2010 2011 BMW 5 Series Forum F10 DIY: F10 M-Sport Fog Lights Replacement (with Photos) |
04-26-2014, 04:18 AM | #1 |
Rep 31
Searched the forums for M Sport Fogs DIY.. everyone said it's really easy and you just pull off the grill and replace.. YES!! it's that easy, no tools required.. but I took a few snaps and figure i put this up so everyone can have a better visual of the install.
Bulbs: H11 (Philips Diamond Vision 5000K H11, Price: 350 HKD) Tools: no need, just your hands. (a trim removal tool can come in handy, but not necessary) Time: ~5-10 mins. **Don't go from the wheel well, there's a radiator/oil cooler blocking access on my 520i** 1. Pull the Grill, start from one corner, and pull straight out. 6 clips in total, see red arrows. 2. remove the black plastic behind the grill (some cars have this, some doesn't) 3. Reach your hand in, twist out bulb, replace with new, twist back in. 4. Do both side, test if they work 5. Now is a good time to clear those inside edges of the grill/bumper. 6. Snap grills back into place, straight. |
05-17-2014, 08:19 PM | #4 | |
Rep 815
Drives: G05 X5,G20 M340,Infiniti Q50RS
its the best, no flickering or codes.
2020 G05 MSport 40i--Phytonic Blue Metallic/Vernasca Coffee Leather/Multi Contour SeatsTrim/Executive Package/MSport Brakes/Icon Adaptive Led HeadlightsW/Laserlight/Harman Kardon/Heated Front Seats Armrests & Steering
09-29-2015, 08:45 PM | #6 | |
17
Rep 84
Which one
11-17-2015, 08:29 AM | #8 |
Rep 4
How does the camera connect to the sat nav? I've been thinking of fitting reversing and ahead looking bullet cameras but that's as far as I've got. where would the power come from?
11-17-2015, 12:19 PM | #9 |
ZEROdoubleZERO
228
Rep 659
The center grill pops off the same as the fog light covers do, it's easier to pull off with a tool with a hook to get behind the grill and pull it out at the tabs. If you're doing the front camera retrofit please do a DYI, I also want to add the front camera. What all parts do I need? Just the camera or do I need a module too? I've read it doesn't need to be coded if you have the reverse camera already. Please let us know, thanks.
11-18-2015, 01:39 PM | #10 |
Rep 14,522
You guys and your fancy cameras! I'm just hatin'
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~ Follow me on Instagram: lsturbointeg |
11-19-2015, 02:56 PM | #11 |
Rep 5,050
Sorry for the delay: I'm fitting the BimmerTech camera & SmartView. The single camera fits in the lower centre grill and runs back to a module that interfaces between the Nav & Screen. SmartView is another box that connects to the module and will replicates your Android phone screen onto the Cars Nav screen, I really do need to get stuck in and get it installed.
12-21-2015, 11:25 PM | #13 |
Rep 14,522
pull it hard enough...at first it seemed like i was gonna break it but it'll come off
02-23-2016, 02:26 PM | #14 |
Rep 1,314
It was a pita when i took mine off. i dont recommending pulling it with brute force. it may come off but the clips are meant to be pushed back while pulling on the grill. i suggest getting the trim remover to aid with this task.
diy, f10, fogs, m-sport |
