TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > OEM Digital TV Retrofit (for CIC)..... DONE
      01-02-2015, 05:28 PM   #23
jezzy
jezzy's Avatar
35
Drives: 06 E91 325xi Black Wagon
Originally Posted by dest View Post
Ive just noticed, you have an E91.
That changes everything.
I too have one and am in the process of trying to work everything out as the set up for antennas and other stuff is unique to the E91 from any other model.
Without wanting to derail this thread, so far I have found this and am trying to research further.
I might start a separate thread for E91 research
http://bmwfans.info/parts-catalog/E9...enna_diversity
Thanks! I'll be watching guys!
      01-02-2015, 05:29 PM   #24
jezzy
jezzy's Avatar
35
Originally Posted by jammy78 View Post
You just to get the correct diversity antennas. If you want to have tv in the rear, make sure you get a tv module with RSE.
Thanks! I'll start researching
      01-03-2015, 02:51 AM   #25
makkan00
makkan00's Avatar
888
Drives: F83 and F36
You will have to change NSR rear glass which had antenna lines for DAB and TV module.
Then you add mini diversity module to connect that.
I had tv module sitting at my place for months but due to glass change etc etc, I sold it on fleabay.
For you, best bet is Kufatec kit and install one aerial at the front and one at the rear.
Not ideal but works brilliantly.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play
      01-03-2015, 02:52 AM   #26
makkan00
makkan00's Avatar
888
Drives: F83 and F36
Jammy you sure that you have f series tv tuner?
As F series coding is on enet and if you try to fit it on e series, you cannot code it.
      01-03-2015, 03:50 AM   #27
jammy78
126
Drives: F31 335D
Yeah, going realoem the TV module is for F07, F10, F11, F12 cars!
Works perfectly.... I get the all the channel / tv show information etc
      01-03-2015, 04:10 AM   #28
jammy78
126
Drives: F31 335D
The module Makkan is talking about is ebay item: 231416728634
Not having the the antenna lines already in the rear glass makes the oem route not viable. I wonder why E90 / E92 have it & E91 don't?
      01-03-2015, 08:25 AM   #29
jammy78
126
Drives: F31 335D
Modification of the bracket.... took a while:
I've had to remove this screw:
Cut a bit out as it hits the connectors:
I also needed to increase the size of one hole.
Finished job.... Oem style:
If you buy the TV module that is for the E9x you won't have this issue but those modules are older, bigger & noisier!
I can't finish the job today as I a couple of c nuts to fix the bracket to the car!
      01-03-2015, 08:48 AM   #30
jammy78
126
Drives: F31 335D
Another thing to take note if going down the oem route.... if you don't have a cd changer, you will need different boot trim (left side).
I need a new tray as my current one is too deep & takes the place where the TV module sits:
      01-03-2015, 08:50 AM   #31
makkan00
makkan00's Avatar
888
Drives: F83 and F36
Did you code the TV module or tried to read it?
As if it is from F-series it gives error. Talking form the experience.
However if you have not coded and you do not need to code it, most of the functions work.
      01-03-2015, 09:00 AM   #32
jammy78
126
Drives: F31 335D
No need to code or read the TV module. Just coded the CIC & works perfectly after I scanned for the channels!
Just need to code it for tv in motion. I think the picture will be fine whilst driving as I really got loss of signal during testing (had sound but the safety screen)! This is where the oem antenna is going to beat the aftermarket ones!
      01-03-2015, 09:03 AM   #33
dest
dest's Avatar
89
Drives: LCI E91 320d M Sport
When I had TV in my RS4 it was all Alpine kit and worked very well in general but if the road went though thick high trees or into a deep cutting like on motorways it broke up at times.
It will be interesting to see how the OEM one gets on.
The other thing is on long journeys you sometimes have to rescan due to regional channels using different frequencies
      06-22-2016, 06:13 AM   #34
dashabz
Newbie (^_^)
dashabz's Avatar
Drives: F30 330XD estoril blue 2013.
Wires installed & coded........ now over 50 TV channels
If anyone is interested in this install, just ask!
hi could you give me a run through to the process also which tuner to buy
      01-23-2017, 06:47 AM   #35
ccfj1
Tinkerer
ccfj1's Avatar
83
Drives: F25 X3 M-Sport
Sorry to resurrect and old thread, but do you have the pinouts for the power lead please?
