekend
However, one question. I see folks stating the use of the impact gun is helpful. I have one, but not sure which of the bolts you think it's most needed for, so I know which impact sockets to pick up? I'm assuming the 21mm, but what about the 18, 17, and 13?
      08-11-2014, 01:28 PM   #64
Bimmer Barney
Bimmer Barney's Avatar
1250
Drives: 2011.5 E90M ZCP
Really just need it for the nuts on the knuckle, which are 21MM. You will need an extension for the rear most nut, which if I recall correctly is the LCA. The bolts/nuts at the subframe are only torqued to 74 lbs/ft so a breaker bar easily removes them. I just did this job this past weekend. +1 for slopping some antisieze on the LCA/subframe for reinstall, using a file, and I even used a rubber mallet to tap it in and line it up.
My alignment specs (I have not pulled my pins):
Front
Left Camber: -1.3
Left Toe: 0.13
Right Camber: -1.2
Right Toe: 0.13
Rear
Left Camber: -1.8
Left Toe: 0.13
Right Camber: -1.7
Right Toe: 0.19
Great right up Rob!
2011.5 E90 M3 DCT ZCP Slicktop
      08-12-2014, 06:20 AM   #65
MadToy
64
Thanks. I did the swap last weekend. Very simple. Autocrossing this weekend, so I'll see how different it feels....
      08-19-2014, 11:15 AM   #66
JoeyH335i
JoeyH335i's Avatar
Drives: 2009 BMW 335i
Very good write up!
I am just here to help!
