Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > 330i Rear Diff Swap with AT 3.64 diff questions (Updated video)
      04-06-2016, 11:59 PM   #45
neoduffer
Fast In, Slow Out
Drives: 06 E90 330i
2006 330i  [0.00]
I just completed the swap. The change is very noticeable and I seem to run out of revs pretty quickly now. Overall it was a great way to liven up the car and make it way more responsive on throttle.
: Ken
houbmw65.50
      04-08-2016, 10:59 AM   #46
pavproch
9
Drives: Z4 3.0i & 330ixT
Did the same diff swap MT->AT (ie. 3.15->3.64 , in my case multiplied by factor of two, because of xDrive ) few months back. Now it runs simply WONDERFUL.
Yes, the mileage decreased proportinally, but.... who cares?
Daily:330ix 6MT - PBX, HR SportSprings, Koni Yellows, OZ Ultraleggera 18", PI+PE, CDV off, UUC sways, M235i SportBrake (front), Cquence rotors (rear), 3.64 diffs, LSD rear
Funcar: Z4 3.0i 6MT - HR SportSprings +sways, OZ Ultraleggera 19", 5.00 diff by Drexler, CDV off, Quaife LSD, M235i SportBrake (front), Cquence rotors (rear)
      04-10-2016, 11:42 AM   #47
X330I
Drives: Alpine White 330xi
I also have a 330xi 6mt, was the fitment from the automatic bolt on ? im sure you had to change both front and rear diff, any other auto diff is bolt on ?
      04-10-2016, 02:10 PM   #48
pavproch
9
Yap, the swap was straight PnP.
      05-01-2016, 06:00 PM   #49
mbanks21
1268
Drives: 2015 335i MSport
Still have an auto diff from a 328 sitting in my garage if anyone is interested in it
      01-09-2018, 08:36 AM   #50
F31cruisin
Drives: 330i
Has anyone dyno'd the before and after Diff install?
      01-09-2018, 10:34 PM   #51
tlow98
Drives: 2009 E91, 2014 F15 x35i
Won't make much of a difference. At least, it shouldn't. This is a torque manipulator, not increaser.
Volasko705.00
      01-30-2019, 03:05 AM   #52
breakingpoint
Drives: E92 330i
did anyone ever consider a 6th gear rebuild after they installed a higher final drive ratio?
Since 6th gear is an overdrive anyway, this seems the way to keep the revs down during highway cruising. A big hassle though...
      01-30-2019, 02:52 PM   #53
dwashy
65
Drives: 2006 E90 330i
Originally Posted by Volasko View Post
I have yet to see ANY video of a N52 stock or modified running the through the first 3 gears with this modification! Please someone make an easy video with your phone and youtube that!
Already did a video, no speedo footage though. When it warms up I'd love to, we've got a good "Mexico" road just North of where I'm at
N52 | +1mm MILVs | Catless | 3-Stage IM | BPC Tune | 3.64 diff | AirLift Performance 3H | M3 Control Arms | SPL Parts BumpSteer Correction | UUC Evo 3 Shifter | CCV Delete | Valeo SMF Flywheel | CSF Aluminum Rad | VAC Front Hub Extenders | BMS Cowl Filter Delete
Appreciate 4
      02-13-2019, 10:34 AM   #54
Volasko
Volasko's Avatar
705
Drives: 06 330i E90, 18 530xe G30
Sounds epic at WOT but that burble would drive me mental after 10 mins.
      02-13-2019, 10:28 PM   #55
Blueeyesredpanda
Blueeyesredpanda's Avatar
401
Drives: E90 / F30
Did you mount the mic near the exhaust, and do a "voice over" for the footage?
3IM . Okada Plasma Direct . Euro Ram Intake . AA header (Pending) . PE . 2nd Cat Delete . F30 340mm 6 pot . EBC Yellow Stuff . StopTech SS Brake Line . BMW Performance CF Strut Bar. 219M . PSS
      03-15-2024, 04:00 PM   #56
carebear85
Drives: 2007 335i ,2005 545i, 2008 528
2005 BMW 545i  [0.00]
2007 bmw 335i  [7.50]
I have a 2007 335i I'm trying to find out if it's compatible with the rear cv axle on a 2004 330 x.I
      03-15-2024, 05:19 PM   #57
carebear85
[QUOTE=approximate;17431756]
      03-16-2024, 10:05 AM   #58
chilledn52
Parts Pro
chilledn52's Avatar
65
Drives: 2007 BMW 328xi 6MT
2007 BMW 328xi  [10.00]
[QUOTE=carebear85;30989569]
no.
different generation
even e90 330i and 335i have different cv axles.
E90 328xi 6MT | Intake Scoops | K&N + Charcoal Filter Delete | DIY Dinan 3in | 3.25in + 3.5in piping | N54 Manifold | Ceramic Coated Headers | Secondary Cat Delete | Xdelete | 3.91 Diffs | 22RPD Tune
      03-16-2024, 10:13 AM   #59
chilledn52
Parts Pro
chilledn52's Avatar
65
Also my Diff Swap Impressions. Do it. Worth It.
https://www.e90post.com/forums/showthread.php?t=2013056