2014 F25 X3 335d M-Sport:
      02-11-2017, 12:30 PM   #36
ccfj1
Tinkerer
ccfj1's Avatar
83
pinouts for the f type tv module
for the TV 12 pin plug (x14454)
1: power
12: gnd
2: video +
7: shield
8: video -
All pins are 100% confirmed
cic end
multi plug
2: video +
11: shield
12: video -
cic single plug
18: video +
27: shield
28: video -
Again All pins are 100% confirmed
I've plugged them in and I get the TV option on screen (cic coded for tv) and have set the region to UK and tried to do a channel search, but the status bar does not move, so not fully working.
I've bought one of the older e series tv modules and will try that.
Pins for the older e series tv should be
1: gnd
11: power
4: video +
6: shield
13: video -
      02-15-2017, 12:33 PM   #37
ccfj1
Tinkerer
ccfj1's Avatar
83
Ok, All done.
The E series tv module works right away.
Pinouts for the E series tv module.
1 : Gnd
11 : +12v
4.: Video +
12: Shield
13: Video -
Plug and play. only the cic needs coding not the car.
      02-15-2017, 02:30 PM   #38
Minisi
24
Drives: 2008 e92 335i
Would this work on my 2008 e92?
      02-28-2017, 06:45 AM   #39
ccfj1
Tinkerer
ccfj1's Avatar
83
The F-type one did not work on mine, but the e-type one should, post 37 is all you need.
      08-05-2020, 04:35 AM   #40
ccfj1
Tinkerer
ccfj1's Avatar
83
Update.
I tried again with the newer type TV module.
It was the RSE unit, TV module for BMW X5 E70 X6 E71 6550 9224300
I chose the RSE because it has the 3rd antennas, this (pink) is used for continual scanning of channels, both green and brown will scan periodically (and when you manually search), but the pink one does it as a matter of course, because this tv module is normally used in rear seat entertainment options. Plus it was really really cheap.
I suspect that most new type tv modules will work, as the MOST interface is the one that carries all the control/interface signals, the main plug just has power and video out, so i **think** that any RSE, dvt, dvt-t, dvt-t2 will work fine (but thsts just a guess), the china/japan/korea ones wont.
Pinouts are
For the TV 12 pin plug (x14454)
1: power
12: gnd
2: video +
7: shield
8: video -
cic single plug
18: video +
27: shield
28: video -
Coding: code tv option to car and then make sure you edit the cic confit so that the TV option is :-
TVM_VARIANTEN
tvm_dvb_t_rse = activ
for older type
TVM_VARIANTEN
vm_l4_most_fkat = activ
Also check option
TV
is wert = 21 this selects the correct input pins for the tv video input. (18,27,28)
RVC
if you also have the backup camera then make sure this is set to wert 23 = camera video input. (21,23,24)
There is a different bracket that sits next to the combox/tcu/mulf
I got over 65 channels and over 40 dab radio stations and the scan bar in the settings menu actually works correctly (not so with the older tv modules).
Correct e9x bracket
newer style tv module is 9176373,
older style tv module 6945074
Since i had the tv already, this was a cheap upgrade, i now get more channels and dab radio channels too and i get full widescreen and the epg is much better.
mjn771072.50
SaNGRia990.00
      01-04-2021, 02:36 AM   #41
ccfj1
Tinkerer
ccfj1's Avatar
83
2nd Update.
I tried a newer G series TV module, thankfully it has the same plug and pinouts of the f series TV, it als fits the same tv frame.
Tried it and while it found channels, it woul not display them (screen said no signal).
I then flashed the tv to the latest version using e-sys and bingo. it all started working correctly.
I now have HD channels too.
mjn771072.50
      01-05-2021, 04:21 AM   #42
Prologic
9
Drives: E90
Trying to do this retrofit as well, but encoutered a problem, that after preliminary testing and coding (added $601 to cas and frm and default coded cic) I can not get channel search to work.
Tv module is from F01 9222844 p/n.
Is there anything else I am missing?
      01-05-2021, 05:38 AM   #43
ccfj1
Tinkerer
ccfj1's Avatar
83
make sure that the MOST in in the correct way round.
Also check that the TV module selected in the cic config is the correct one.
TVM_VARIANTEN
or
TVM_VARIANTEN
tvm_dvb_t = activ
And NOT vm_l4_most_fkat = activ
      01-05-2021, 08:36 AM   #44
Prologic
9
Drives: E90
TVM_VARIANTEN
or
TVM_VARIANTEN
tvm_dvb_t = activ
My car has Logic7, so I immediately get no sound if MOST is disrupted, which is my case is working fine.
As for these CIC options, they are correct after default coding CIC module.
