rear view mirror homelink fuse
05-22-2013, 08:41 PM | #1 |
Rep 1,529
Hey guys anyone know which fuse is the one for the homelink? i just recently got my battery cable recall done and now my homelink doesnt work...the light doesnt even come on when i push any of the buttons.
you guys think it could be a fuse blown out or something worse?
Space Gray l 6MT l OSG LSD w/ VAC Race Diff Cover l Cobb e30 l Morr vs8.2 l UUC SSK w/ DSSR l VSRF Catless Dps l RPI Intercooler l CDV Removed l HID AE 8000k l ETS Catback l AST 5200 w/ Vorshlag Camber Plates l ER Dual Oil Coolers l Rear Camber and Toe Arms l K&N Drop In l Solid Tranny/Diff/Subframe Bushings l Bridgestone RE-11
05-23-2013, 07:57 AM | #2 |
Rep 1,529
anyone?
07-05-2013, 01:18 PM | #3 |
10
Rep 29
I came across this thread yesterday. Went to hardwire my radar detector and noticed there was no power on the green/white wire for the homelink. Checked fuses and everything is good.
I had my battery recall done around May and noticed yesterday my compass and homelink no longer work. I don't believe I popped fuses, I've done a lot of electrical work before. Did you find a solution to this problem? |
07-06-2013, 07:00 PM | #5 |
Rep 1,529
oh yeah you have to go into your glove compartment and get into the fuse box...just look at the placement card and find the one that goes to the homelink.
cant remember exactly which one it is but youll figure it out. they just moved the fuse over or something which i dont know why.
07-06-2013, 09:01 PM | #7 |
Rep 1,529
yeah but you should check to make sure they didnt move some around...there are empty slots.
08-02-2015, 12:54 PM | #8 |
Rep 3
Did anyone ever get a response on what it could be for those that had no problem with their fuses? My home link led doesn't light up and my compass doesn't work either.
02-23-2016, 10:57 PM | #9 |
20
Rep 85
Drives: 07' 335xi and 83' 528e
Anyone ever figure this out? Having the same issue currently.
06-22-2017, 09:29 PM | #10 |
Associate Special Class
30
Rep 105
Drives: 2013 335is
I hate to bump an old thread but has anyone figured this out? I recently installed an autodim, homelink, and compass mirror in my 2013 335is. The mirror will not power on and all of the wiring is correct. Please let me know if you can help.
2013 E92 Alpine White 335is: 7spd DCT
10-24-2017, 07:23 PM | #11 |
Rep 45
Sorry to bump an old thread again but anyone figure this out? My rear view mirror doesn't dim, compass off, and homelink doesn't work. Ive checked fuses and all fine. Any ideas?
12-15-2017, 12:39 PM | #12 |
20
Rep 85
I never was able to figure anything out. However as of recently I began thinking about it again and did some research. I plan on seeing if everything in the coding is "on" such as the compass, etc. I read on the F15 forum that even if its "on" sometimes turning it "off" and back "on" fixes this issue. I'll try it this weekend and see what happens.
12-15-2017, 01:14 PM | #13 |
463
Rep 2,763
mirror get it's power from roof functional center which is integrated in front roof light
roof center in cars without sunroof and after 2007/09 get it's power from F62 F25 F7 fuses homelink and fla function will not work without ignition enabled
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
12-15-2017, 09:26 PM | #14 |
20
Rep 85
Could you clarify that a little bit? I think I’m not reading your post the way you intended. My car’s production date is 2007/03, any idea where or what fuse it gets it’s power from? Thanks
12-16-2017, 01:40 AM | #15 |
463
Rep 2,763
for 2007/03 fuses will be F40 F12 F28
12-16-2017, 07:36 AM | #16 |
20
Rep 85
12-30-2017, 02:02 PM | #17 |
20
Rep 85
12-30-2017, 02:36 PM | #18 |
463
Rep 2,763
start engine and with engine running check power wires to mirror then
01-05-2018, 06:27 AM | #19 |
20
Rep 85
01-10-2018, 05:00 PM | #20 |
Rep 1,354
I replaced my mirror to add High Beam Assist.
The replacement mirror would not light up at first. I thought there was something wrong with my wiring or the mirror. Then I read that you had to default code the FSD after changing the VO. Sure enough after doing this my mirror lit up, the compass came on, etc. I don't remember if that also affected the Homelink or not, but it definitely affected everything else. |
02-16-2024, 05:47 PM | #22 |
Rep 1,354
I default coded the FSD.
If you are not familiar with this I suggest to search for default coding here. There are several threads that explain the process in detail and the software tools you need to do that. Default coding which is normally done after a vehicle order change, reverts the module to factory default conditions per the list of hardware the car believes it has in the vehicle order. In effect the firmware in the module already has the correct programming in place for many different options but does not enable these options until it both reads the available hardware from the vehicle order then is default coded to enable that hardware. I hope that clarifies it. |
