TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > Supercharger stuff (MILVs+AA+BPC)
      04-28-2018, 06:43 PM   #23
Phyrexia
Resident Pedant
Drives: '15 335i 8AT
Originally Posted by Noir View Post
I didnt tell em my setup...
How are you planning to tune this? That statement on the ESS website has me scratching my head. No headers allowed?
'15 F30 335i 8AT Estoril II/Black (12.218 @ 114.94mph)
MHD Stage 2+ 93 / XHP Stage 3 / M-Goodies / K&N Filter / ER CP / CSF IC / NGK 97506 / ER DP / Michelin A/S 3+
      04-28-2018, 07:50 PM   #24
Noir
Noir's Avatar
Drives: 2006 E90 330i 6MT
BPC will be doing the honors.
http://www.e90post.com/forums/showthread.php?t=1393038
See you, space cowboy.
Supercharged
Phyrexia502.50
Phil@BPC465.00
      04-28-2018, 09:12 PM   #25
Taskmaster
Japan
2465
Drives: M235i 6MT / E92 328 Msport 6MT
What is the new exhaust going to be? And do you have the stock good?
      04-28-2018, 10:03 PM   #26
Noir
Noir's Avatar
Man, if it comes down to it, probably stick to the known good, go with supersprint mids. I have 335i mufflers though, too expensive to experiment with mufflers... I think these are more free flowing anyways, but thats pure speculation... Mids are custom fab'd by my buddy/indy guy.
No doubt in his ability! Just thinking it may have been created to sound great vs being effective. I'd like to hop underneath and g et t some diameters and compare those measurements and the shape to a set of supersprints ... again, wondering if the baffles in the inner tips are possibly inhibitors to the true potential (if it is in fact there....) as they do have holes punched to provide an exit for the pressure and all, but maybe the obvious situation is that they are inhibiting the free flow by a certain degree...
Supercharged
      04-29-2018, 09:28 AM   #27
CobraMarty
CobraMarty's Avatar
619
Drives: 2007 328xi e90 + e92
Oil coolers-
The N5 for $1050 ouch. You can do the bmw part for way less than half.
      04-29-2018, 09:35 AM   #28
Mike.
Mike: Everyone's Pal
Mike.'s Avatar
2044
Drives: F80 M3
2013 BMW 335xi  [10.00]
you done did it now
Alpine MSS Stage 2+ E30 tune|MST Intakes|VRSF Single Mid Pipe|Agency Power Intercooler|VTT Full solution crank hub fix
      04-29-2018, 09:50 AM   #29
Taskmaster
Japan
2465
Stock hood*
      04-29-2018, 10:59 AM   #30
desertman123
E82 Mudflap Ambassador
desertman123's Avatar
Drives: '08 128i
1992 Honda Beat  [9.50]
2008 BMW 128i  [10.00]
2014 BMW 528i  [10.00]
They're too lazy/can't figure it out to give a proper tune with headers. Claimed something along the lines of 'you can get more power out of the stock headers due to stock O2 sensor locations' which sounds to me like they just don't want to spend the time figuring out how to tune MSV70/80 properly. Probably they know they won't make a whole lot of money off the kit. But they gave us boost when no one else would.
BPC is here to save the day.
My 2008 128i - Sparkling Graphite/Beige - Sport pkg - 6MT - Click me!
Parents' 2014 528i - Mineral White/Ivory White - fully loaded
Instagram @Andreys_128i and @Honda.Bito
Phyrexia502.50
tlow982188.00
      04-29-2018, 11:44 AM   #31
CobraMarty
CobraMarty's Avatar
619
I have a ESS stock pulley 115mm(4.52").
And a Vortech 4.25"(108mm).
The Vortech requires a 1.0mm(0.04") shim washer behind the puller to space it out so the ribs will line up and the nose of the pulley needs to be shaved down 3.6mm(0.14") so the nut can go on.
