TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > Tech Info: E90 330i N52 Three-Stage Intake Manifold
      04-12-2021, 02:11 PM   #925
DavidPayne
15
Drives: 2011 BMW 328i xdrive
Hi,
I plugged in the small disa, and when I press the gas pedal it does move a little at about 4500rpm, but it does not shut completely.
With inpa I had trouble, but it does make it move a little every once in while.
Does that mean it's shot?
I did not update the ecu yet.
Thx,
David
      04-13-2021, 06:19 AM   #926
Hotter
Hotter's Avatar
72
Drives: BMW E92 328i -> 330i
Does N52B25UL 753082806 from E60 2006 523i also works for 328i->330i?
From photos it has 2 hoses at the bottom.
      04-13-2021, 07:10 AM   #927
neilvan
neilvan's Avatar
858
Drives: 09 E90 335i M-Sport 6MT RWD
I mean it'll bolt on, but the 2.5L manifolds have smaller diameter runners than 3.0 versions
      04-13-2021, 07:57 AM   #928
Hotter
Hotter's Avatar
72
Thanks, I will use N52B30OL then, not sure which car it came from, but that should definitely fit correct?
      02-21-2023, 12:18 PM   #929
dragon-fly
Drives: BMW E91 BMW E46
I will have a manifold + disa and possibly ccv for sale soon, am located in Canada, Montreal area, anyone interested?
Car is probably getting totaled out from rear end collision.
      03-22-2023, 09:27 AM   #930
omarg
Drives: E92 328xi
I'm in Ottawa, on if you have that intake for sale I would be more than happy to take it
      03-22-2023, 09:37 AM   #931
dragon-fly
It's already gone.
Good luck!
      04-26-2023, 06:05 AM   #932
Arturas
17
Drives: 325i
2005 325i  [0.00]
Can anyone please elaborate on this?
I run european e90 325i 160kW '05, on a pillar B there's indication it's equipped with N52B25A which is ok. But I've looked into my intake manifold it clearly has something DISA'ish things on it. As I understand, it must not have these flaps since it's 2.5L. If not DISA's what is it then? Not su much familiar with BMWs
      04-26-2023, 09:39 AM   #933
vilord
Drives: E91, Tundra, TT, SV650
You do have a DISA manifold already. 2.5 did get it in some variants.
Jesse
      04-27-2023, 02:39 AM   #934
Arturas
17
Drives: 325i
2005 325i  [0.00]
Thanks for reply. If there're DISA's, then couple more questions.
- Does that mean I have physically same manifold as the one found on 3.0L 190-200kW versions?
- If the answer is yes, going further, does that mean it's enough to have current ECU flashed/mapped (or even replaced with another sourced from 3.0L together with CAS and key) to reach more than 160kW? I know I won't reach 190kW since it's 2.5L but heard rumours that even 2.5L versions benefit significantly.
      04-27-2023, 07:04 AM   #935
neilvan
neilvan's Avatar
858
Read 6 posts up on this page; I have a pic showing the difference between the 2.5L and 3.0L manifolds
Arturas16.50
      05-15-2023, 12:42 PM   #936
mattanderson
193
Drives: 2007 E92 328i
What's everyone doing for DISA valves in 2023? Bite the bullet and go genuine BMW from FCP Euro?
      05-17-2023, 08:56 AM   #937
Spence90
Spence90's Avatar
21
Drives: Bmw 330i
Most people recommend genuine only on disas just make sure any oil from ccv system is sorted or they'll keep failing
