BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > What else should i replace with valve cover
      03-05-2024, 01:46 AM   #1
trickster123
Drives: 2007 e92 325i 2.5L
Going to replace the vc on my e92 325i (uk) n52b25a with a febi part, does anyone know which gaskets this includes? And i cant find where to buy an oem bmw gasket for the vc. Any recommendations on what else to replace while im doing this the car is at 120k miles at the moment.
      03-05-2024, 03:25 AM   #2
Phil325i
Phil325i's Avatar
619
Drives: E92 325i MSport Coupe
Genuine covers come complete with gaskets and fixing bolts in place. As for other jobs, a good time to do oil filter housing gasket if not already done...
      03-05-2024, 05:06 AM   #3
trickster123
Does the ecentfic shaft sensor and valvetronic gasket come with it?
      03-05-2024, 07:46 AM   #4
Suvorovo
Suvorovo's Avatar
254
Drives: Broken e90 330xi 6MT
Why are you replacing your ESS? Did you find oil in the connector? This part is kind of expensive to just replace just cause.
Gaskets come with a kit for both valvetronic and ESS.
      03-06-2024, 01:12 PM   #5
AmuroRay
AmuroRay's Avatar
2290
Drives: M235i
MILVS and N55 rockers, essential sensor and a nice tune!
Mods: Yes.
      03-21-2024, 12:18 PM   #6
d1saster
Bulgaria
60
Drives: F15 N55 & E93 N51
Check both vanos gear bolts if haven’t been replaced by the recall. Check the vanos timing. Might need the timing special tool for both of the tasks.
      04-04-2024, 04:39 PM   #7
Varin
Drives: E92 325i
I'm replacing my valve cover next month, also UK 2.5L N52B25. Already ordered MILVS from Marty yesterday, will do that now as I don't want to go through opening it all up again any time soon. Might get the breather hose, that one from the back of the cover which has like 75% chance to break... If I do that, I might as well just replace whole CCV with other hoses.
Probably will do oil filter gasket as well at the same time.
Someone mentioned to me that I might as well get new DISA valves for the manifold. They might still be the original ones, car is from 2006. Does someone here knows if those degrade with time and affect performance and I should surely replace them after so many years of service? Or unless broken - do not touch?
      04-05-2024, 07:57 AM   #8
Phil325i
Phil325i's Avatar
619
Not sure if your N52 valve cover is alloy or plastic, but if it's plastic I would replace the whole cover. It's easy to replace just the gasket and miss a hairline crack or dead PCV system, which then means repeating the whole job again to change the cover.