Vortech also has 4.10"(104mm), 3.80"(96.5mm) and 3.60"(91.44mm) pulleys if needed.
      04-29-2018, 12:47 PM   #32
Noir
Noir's Avatar
Originally Posted by CobraMarty View Post
Oil coolers-
Yeah you right...
Are you referring to the oem pipe the OP used in the previous thread used?
Supercharged
      04-29-2018, 12:48 PM   #33
Noir
Noir's Avatar
Stock hood*
haha... oops... No I do not, I have the carbon vented hood from duke dynamics
Supercharged
      04-29-2018, 12:50 PM   #34
Noir
Noir's Avatar
Yeah, I am glad they took the time to make the kit possible, it is a shame they didn't want to take the time to do further R&D to make the headers combo happen. FWIW I'm sure their tune would be inferior to Bobs wizardry anyways!
Supercharged
Biginboca3763.50
      04-29-2018, 08:27 PM   #35
CobraMarty
CobraMarty's Avatar
619
Noir, I got your email. Thanks, You Rock.
I can't wait for this to happen. It will open many doors and answer many questions.
      04-29-2018, 08:49 PM   #36
Noir
Noir's Avatar
You're welcome!
Same! Stoked for what the future holds!
Supercharged
      04-30-2018, 08:35 AM   #37
Eagle1oh7
Eagle1oh7's Avatar
Drives: '11 328i Sedan
Bro you're stationed here in VA beach?
DONE: Seibon CF Hood, M3 Rep, MSport rear w/DD CF Diffuser, M3 Rep Skirts, Seibon CSL trunklid, Forgestar F14 18s w/Michelin PSS, Eisenmann catback, AA Headers, BPC Stage 2, Charcoal Delete+revMotor+AFE Drop In filter
FUTURE MODS: LED headlights, CF rooftop, M3 Suspension Conversion, Dinan CAI Mod
Noir883.00
      04-30-2018, 09:23 AM   #38
CobraMarty
CobraMarty's Avatar
619
Read all thru the install instructions. Fairly straight forward and easy.
Uses STOCK injectors. No instructions to change out the injectors. Very interesting.
Couple of questions-
-Are there 6 new injectors included in the kit?
-What is the size of the SC pulley supplied
-What is the part number of the new belt
-What is the 'Copper Paste' to put on the bolts going into the engine block
-Is there any part numbers on the idler pulleys, SC Koyo pulley and the pulley on the bracket
Most interesting is that it looks like the SC housing could be 'clocked' so that the outlet is up high and pointing backwards. This could then go right into the TB and then into a custom intake manifold with an intercooler inside the manifold, similar to the B58 intake manifold.
      04-30-2018, 09:26 AM   #39
Noir
Noir's Avatar
I will try to get you some answers tonight.
F-cked up royally this morning and have a long evening of cleanup ahead of me.
Will get you some answers NLT tmrw night.
Supercharged
      04-30-2018, 09:26 AM   #40
Noir
Noir's Avatar
I am!
Supercharged
      04-30-2018, 12:47 PM   #41
Taskmaster
Japan
2465
Does ESS not sell the VT1+ with more boost and better injectors?
      04-30-2018, 01:02 PM   #42
Noir
Noir's Avatar
See, I was wondering the same thing.
I was looking for that kit originally, or should I say, the upgrade kit and I don't recall seeing it on the website. I dunno when it got taken down. Maybe I overlooked it...
Edit: Can't recall, is that upgrade the one the handful of cats were having issues with?
Supercharged
      04-30-2018, 03:36 PM   #43
W37V
[Oo=||=oO]
1103
Drives: e92n52 & f15n57
Iirc, Injectors that come with VT1+ kit are regular injectors from e9x m3.
So if anyone wants to upgrade later on, they could.
Noir883.00
      05-01-2018, 07:18 AM   #44
CobraMarty
CobraMarty's Avatar
619
There is a used VT1 kit on ebay now. It has a 130mm(5.12") pulley.
Noir883.00
