07-26-2017, 11:25 PM | #1 |
54
Rep 153
Carbon Fiber Roof Saved! dreadful gel-coat fix
I AM HERE TO HELP WITH ANY QUESTIONS FOR THOSE IN CONSIDERATION OF THEIR OWN EFFORTS!
So I myself have done countless hours of research trying to figure out who else saved their carbon fiber roof from the peeling gel-coat. The most i found was one guy with an M6 made a video talking about his roof and ended up painting it the same color as the car. Well folks, that does not satisfy me. I purchased the car for the car and its performance and aesthetics. Painting over the looks of the carbon the same color of the car would be nothing but an utter disappointment. So here I am now writing up on this experience and hoping i give a deep insight on my experience on recovering the roof without sacrifice. I am also conducting this write up to help give people the relief that they to can also salvage their roof from the horrifying gel-coat that becomes weaker over time from outside sittings. Not only have i taken plenty of pictures but i also made some video footage of my process for them DIY guys. I want to make this write up simple and fast because no one wants to read forever. haha. Lets begin remove the antenna cover, it is double back taped so you can get some sort of strong thin plastic to removed it cutting through the tape. once removed, use a T25 or T30 torque socket and pop the antenna off. I suggest taking a picture of the wiring plugs to ensure its plugged back into the same slots. Peel from the beginning center of the roof Work your way around until entire center is peeled in my experience the 4 corners begin to become a challenge. that is because the roof is a dome shape which the sun beats directly in the center. any hard areas to work i used a brand new clean razor blade. you cannot cut directly with the blade you must take your time and do a teeter-totter motion to slice through the gel-coat. be sure to keep the blade in a very sharp angle to prevent slicing into the roof. it may happen that's okay just cannot cut so deep more than likely you will not see it after re-cleared. where the antenna is located try your best to remove as much clear as possible but keep in mind the antenna will cover the area so it is okay if there is a hard line inside within the cover itself no one nor you, will see it. as for the edges, use the blade in a sharp angle to carefully cut through the clear, it was relatively easy for me cut down as much as possible, keep in mind also here the roof moldings will hide any hard lines in there too. it is an option for the enthusiast to have both front and back glass removed for painting but is not needed. they can pull back the strip and mask off the seal. mask off the hole where your antenna was with good tape and rinse down your roof cleaning it up as well as you can with water, also enjoy it with water on your roof as it simulates clear coat looking clean. The next morning i drove to my shop where i work and parked my car inside the other building till my lunch break and dropped the car off at my buddies shop down the way for him to do the job. 5-7 coats of clear is recommended, every 2 coats sanding is recommended. the final coat you will still see the weave pattern in the clear coat as it settles in. my buddy did 7 coats as he told me. i left it alone at that if i want to i could sand it down and buff polish to give it a flat final finish. but the weave pattern in the coat does not bother me i dont really notice unless i take a good look at it. As safety reasons i highly suggest gloves and a respirator at most to avoid inhaling and getting all the resin all over your hands. do at your own risk. Last edited by E92friendly; 07-29-2017 at 11:13 PM.. |
9
avantegardestyle290.00 Blindside_1376721.50 FMLYSDN1183.00 M3MPH1S592.00 Tewie197.50 TTony271.00 Ftypekid29.50 InnerBlueSkies1092.50 Idfkman473.00 |
07-27-2017, 12:42 AM | #2 |
Rep 3,152
Excellent work on rescuing the CF roof.
Current Mods:
2004 E46 M3cs JB/CSL 2010 E70 X5M AW/BLACK 2011 VW Golf R DSG White/Black IG: @060Motorsports |
07-27-2017, 06:38 AM | #3 |
Rep 10,602
Very nice. Looks brand new.
Should be very helpful for others. I know I have seen at least one post or two about guys who had their carbon roof start to fade or peel. |
07-27-2017, 07:09 AM | #4 |
General
64200
Rep 24,859
Good job , CF roof looks really good !
Think I saw a dent in your car ?
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
07-27-2017, 08:07 AM | #5 |
54
Rep 153
///M Power-Belgium64200.00 |
07-27-2017, 09:47 AM | #6 |
Rep 1,368
Nice work!
07-27-2017, 09:56 AM | #7 |
3769
Rep 2,912
Drives: 2011 E93 M3
Great work!
Most will recommend painting the roof body color because removing the clear from bare carbon is very difficult. It is very easy to use a sander and go past the clear and into the weave which will ruin the weave's visual effect. Clever of you to use a razor to shave off the 'dead' clear. Sounds like the conditions were just right to allow it. Most shops wouldn't hassle with that method. |
12M331.50 |
07-27-2017, 10:04 AM | #8 | |
54
Rep 153
07-27-2017, 10:31 PM | #9 |
Rep 1,368
Was your car parked outdoors in the sun for most its life?
07-28-2017, 01:50 PM | #12 |
54
Rep 153
07-31-2017, 12:08 AM | #13 |
Save the manuals!
6031
Rep 6,753
Great work salvaging your roof! Always good to see people trying new ways to fix these issues.
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
07-31-2017, 11:02 AM | #14 |
54
Rep 153
08-25-2018, 09:55 AM | #16 |
the doctor
284
Rep 432
I use to work for Mitsubishi Motors NA. The carbon fiber rear wing coating would start to fade and peel. One of the body shops in San Jose was able to fix them. The guy would use a razor blade and strip it by hand (amazing) and refinish it. They looked pretty much factory.
It was so good that we sent finished samples back to Japan. |
12-31-2018, 09:24 PM | #18 |
4846
Rep 2,445
Drives: 2022 M3 6MT
Could you wet sand it instead of taking a razor to it?
2022 M3 6MT - Portimao Blue Metallic
2022 X3 M40i - Tanzanite Blue Metallic |
01-07-2019, 04:16 PM | #20 |
Rep 9
Hi all, new to the forum. I have a 2011 M3 Coupe with the CF roof and just started having the same issue. I had a small chip and moisture got underneath the clear so now there's a bubble about 3 inches in diameter.
Can anyone recommend a body/paint shop in the Los Angeles/Orange County area that can do this repair? The body shop I use for some of my other cars has never done this with carbon fiber and said that his guys would normally sand down the spot, feather it out and respray the clear coat. Thanks, Mike |
01-07-2019, 04:26 PM | #21 |
Rep 1,881
5-7 coats of clear with sanding in between would cost a fortune for the consumer. almost better value to replace with a new roof... for insiders it makes sense, but otherwise probably not.
I am never able to post pictures on forums, all my pics are on IG @baye30 https://www.instagram.com/baye30/
Current Garage - [2011 E90 M3 ZCP] [2005 E53 X5 3.0 Sport] [1988 E30 325IS 24V] |
01-07-2019, 07:30 PM | #22 |
Rep 9
I'm in the auto industry so I can get insider rates. The issue I'm running into is that a lot of the shops that I use haven't done anything like this (and generally don't work on CF). Is this process something that any competent body shop should be able to do if I show them this link?
